Question about Panasonic SD-YD250 Bread Maker
Panasonic SDBT56N
Missing mixing paddle
    Novelist:
  • 161 Answers
Go to e bay. They have a couple of stores that sell nothing but parts for bread machines.
Posted on Jul 03, 2008
Mixing paddles come off during mixing, am using teflon tape on shaft to hold paddles on, what is a better fix?
Sound like you need new shafts or paddles and I know the paddles can cost $30 each. so think about a new model or buy one at a thrift store and try those paddle or use the machine. I got a great one for $10 . :)
Jul 30, 2017 | Black & Decker B2300 Bread Machine
I bought the bread maker last night and it doesn't seem to mix the dough. I have spots of flour and salt in the dough. It seems like there is a paddle or something that is missing. Do you know if I am...
There is supposed to be a removable small paddle in bottom of pan.
If it's not there, you will not get dough at all. Just wet flour.
If paddle is there, but you have half way dough.. AND you followed directions exactly, machine has a problem. Take it back for refund or exchange.
Nov 17, 2010 | Oster 5838 ExpressBake Bread Maker
Mixing paddle missing paddle was left in bread and thrown away by mistake
Go check on ebay with seller named: the_cub_fan
They seem to have a large variety from many makes and models.
Dec 03, 2009 | Kitchen Appliances - Others
Panasonic SD-250 not mixing. Pan was submerged in water.
Hello LT,
There is a sealed bearing and shaft on the bottom of the bread pan that the paddle sits on. Submerging the whole pan in water may have caused water to seep into the bearing on the bottom of the pan, or the whole pan might be worn. Slight resistant in 2 places on 360 degree is not bad. Let everything dry out and we will try a few things. First, put the paddle in the empty pan and place it in the machine. Start a kneading cycle and look trough the lid to see if the paddle is spinning freely and with smooth motion 360 degrees. Watch it until you are sure it will run freely for the entire cycle. If it does not run freely, stop the machine and take the pan out. Now start the kneading cycle again with the pan out and look at the motor shaft at the bottom of the machine to see it it is running freely. If it is running freely, then the problem is with the pan, and the pan needs replacement. If the motor shaft is not turning freely, then the belt is slipping in the machine and needs to be replaced. If everything runs smoothly check the kneading time to make sure your mix has enough time to knead correctly. Hank
Nov 14, 2009 | Panasonic Kitchen Appliances - Others
Panasonic SD253 breadmaker manual
http://support.panasonic.co.nz/manuals.asp
Mar 23, 2009 | Panasonic SD-YD250 Bread Maker
The paddle will not stay on the shaft while mixing dough.
Probably the paddle and shaft are worn. Both are replaceable. Buy a new Paddle and a Kneader mounting shaft unit (Part No. ADA 29A115)
Panasonic Parts
National Parts Center at 800-332-5368 between the hours of 9:00 a.m. and 8:00 p.m. EST Monday through Friday.
Nov 16, 2008 | Panasonic SD-YD250 Bread Maker
Breadman Ultimate - finding a part
http://www.nelsonappliance.com/BreadMan+Mixing+Paddles+for+Bread+Maker+(20145).html
Look up the link and order.
Mar 06, 2008 | Breadman TR2200C Ultimate Bread Maker
Bread not rising enough
We had exactly the same problem. We contacted Panasonic who supplied bogus "advice" about changing the type of flour and using more water. We eventually discovered the reason for the problems: the mixing paddle was now a loose fit to the spindle. Part way through the baking process it would stick. We also have a solution. You jam tin foil in the gap between the spindle and the paddle, it works a treat. Don't waste you money on a new paddle, this won't be a tight enough fit.
Oct 24, 2007 | Kitchen Appliances - Others
Panasonic SD-YD250 Bread Maker Logo
87 people viewed this question
Top Panasonic Kitchen Appliances - Others Experts
Irene Tulloch
Oloyede Monsuru
Are you a Panasonic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
