Question about Pioneer Televison & Video
I have a Pioneer PDP505PG about 4 years old. About a week ago it started flashing every 7 seconds until it went into standby mode. I turned it off and the next day it worked fine. Last night it did it again and now doesn't work. your ideas would be appreciated. I have heard that it may need to be re gassed or something like that? Cheers Mark Brebner
    Master:
  • 497 Answers
Faulty relay contacts should be problem.
Posted on Jul 03, 2008
  • Yaz  S
    Yaz S Jul 03, 2008
    please do keep us updated.
    Thanks for using Fixya
    Genius:
  • 1,689 Answers
Mark,
good day
re-gassing may also be a fix since the TV won't somehow turn on or go off from standby, regassing/recharging is like fixing or reconstructing the plasma so that after 10-15 years of use, you will get a "like-new" display from the unit.
about the standby, if the unit realizes that it has an internal issue (specially with the plasma's going bad) it will not allow you to turn it on because forcing the plasma to work if it is worn out will cause more damage. much like a breaker, it avoids further damage to the whole circuit.
best move is to get it checked by pioneer or a local repair shop that fizes pioneer, also note that regassing or resharging will cost arouns $100 to $400
good luck
-mox
Posted on Jun 24, 2008
    Genius:
  • 1,847 Answers
Try power cycle , and load the default factory settings.
    Sergeant:
  • 260 Answers
You need to try a hard reset of the television (unplug the set for a couple of hours and plug it back in). If that does not work, you most likely need a new power supply. the safe mode is preventing damage to the unit if the power supply is not working.
Let me know if you need help doing that yourself. You may want to try one of our nearby professionals.
Ken
Windows 2000 xp will not boot up
Quite possibly your hard drive is either bad or going bad. I hope you have a backup of your stuff.
Oct 01, 2017 | Pioneer Computers & Internet
LG 19 LH 2000 no picture or sound
i have exactly the same problem and my tv is just 2 weeks old !!
any soloutions?
Nov 21, 2009 | LG 19LH20 19 in. LCD HDTV
Oil light flashing, last oil change 7 wks ago
I belive they didn't reset the oil light timer. I belive the sequence is 1. key on (not acc with engine off)
2. step on the brake pedal 5 times within 10 seconds. 3. key off. 4. start car. 5. check if the light went out. you may have to try it a few times to get it.
Jun 25, 2009 | 2003 Pontiac Grand Am
Hi, I have a Panasonic W32D2DP its about 5 years old. It worked fine until about 3 weeks ago. It started cutting off and going to standby. It worked fine after for a few more hours, then would do it...
It's going to be cheaper to buy a new TV. Once you get this problem solved, another one will pop up. The parts for a TV that's 5 years old are not going to be cheap. Most TV repair shops stop carrying parts after 4 years, & the manufacturer stops making them after 7-10 years. With a semi-major purchase like a TV, it's best to purchase an extended warranty. ipmart. com offers a cheap repair manual. You'll be suprised how expensive repair shops can be when it involves "out-of-warranty" work.
May 08, 2009 | Televison & Video
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Flashing Standby Light (6 times every 2 second interval)
A 6 flash error indicates a problem with the backlight. Your set is less than a year old and still in warranty, so you should contact Sony and arrange for a service call to get it repaired.
Nov 10, 2008 | Sony BRAVIA KDL-40V3000 Television
Time change on Pioneer car radio
Turn the raido/cd player off. Hit the clock button. Time will display. Press and hold down the audio button for 4 seconds. Use the arrow keys to change time. Press and hold the audio key when finished until the time is done flashing.
Nov 07, 2007 | Pioneer KEH-P2030 Cassette Player
Sound, but no picture. Standby light blinking 5 times
A few weeks ago my set started flashing to a black screen. Now a couple of weeks later, i have no picture, but the set turns on and i have sound. The standby light is flashing. I purchased the set in 2000 so it is seven years old. This is the first problem. Could it be all three of the bulbs? Could it be all three of the bulbs? no as you say that sound is ok that means your power supply &high voltage section is ok. please check chroma ic luminance section or system control section stand by ckt ihanks
Sep 11, 2007 | Sony KP-53HS10 TV
Televison & Video Logo
217 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
