Question about Dremel Variable - Speed Multipro Rotary Tool 395
Bad bearing in a model 395
Front bearing is locked up on a model 395. were can I a repair shop?
Threw it in the trash!
Posted on Jun 25, 2008
How to replace rear wheel bearing
I think you can take it to the near car repair shop.
_______________
car keys replacement
Oct 08, 2012 | Lincoln Town Car Cars & Trucks
How do I adjust front wheels one wheel goes way off center
before you change anything, lift the whole front end off the ground and check the wheel bearings and the suspension bushings for slop. you cannot align it if there is slop in the system and those cheap
plastic wheel bearings are usually the culprit. if the bearings are bad, replace both sides and you can buy new front wheels at small engine repair shops, lowes, menards, DIY. if the knuckle bearings are bad, then a sears parts location or a small engine repair shop is the place to be. and from time to time an entire knuckle is bent from where a woman hit something with it.
if there is no slop, then acquire an owners manual from sears, google it, and there will be instructions on how to align. very simple lock nut on a threaded rod type of task. not rocket science.
Jul 27, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Theres a grinding noise coming from the front wheel
pucks not retracting ...worn pads .. or wheel bearings bad...
Apr 18, 2011 | 1999 Yamaha FZS 600 Fazer
Hi. how would i repair a rear axle for a 2006 toyota corolla? i dont have a lift so will i need to take it to an autobody shop? if so how much do these repairs cost usually?
What are going to do to repair the axle? There really is no axle on front drive cars, the wheel assembly is connected to a hub that is mounted to the frame through swing arms. And, you would not take your car to a autobody shop for mechanical work. The cost of repairs depends on what is being done.
Nov 29, 2010 | 2006 Toyota Corolla
Should I be lubricating my dremel (395) tool?
Just a comment-Based on experience, I would go with BOTH their suggestions and order brushes and bearings. That squeal is definitely the bearing; it is a sleeve bearing; RPMs too high for a ball bearing to last and the sleeve bearing has a solid lubricant cast into it.
Dec 16, 2009 | Dremel 395 Variable Speed Multipro Rotary...
Grinding or humming noise from X3
raise the car on that side grab the tire and see if has any( play) moves from side to side considerably.
Oct 03, 2009 | 2004 BMW 3 Series
I have a Marathon Electric 1-1/2hp pool pump motor with a bad front bearing. Is the motor repairable and if so how do I get it apart?
First go to a motor repair shop or Neely Bearing shop and see if they can get a replacement battery, then post a picture of the motor and I will tell you how to repair or replace the bearing. I need to know the frame type, it's located on the motor tag and is it 110 or 220?
Jul 16, 2009 | Kitchen Appliances - Others
Dremel Moto-tool model 395 type 1 lock
You can either go to Dremel.com and type in your model number for replacement parts or call their toll free number at 1-800-437-3635 and get that information. Let me know if you need anything further
Feb 20, 2009 | Dremel Variable - Speed Multipro Rotary...
Front bearing making different than normal noise has front wheel drive
Your bearing is shot, replace it. This is a sealed one-piece bearing and cannot be repaired. You'll need to remove the axle nut, brake caliper and rotor to get it out. You will also need the help of a machine shop to press out and insert the new bearing into the hub. If you take it into a mechanic expect to pay around 300 dollars for the repair. May sound like a lot but for the part and work involved it's not a bad price.
Bearings will usually go out between 70,000+ miles on these vehicles.
Aug 03, 2008 | 2002 Ford Escape
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
181 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
