Question about Optoma RD65 65" Rear Projection HDTV
Image/mirror adjustment I posted on the site already but thought I'd send to you directly. The image on my screen isn't centered or flushed with the screen. How do you make adjustments?
  • 979 Answers
Ah, it seems that you might very well have a few voltages off as there aren't many other adjustments that can be made without seriously offsetting quite a few mechanical tolerances. Has the set been dropped or bumped severely? Moved recently? If no to the above questions, you really should verify all power supply specs before doing any "precision bending". Many times, a set that has the symptoms you describe just need work on getting the power supply a "green light" before taking any other action...accordianman
Posted on Jun 25, 2008
What does the HUD button perform?
Your windshield serves as a giant screen, and a projector embedded in the dashboard sends a transparent image onto it. The image leaves the projector and bounces off a series of mirrors, magnifying and flipping the image so that the data comes out right-side up and legible. Press a toggle switch by the dashboard and you can adjust where the display is on your windshield-something accomplished with a rotating mirror.
Some car companies like Mazda project their heads-up data onto a small plastic window that flips up, known as a combiner. This creates a uniform image no matter how the windshield's shaped. It also reduces the number of mirrors needed to send the image onto the windshield clearly. And a lot of aftermarket displays use such a combiner so you can install it in nearly any vehicle you please.
Oct 24, 2017 | Cars & Trucks
My Samsung Led TV Model Code UA40D5500RRXXT is displaying a horizontally split image, with upper half showing an inverted, mirror image of the lower half, and flickering
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 21, 2016 | Samsung Televison & Video
How do I fix double image on Sony led 46"
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in this keyword "Double image, mirror image" in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 04, 2016 | Sony Televison & Video
When put in reverse the image is up side down.
How to Reverse the Image on Backup Camera eHow
After installing a backup camera on your vehicle, you need to reverse the image so that the image on the screen matches that of your rear-view mirror. The orientation must match so that the driver doesn't get confused with two conflicting images. The nature of the camera's technology is that its image will be recorded un-reflected, but the mirror will display a reflected image. Fortunately, the engineers who designed back-up cameras thought of this and created simple controls for you to change the orientation.
Read more :
Jan 12, 2016 | 2011 Lincoln MKX
Scanning is backwards
I just got my scanner yesterday and had the same problem with my FIRST jpg. I looked for a solution and found your posting. I had scanned one page of the instruction booklet from the center fold outwards, not in the direction of the text, but rather sideways across it. That image was mirrored. I did another scan in the 'proper' direction, that is, from the top of the page to the bottom, both as a jpg and a PDF and they came out in a normal, readable form. Perhaps you need to do it a few times if you haven't already? Have you tried calibrating it?
Jun 20, 2013 | PANDIGITAL PANSCN08 Handheld Wand Scanner...
Efforts to print 4x6 borderless print result in only top part of photo paper being used and top third of photo being cut off
First thing to try (and I'm assuming you're attempting to print a photo within HP Image Zone & have already selected the 4x6 photo tray? Hint: can be done via printer, properties, printing shortcuts) is to change the 'more options' directly below where you'd selected the 4x6 image size and then change to 'shrink to fit' vs. the default 'crop to fit'... Additional thoughts includes rotating the image (can be done directly on the preview screen...)
Dec 18, 2010 | HP Photosmart 3310 Printer
Pentax k1000 ....lens will not focus...(one 50mm...other 70-210mm)...happened once before...brought to camera store and of course it focused...nothing wrong...took some pics and worked not...
Try this first.
Set your lens focus to infinity and focus your screen at a far away object (like a distant lampost). If it,s not in focus, then you have a misaligned mirror. Adjust your mirror so that a infinity setting, the split-screen image merge well to form a well focussed image. Hope that helps.
Aug 06, 2009 | Pentax K1000 35mm SLR Camera
My Canon PowerShot A85 no longer shows scene on the LCD screen before shoot nor immediately afterward and records a blank on the memory card. Photos taken before this problem started can be viewed on the...
I called Canon customer service. Problem is likely due to a defective CCD image sensor. The camera is well beyond warantee, but they will fix it free including shipping both ways. No proof of purchase needed.
I can't get the web site pasted in here, but here is a quote of how to contact Canon about this problem.
Canon already had much of my brand loyalty and this promise of a fix just doubled it!
"U.S. residents are kindly directed to contact the Canon Customer Support Center for further assistance at 1-800-828-4040. Support hours are Monday thru Friday - 8:00 AM to 12:00 midnight; and Saturday 10:00 AM to 8:00 PM (all times EST). Alternatively, if electronic support is preferred, please send your email to"
Jun 19, 2009 | Canon PowerShot A85 Digital Camera
Printing mirror image/print
Go to control panel and go to printers or printers and faxes. If you see the printer icon right click on the printer icon and select printing preferences. Under printing preferences click on advance and look for mirror image. Click on mirror image and chage it to off
Oct 29, 2008 | HP Officejet Pro L7680 All-In-One Printer
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
2 Press PIC. FLIP to change the
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
4 Press c/d to select the desired
picture flip setting, and press
5 Press MENU to return to the main
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Optoma RD65 65" Rear Projection HDTV Logo
49 people viewed this question
Top Optoma Televison & Video Experts
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
