Question about GE JGBP28 Gas Kitchen Range
My oven wont heat up.
I have a newer ge model gas range and its work fine all this time.. until suddenly the other day when we went to use the oven it didn't do anything. I set the digital pad to bake at 350 and it works its way to 100 and then starts beeping like its ready. but when i opened the oven door there was no heat there.. so i tried setting the broiler at Hi to see if that would spark.. but nothing. And its weird cause all the top burners are working fine. can you please help.. im fed up trying to find dinners i can do in the foreman!
    Sergeant:
  • 409 Answers
Can you tell me the model # off the stove. sounds like you may have to replacet the TOD or the heat probe.
Posted on Sep 13, 2008
Oven wont work everything else is fine
As your oven is electric there is a heating element in the oven, have a look in the oven to find it and check the little plug in caps on the end to make sure they are not loose. If they,re ok check the switch on the front panel sometimes the knob comes loose on the spindle if that's all ok it may be the switch has failed. Good luck.
Jun 16, 2014 | GE Profile JGSP44 Dual Fuel (Electric and...
Xl44 GE GAS RANGE OVEN WONT WORK, RED LIGHT IN
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
czvb
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge profile (model #: JGBP90MEB3BC) oven won't heat up. Stove top and broiler work fine.
This is a gas range isn't it? We can help you get this oven heating up again. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST and we will get the correct parts out to you to get you cooking again asap!
We look forward to working with you. Thanks, Ella
Dec 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
My GE Spectra gas oven worked fine last night. Today, the oven will not heat. The broiler and the burners work fine, as does the clean feature. But nothing when the oven is turned on.
Are you sure the cleaning process works, because usually when the oven wont work, the clean process wont work. If you are correct, then the problem is most likely the control panel not responding to the bake setting. This will require either a new touch panel or a new control circuit board.
Oct 11, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Oven not heating up to temp. Sometimes get small explosion inside when starting. Sometimes small slight gas when lighting. Top burners work fine. Model GE JGBP26GEJAWH
heatman101
gk
Aug 13, 2009 | GE JGBP26 Gas Kitchen Range
Oven does not heat. Broiler and stove work. NO gas smell.
could be the oven thermostat, get a plumber/heating engineer out, but make sure you can trust him, cause he could try and say u need a new cooker when it MIGHT only be a new oven thermostat.
Feb 02, 2009 | GE Ovens
GE JGBP28 Gas Kitchen Range Logo
156 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
