Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I cant find a part for my wd-52525
I Just replaced my Lamp and now I have to rep[lace the ballast i cant find the part anywhere and Mitsubishi is no help. Any advice?
  • Anonymous Dec 08, 2008
    I replaced the lamp but it still does not work
  • Mitsubishi Master
  • 8,617 Answers
What makes you think the ballast is bad. Thats one part on the Mitsubishi DLP that very seldom needs replacement. Whats the symptoms with your WD52525
Posted on Jun 28, 2008
Where can i get a color wheel replacement for my DLP Mitsubishi WD-52525 210719 TV? I have changed the lamp and still the TV goes to black and the status light goes on.
This DLP tv model don't have a colors wheel.U hear alot of clickings sound,when power turn on?The Ballast board it dead.This board,job to help projection lamp to ignite.Tries websites like Partstore.com,Ebay.com to buy the Ballast board for the replacement.
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
My WD-52525 started a rubbing noise coming from the back area. I figure it's the light engine. Color was off and it won't restart, has a lamp light now. Lamp is 4 months old. Sound like light engine?
This sounds like your color wheel. this will affect the colors on your screen. Do check your lamp though, at 4 months you still should have a good lamp. Unless you have a bad ballast affecting the lamp as well. If you hear a rapid clicking or an electrical buzzing type noise. "ballast"
Apr 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 52525 TV Red Lamp LED
340v should be on power pwb plug PL on the 1 and
5 (GND) pins for the ballast. and the ballast plug CN should also have the 340V with pin 1 of that plug being GND nd pin 3 should have the 340V If the PL plug on the power board is low the power pwb has a problem most likely the doubler circuit. If CN plug voltage is high say 360V the ballast is suspect.
Jan 10, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I replaced a mitsubishi WD-52525 lamp because the light was constant red. It still doesn't work, now what do I do? I think it is a bad ballest where is it and how do I troubleshoot?
The ballast is on the right side looking from the back. If the ballast is working you should hear a slight sizzling sound when it is turned on as well as the color wheel start. The color wheel has to start before anything will start. Also, make sure all covers are installed. This set has safety switches every where.
Oct 14, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 Lamp ballast
i am sending a response to your request to your email address.
May 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Red lamp light with newbulb, won't come on error code 34
There are two 1000uf 16V capacitors on the PWB that cause that problem code 34 lamp abnormality. If you need more info let me know.
May 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
218 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
