Question about HP LaserJet 2430 Printer
Problem with my HP laserjet printer
I have a problem with the hp laser jet 2430n printer. It has only been two years now and I have been using the hp laser jet 11A toner and as for today it has a message saying i have to insert black cartridge even though it is already there and then after five minutes than it can print. Please can you explain what is the problem there? I really need help. I don't want to change to change to other brand though. Is there anything I can do
  • 81 Answers
It seems like the cartridge sensor is loose. Turn off the printer, unplug it and take the toner off. Wait a few minutes (it can be very hot) then try to find the sensor (in the area where the toner goes and see if it is loose (if so, try to adjust it).
Good luck
Posted on Dec 13, 2008
How to scan a document using hp laser jet?
You can follow the linkd follow below, it will detail you how to scan document using HP Laser Jet:
Hope this helps.
Apr 18, 2011 | HP Laserjet M1319F Laser Multifunction...
What is service error 49.4C02? HP Laser Jet 2430n
Printer error code "49.4c02" is one of them. It occurs when there is corrupted data. This may confuse the printer, and it stops functioning. In other cases, the data is corrupted while being transferred to the printer. Some printer models are naturally prone to this error because of their driver, while others can display this error while printing a specific font. fix printer error 49.4c02
Sep 07, 2010 | HP LaserJet 2430n Printer
HP LaserJet 2430n is not grabbing the paper like it used to
You need to replace either the pickup roller or the separation pad (or, optimally, both at the same time) - both should be removable without tools, they just snap in. You can order new parts at - shouldn't be more than $20 worth of parts. You can help reduce the problem slightly by roughing up the rubber on the pickup roller and the cork on the separation pad by scuffing both with a light grade of sandpaper, just to give it some tooth. But replacing them is best, it'll fix it!
Oct 20, 2009 | HP LaserJet 2430dtn Printer
HP 2430n Service Error 494C02
Hi atrowbridge:
The error code 494c02 is a firmware issue and needs to be updated. You can go to for the latest firmware updates for your printer.
Jan 09, 2009 | HP LaserJet 2430n Printer
Replacing paper pickup roller
on both sides of pickup rollers there are white bushings rotate the white bushings towards you
Remove the left-side bushing by sliding the bushing to the left.
Slide the roller and shaft toward the left until they clear the hole in the right-side bushing, and
then lift the right end of the shaft.
Slide the roller and shaft toward the right and lift the roller and shaft together out of the printer.
install your new roller then reverse this process to reinstall
Oct 21, 2008 | HP LaserJet 2430n Printer
Installer of hp laserjet 1300
dear all
i need install of laser jet 1300 printer urgently
please help me
May 09, 2008 | HP LaserJet 1300 Printer
Free HP LaserJet 1300 Printer Driver
i don't have priter driver for HP Laser Jet 1300 printer, can i download it, how to download it?
Dec 24, 2007 | HP LaserJet 1300 Printer
Laserjet 1010
where do I download a free driver ofHP LaserJet 1010 Printer
Dec 23, 2007 | HP LaserJet 1010 Printer
Hi, It seems you could be having a fuser problem if the line is running vertical all the way down. In that case you would have to replace the fuser to correct the problem!
Nov 30, 2007 | HP LaserJet 2430n Printer
HP LaserJet 2430 Printer Logo
174 people viewed this question
Ben Johnson
