Question about Panasonic Lumix DMC-LZ7 Digital Camera
Getting to the lens
Thank you so much for the response. I was able to remove the cable and got all the way down to the lens. I cannot figure out how to get to the actual lens. There is sand in there. I took out all the screws, but now I'm not really sure how to get to it to clean it. Any suggestions? No big deal if you can't. I'm just about to buy a new one because I am so frusterated.
I recently disassembled the lens mechanism entirely.
If you do,
1. remember every step so you can reverse the process. Videotape what you do and talk to the camera.
2. the telescope mechanism is a marvel, but a bit of a puzzle if you don't know the positioning and how to assemble it.
3. there is a VERY FRAGILE ribbon cable that goes into the lens to drive the image stabilizer lens. you cannot disconnect it like the other cables on the circuit boards. I broke it trying to reassemble. I don't know if it's possible to put things back in the proper sequence and keep from bending it so many times that it breaks. when it goes, the lens assembly is totally dead.
Posted on Jun 26, 2008
    Novelist:
  • 104 Answers
Well, frustration is something common in this cases, I don`t have the intention to give you more of this but try to be calm cuz it is always possible that the camera will still have problems even after fixing. That camera is not so expensive so think of that and try this out: the lens structure "cannon" is very delicate, a single flase maneuver and you will be out of the game. Place the parts over a soft material, like a soft clean rag or something like that to avoid falling/crashing problems. If you can identify that very very little motor that moves the lenses in and out, separe ir from the structure or just make sure that motor wont be forced while you work. You might not be able to take it out, in that case try moving the gears so they wont be moved.
the structure is sustained by just one or two metallic axis and then you only have a plastic structure tellescope style...
That structure usually stucks for dirt or problems in the structure, yours is obviously the sand... you dont need to disassemble the structure just try to find a little open space or slot and use an AIR SPRAY like "blowing plus" or some like that, you can surely buy it for about 10 dollars or less in a shop, even better if you can get to some sort of air compressor...
Just need to clean the sand by blowing the structure with clean air of some kind. If you insist too much with the lens structure you could brake it so I would not recommend it. It seems you are already tired so better to try cleaning with air, all the structure and the camera also, air wont give more problems.
best luck to you.
Posted on Jun 25, 2008
I have an acer 4088z. My screen comes on but it is totally blank and then goes blank after about 15-20 seconds. Thereis no sound of the fan working at all. I have tried removing the battery and power...
To figure out what is wrong there are only three things that can go wrong from easy to fix to another.
LCD cable and connectionsinverter boardmotherboard
Also remove every single removable components like ram, hardisk, power supply cables, data cables..
ORR
Removing the graphics driver in safe mode might work for you. Just remove it via Device manager. If problem id driver related then also try a system utility tool like Reginout to fix this problem.
May 05, 2012 | Acer Computers & Internet
Tip
Solution for nikon "lens Cover Error"
Nikon Coolpix S5/S6 “LENS COVER ERROR”
In this document I have given a solution to fix the problem most of the Nikon coolpix S5/S6 cameras face. At power –on it give an error “Lens Cover Error”
Before opening the camera I would suggest you to take a snap of each and every step. Because it will helpful while you are fixing the screws back. There are many screws which has to be opened. So better take a photo of each and every step.
IMP NOTE: Remove the battery before opening the camera. Use some antistatic strip to prevent the components from getting damaged Or Keep your feet touched to the floor such that your body remains grounded.
Follow the below steps in the given order:
Step 1> Remove the screws at the bottom of camera
Step 2>Remove the side screws
Step 3> Remove the side screws as given below .
Step 4>Lift the cover and remove the cables which connects the switches to the camera. These cables are fitted in a small connector. There is a tiny lock (present for few connectors)  on the connector, which on pulling it across its hinges, will open and the cable comes out easily. You need not pull it forcefully.
Step 5> Remove the screw as shown below
Step 6> Lift the screen as shown below.
Step 7> Remove the cables and screws as shown below.
Step 8> Lift the screen panel as given below.
Step 9>
Remove cables as shown below.
Step 10>
Remove the cables as given below.
Step 11> Remove cables.
Step 12> Remove cables
Step 13> Remove the 4 wires using a soldering iron.
Step 14>
Step 15> Removing at this stage is a bit difficult. You will have to open it cleverly. Lift it from the side as shown below.
Step 16>
Step 17>Below figure shows the lens cover and the stepper motor which controls the lens civer.
Step 18> To remove the stepper motor remove the screws as given below.
Step 19> Below figure shows the stepper motor used for lens cover
Step 20> Below figure shows the stepper motor which is used to control the lens cover. There is a small white switch on this motor. This Switch is used by the camera to detect whether the camera lens cover has is open or closed. When we switch on the camera the lens cover (which is shown in step 17) opens and in turn it presses the white switch show below. If the lens cover is unable to press this switch, then the error “Lens cover Error” flashes on the camera.
I would suggest 3 different ways to solve this problem.
1>     Fix some glue on the white switch shown in the below figure, such that it remains pressed forever. Because of this, camera will never give the error message. Remove the lens cover (which is shown in step 17) forever. You don’t  need it anymore. Now fix the below stepper motor back in the camera and follow the steps in the reverse order to fix the camera components.
2>     Buy a new stepper motor from the market. Its quite cheap. Fix it back in the camera. Here you need not remove the lens cover. Follow the steps in the reverse order to fix the camera.
3>     In this method you can open the stepper motor to fix the problem. Now follow the steps given below.
Step 21>
Remove the screws as shown below.
Step 22> Remove the gears one-by-one. See the placements because you have place them again in the right order.
Step 23>
Step 24> The gear shown below is the culprit. Remove it. There is a tension spring present inside this gear. Do remember the position of this gear before removing this gear. Its placement is very important.
Step 25> The spring is shown below.
Step 26> Now the switch shown in step 20 does not get pressed because of reduced tension of the spring. Increase the tension of this spring by pulling it in opposite direction. Place the spring back in the gear and follow the steps in the reverse order to solve the problem. Now because of increased tension of the spring, the lens cover will be able to Press the switch shown in fig 20.
Happy debugging
Mukesh
on Mar 25, 2009 | Nikon COOLPIX S6 Digital Camera
I'm trying to turn on my Canon Powershot A1100IS and it's saying " Lens error, restart camera". I've tried doing it and I keep getting the same response. I had dropped it this past...
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Jul 07, 2011 | Canon PowerShot A1100 IS Digital Camera
Getting a message that says "lens error." the
Hello
Regards
Andrea
Apr 24, 2011 | Nikon COOLPIX S200 Digital Camera
Lens error.....restart camera. Tried over and over again. Nothing works. HELP!
Went to the beach yesterday, by the end of the night my camera gave me this error: "lens error, restart camera". The lens would no longer come out.
I figured sand got stuck within the lens, so I did the following:
1. Turn camera up-side-down (with lens facing down)
2. Gently tap the sides of the camera (to loosen particles in lens)
3. Turn camera on
4. The lens will eventually come out
5. Gently tap the sides of the lens
6. Turn camera off (continue tapping side of lens as it retracts)
I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
Now the camera works...thank god....
thanks.
Apr 11, 2011 | Canon PowerShot SX10 IS Digital Camera
I am getting a "lens
Hello
Regards
Andrea
Mar 20, 2011 | Kodak EasyShare V550 Digital Camera
Getting a response that says E18
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Sep 12, 2010 | Canon PowerShot A95 Digital Camera
How to replace headlight lens 1995 Ford Taurus ?
there are only 3 nylon u-shaped clips holding the headlamp assembly in
Jan 22, 2010 | 1995 Ford Taurus
BMW CD Changer MP3 player is connected to power and i-bus in e39 (1999 BMW 528i). When I press the button on the display monitor to toggle between Tape and CD, most of the time the CD does not show up (it...
in the unit there are two things that you will have to check
1) one is the lens which reads the cd in the unit.
2) second is the gear that moves up and down to the tape/cd.
if the lens is not getting adjusted after you turn it on/off then this problem happens also if the gear is not moving properly then also same problem occurs.if the gears are getting blocked then also this happens.as you mentioned it works that means the unit is not faulty but there is minor problem in lens or gear assembly just get it resetted by checking it.also local electronic repair shop can realign the unit.the unit need proper servicing to get it work properly.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 31, 2009 | Car Audio & Video
Lens Error, Restart
That Was So helpfull i thought i had to buy a new camera until i tried that thank you so much
Oct 26, 2007 | Canon PowerShot A540 Digital Camera
Panasonic Lumix DMC-LZ7 Digital Camera Logo
135 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
