My Canon MPC200 is printing in blue only. I've installed a new printhead to no avail. What can I do?
Go to www.fixmein.com and i wil tryu to help u
Posted on Jun 24, 2008
Printhead pixma ip 1000
wipe out print head connection point with arosel and instal head again
Dec 28, 2013 | Canon PIXMA iP1600 Printer
Error code e02826 after installing new printhead
Reset the print head. While out clean terminals with damp cotton wool. Should start after that if not probably faulty printhead,
Sep 28, 2012 | Canon imagePROGRAF W6400 InkJet Printer
I can't print with the black ink. I performed a print head cleaning, and then I printed the nozzle check pattern. I noticed that the Cyan, Magenta, and Yellow shows up. However, the black checkered...
Simple problem that print head cleaning will typically not fix. The black ink is pigment based so it tends to form more stubborn clogs. Just remove the print head and if you have a steamer hit the black printhead nozzles with some pressured steam. If not available, soak the surface of the printhead in shallow hot water (try not to get the contact wet or be sure to dry them if you do). You can tell if the printhead nozzles are open by folding a section of wet paper towel like 5-10 layers and then soak it, press the printhead surface up and down lightly on the wet paper towel and if the nozzles are open you will see some ink pulse in the black port screen (the colors will also pulse from the pressure of the liquid under the printhead). It's easier than it sounds so give it a try. I've saved 100s of Canon printheads this way.
Note: if you have a really dried out head, you sometimes have to soak from the top inlet ports and the bottom nozzle surface to clear, but unlikely in you case since you had a black cartridge installed with ink in it (this keeps the top port from drying).
Sep 15, 2011 | Canon MP520 All-In-One InkJet Photo...
Black 3e won't print, even with NEW printhead.
Hello!
Please check the "Rplacing an ink tank" part of the manual. Hope it will help you.
https://manualsbrain.com/en/manuals/1796179/?page=45
Oct 24, 2017 | Canon PIXMA MP780 All-In-One InkJet...
I have a canon i960 printer. It won't print blue. All other colors work fine. I've replaced the ink, downloaded new drivers, run the clean print head utilities, both regular and deep cleaning. What do...
I would guess that the printhead is bad. Google cleaning printheads or get a new one. Sometimes , not always you can clean the printhead instead of replacing. (take out and clean by hand)
Apr 07, 2010 | Canon I960 InkJet Photo Printer
Error: print head not installed. Install print head
Make sure the contacts on the carriage assy. where the printhead sits are clean also. If your printer is still under warranty it will be repaired free of charge, if not, it sounds like you may need a new printhead. The part number for the printhead is printed on one side, it's always a qy6- number followed by 2 sets of 3 numbers each.
Jun 22, 2009 | Canon PIXMA MP610 InkJet Printer
Canon pixma ip3000inkjet printer
The printhead is clogged.
See the following guide:
Canon iP3000/4000/5000 Printhead Cleaning Guide
If it does not work, replace the printhead: Genuine Canon Print Heads
Nov 25, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
New printhead will only print 3eBK, no color
If you're concerned with a clogged printhead try to clean it with acetone solution. Also, check the cable connections to your printerheads they might be loosened..
Feb 23, 2008 | Canon i860 InkJet Photo Printer
50 people viewed this question
k24674
jasbo
jasbo
