Brother mfc-8860dn, unable to reset maintenance message, after fitting new rollers
  • Anonymous Apr 30, 2009
    how to reset PF kit1
  • 3 Answers
TURN THE PRINTER OFF PRESS AND HOLD THE MENU BOTTUM AND TURN ON /KEEP PRESSING UNTIL YOU SEE MAINTENANCE
THEN YOU PRESS 82 FOR DRUM OR 88 FOR THE FUSER OR THE KIT.IT FIX YOUR PROBLEM.
SORRY ABOUT MY ENGLISH.
Posted on Jul 14, 2008
Same problem to me, unable to reset maintenance message,
Posted on Jan 19, 2010
Shows print unable 4 f
How to Clear the "Unable to Print" Message from the Brother ...
? 1:48
https://www.youtube.com/watch?v=BxbJbXf1u9w
Aug 2, 2013 - Uploaded by Brother Office
For use with models: MFCJ4310DW, MFCJ4410DW, MFC4510DW, ... How to Clear the "Unable to Print ...
Brother Printer DCP-195C Message reads - print unable 4f ...
www.justanswer.com > Printers
Question - Brother Printer DCP-195C Message reads - print unable 4f see - 7B. Find the ... 00:00 00:01 OK (the display is showing this message) - now push the ...
Brother MFC 5860CN - Error Print Unable 4F User manual
Dec 28, 2015 | Office Equipment & Supplies
Showing my 7220 Brother printer gives me the message "Unable to print, See troubleshooting and general maintenance in User's Guide" please help me
You need to pres Menu-Start-Up Arrow 4 times in less than 2 Seconds !!! and you will be in Maintenance mode. LEDs will be flashing. Press the Up Arrow and numbers will change and press OK after the one you want to select. The number sequence is the following. 8-0 2-8-6-4 4-4-6-0 7-7 9-9
Oct 27, 2014 | Brother MFC 7225n - Multifunction fax /...
The printer wont printer and displays "Unable to Print. See Troubleshooting and Routine Maintenance Chapter in Users Manual"
Unplug the printer for about 15seconds and then plug back in and power up.......this should reset the error code! Test print and you should be good to go!
Oct 05, 2014 | Brother Mfc9420cn Mfc-9420cn Fax Modem...
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Office Equipment & Supplies
I have a Change Unable 51 Error Message on my Brother MFC-260c MFC and it says to refer to User's Guide, how4ever there is no error code to match this in the guide. HELP!
hi karn..you need to disasemble your printer and clean your Maintenance unit....the coz of this error 51 is usually you are using competetor ink and then you have reset the counter (error 46) ,after you reset it, you need to change ink absorber if not it will bank those waste ink in the ink absorber and after it is full the waste ink have no place to store and it will jam the mantenance unit and the worse case it the ink maybe spoil other part of the printer go and find engineer  asap if not you need to replace new unit....
Mar 09, 2009 | Brother IntelliFax 1860C Plain Paper...
My Brother MFC-235C shows print unable 32 read user manual but I dont have a manual
The message "Print Unable 32" or "Machine Error 32" will appear on the LCD display if paper or labels are stuck inside the printer or drum unit.
This will also appear if there is either a mechanical issue or just a problem with a sensor possibly software.
1) The way to resolve this issue is to make sure there is no paper in between the rollers or on top of the print heads (if applicable).
2) If there is no paper the you will need to hard reset the printer which will restore to manufacuter settings and reset software.
Hold down the Menu botton while plugging in the power cable. The display should read "Maintenance." let go of the menu button and then punch in 91. The display should read "Param Init." The unit will beep once. Then type 99. The unit will exit maintenance mode.
This only works for maybe 30% of the time.
3) If this does not work then : Refer to Manufacturer or return the item.
IF PRINTER DOES NOT HAVE A MENU BUTTON:
1)Turn the printer power switch OFF. Check that the front cover is closed.
2)Turn the printer power switch ON while holding down the GO button until the Toner, Drum and Paper LEDS are lit.
3)Release the GO button. All LEDs will be off.
4)Press the GO button 8 times. The Ready LED will flash briefly while the printer is reset. After the printer is reset the READY LED will be lit.
Feb 19, 2009 | Office Equipment & Supplies
Brother MFC 8860DN Toner End Life Error
Open the door where the toner goes. Press the 'back' button. Press *00. Do not respond to the query about the drum. Close the door. Other models may have to press the 'Options' button located near 'Copy'. This should work.
Jul 08, 2008 | Office Equipment & Supplies
Instrution book for 8860 DN
I have a Brother MFC 8860DN Network Fax machine and I need to program some phone numbers on it for automatic fax. I don't have the book to follow the steps to program it.
Nov 21, 2007 | Brother Office Equipment & Supplies
3,299 people viewed this question
k24674
