Question about Maytag Washing Machines
Maytag neptune washer keeps shutting off and the display "Lr" is what shows on the time left for cycle.
    Genius:
  • 1,847 Answers
It seem to be issue with the timer or the water senser. may i have the model #.
Posted on Jun 24, 2008
  • Legin Varghese
    Legin Varghese Jun 24, 2008
    Lr is the error for a locked rotor. The machine is trying to run the motor but is unable. Usually this the motor control board that is at fault. The first thing to do is make sure the belt is on. After that some tests are have to be made to determine what is going on. Im going to lay out some instructions in case you want to get into this thing. You will have to remove the door by removing the screws holding the hinges on. Same thing for the spacers on the other side. Lift up and remove the door. Pull the front panel forward and lift off. Once the panel is off, set the door back on and close it. Unplug the washer. On the motor control board, bottom right, pull the JP4 harness connector from the board. Plug the washer back in and make sure the door is closed. Press delicates and heavy soil 3 seconds to activate the service mode. Now press the rinse key. Make sure the door is locked by pressing the max extract key. Now press the stain cycle to start motor control test. The motor should run rotating the drum at 50rpms. If the motor doesn't run, check for voltage at the 3 wire harness, MN4, should be 120V. If you don't have the voltage, problem is in the main board. If you have that voltage, then the problem lies either in the motor control, or motor itslelf. On the motor harness, 7 pin connector on the board (middle). Between the brown, white and black wires should all read 6 to 7.5 ohms. Between the 2 grays 150 to 195 ohms. If that checks, then it's the board. If it doesn't check, it's the motor. Ohm checks should be done with the power off.
Washer wont finish cycle and display reads "LR"
Hello todd.... This is a common problem with the neptune. It means that the machine needs a new motor and a new motor control board kit. If you are under warranty do a repair. If not, get an estimate before you go ahead and repair it. Joe
Thanks for choosing Fixya!
Feb 18, 2011 | Maytag Neptune MAH5500B Front Load Washer
The washer will not complete the wash cycle. Lr
http://www.servicematters.com/maytag_library/docs/TDL-0044B-B.pdf
If all else fails, replace motor control board, and/or motor.
Jul 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
Keep getting Lr halts with even the lightest loads. Takes hours to do one load restarting, adjusting, restarting.
This is a common issue with earlier Maytag Neptune Front Load Washers due to a momentary loss of motor control neutral feed from the power cord and result to the shutting down of the washer in the middle of the cycle. The neutral feed line needs to be checked for poor connection. Check the tip I posted regarding this problem and how to address it.
May 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
Lr shows during spin cycle and pauses washer
you need to replace the motor and the motor control board,it comes in a kit,call your parts store give them the model number and the first two on the serial.common problem with the neptune,the wire harness that plugs into the motor is strait down,moisture runs down the harness and gets into the connectors,it's around 200 bucks for the kit
Feb 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
Neptune - has Lr displayed where time remaining for wash usually displays. Doesn't finish.
Hello there
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Burn Spot on a Maytag Neptune Washer Motor Control Board (click to enlarge)
Blown Fuse on a Maytag Neptune Washer Motor Control Board (click to enlarge) Either way, it means just one thang: a new motor and motor control board kit are in your future.
Dec 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
My washer shows Lr sign on the pad.what does that
that is a locked roter sometimes caused by sudsin unit
Aug 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front load has Lr on Time display
Im having the same problem what is the lr code and how do you get rid of it?
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
LR == locked rotor, which translates to a bad motor and motor control board( usually depending on age sold a 1 set. Neptune repair kit. retails for about $200 part number 12002039
Oct 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Neptune mah5500bww
I've had the same problem with a Neptune MAH3000. I replaced the mother board to no avail. I replaced the timer control to no avail. I then replaced the door lock assembly (wax motor, door switch, etc.) and problem solved. Luckily, I had another machine that I could rob parts from.
Nov 02, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
