Question about Cuisinart DGB-500 Coffee Maker
My coffeemaker is less than two years old and a friend advised me to contact Cuisinart online about my problem, it will no longer grind up the beans can I order a new blade set and how long should they last?
  • 8,596 Answers
The DGB-550BK is better
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
What is stripping the young leaves on my runner beans
This is a problem with your Cuisinart Grind & Brew Coffeemaker? This product uses roasted whole bean coffee. Why in the world would coffee beans have leaves attached? Makes no sense.
Jun 16, 2014 | Cuisinart Thermal DGB-600 Grinder
Our DGB-700 has stopped grinding the beans. The motor sounds very weak. I have taken it apart and cleaned thoroughly with no good results. Can it be repaired or is it just time to "move on"...
I use Capresso CoffeeTeam model #454 10 cup 50 oz digital coffeemaker burr grinder combination with four grind settings. Now it is more than 5 years old, works every single day without any problem. Capresso has the great customer support. Its price for the refurbished item is compatible with the price of your Cuisinart. I am not sure it is the solution for you but I am very happy with my coffeemaker.
Jan 04, 2011 | Cuisinart Grind Brew DGB700 12Cup Coffee...
We have a Cuisinart DGB-900 BC Grind and Brew Thermal Coffeemaker. Our Problem is that the bean grinder has stopped working. We purchased the coffee maker on 2/25/10. Prior to this happening, we were...
try cleaning the grind chute again. if problem persists:
this is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
Aug 30, 2010 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Cuisinart DGB-700BC grinds but no grounds in the basket.
Hi there, you have some kind of blockage, If the beans are going down, you need to remove the brewer unit and wash it, if the beans arent going down the exit of the grinder is blocked and needs to be removed, cleaned and replaced
Jul 26, 2009 | Cuisinart DCC-1200 Coffee Maker
Condensation- Cuisinart coffeemaker DGB-300
The condensation is normal, not just with this Cuisinart Grind n Brew, but with ALL Cuisinart Grind n Brews - because of this, you will really need to clean it after every use if you want the grinder portion to last long. As far as the bean amt - Cuisinart bases it's reccomendations on a smaller-than-normal coffee cup size of 5 ozs or so. Plus, the condensation, as you mentioned, will prevent a certain portion of the grinds from flowing to the brew/filter basket. Add more beans or less water to make a stronger cup.
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 16, 2009 | Cuisinart DGB-300 Coffee Maker
Our cuisinart grind and brew,,dcc590pc does not brew, we have to keep in setting , it is one year old and makes great coffee.. it also leaks, but we keep it in a 9X 13 loaf pan just in case.. i have run...
You should contact Cuisinart's Customer Service as they really stand behind their products and should be able to help you with getting a machine that works correctly.
I've been very impressed with how fast they work to resolve issues with faulty units and they are very prompt in getting back to you with an answer. Give them a call at 1-800-726-0190
Here's a link to their website for contact info, just select United States or International and give them a call or fill out the online web form. It's a good idea to have your model and serial
number available when you call.
Rather than go into what you could do, since your coffee maker is about 1 year old, I think you'll discover that it's still covered under their warranty.
Hope you find this info helpful and best regards!
http://www.cuisinart.com/support/contact.html
Feb 26, 2009 | Cuisinart Coffeemakers
Beeping only, and the coffeemaker won't brew at all
Check first that both filters (the water filter and the grounds filter) are in place correctly. Also check that the white tab in the grind cover moves freely when the lid is closed. (You can use a fork tine to test.) If that doesn't solve your beeping issue, contact http://www.cuisinart.com/support/us.html or 1-800-726-0190. I did and they are sending me a new unit at no charge.
Sep 30, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Machine shuts off after beans are ground & sometimes when pot is 1/4 full
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. Serial number is engraved onto the very bottom of the coffee maker - hard to read. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
-Tha Mp3 Doctor
PS: The DGB-550BK is better
Jul 17, 2007 | Cuisinart DGB-500 Coffee Maker
Cuisinart DGB-500 Coffee Maker Logo
345 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
