Question about Onkyo TX-SR503 Receiver
Won't turn on
When i plug it in the standby light comes on, when i press power u hear a click but no power. Can u help me
    Problem Solver:
Inside there is probably a dirty and/or broken relay.
Posted on Aug 07, 2008
42HDS69 On off switch won't work sometimes
The clicks are coming from a mechanical relay in the standby supply for voltage---the standby power supply runs 7/24 if set is plugged into power.
What I would do if you are able is open set and on power board (power cord goes to it) look for and replace any filter caps that are puffed up there--the relay is possible but rarely bad in this way unless a solder connection under it is bad.
If caps are good you have a connection or bad part near the relay that likely is causing this problem.
Look closely at filter caps in power supply:
even one that is slightly puffed up can cause this, if find that and need to know what and how let me know.
Dec 19, 2012 | Hitachi Televison & Video
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
Could be an open internal fuse or power supply failure
Jan 05, 2018 | LG 42CS560 42 Class LCD HDTV
SONY BRAVIA KDL-46S2000 NOT TURNING ON
Look for loose contacts in power outlet. Try the TV on some other power outlet. There could also be a problem with the power cord.
Aug 05, 2012 | Televison & Video
Tv won't turn on- its in standby mode. the young lad had the remote before it was turned on.... could he have pressed somethin on the remote which is now preventing it from coming on?
Powering up do you hear the relay click then you may see the display flash (not necessarily), but then the TV clicks back into standby mode. If so there is a component failure.
will need diagnosis by a repair shop. Too many different components it could be for me to guess. but
the common repair kit containes1 fuse (F302), 1 diode (D304), the power resistors (R927 and R929 for the board revisions with these two resistors) and the IC301 voltage regulator IC.
Feb 21, 2018 | LG 50PJ350 50 in HD-Ready TV
Hi I just moved plugged in my ps3 the red standby light came on and now nothing it won't even try to turn on what should I do ?
Sorry I had no idea you sent me this message until today. I apologize for the delay. You probably found a solution by now but if you haven't, please try this..
Solution:
  1. With the PS3 in Standby mode (Red light on), press and hold the Start button until you hear a single beep, followed by double beeps.
  2. Connect the controller using USB cable and press the PS button on the controller.
  3. Now, the system restore screen (or whatever they call it) will come up like this
  4. You have several options here for restoring the system, some will unfortunately wipe up all your data, others will make you lose the file naming.
I hope this helps :D
Oct 24, 2011 | Sony Playstation 3 (PS3) Console
I have a RCA DVD Home theater system and I plug it in and the blue standby light comes on, but when I push it or other buttons on the unit, it just powers off and then won't turn turn back on at all....
I am having the same problem...i plug it in the standby light xomes on but i press the power button and nothing happens...mine is a rca rtd315wr model
Sep 03, 2011 | RCA RT2360 System
My 40' vivo tv has turned off and won't turn back on but the red stand by light is on??
If the standby light is on and it does not respond, it is most likely to be a problem with the power supply . First try this, unplug and leave the set like that for a few hours. Then plug it back in to see if the tv attempts to turn on when you try to power it up. See if you hear a "click" even if it goes back to standby. Let me know what you found so that I can help you test the power supply board to confirm, if necessary.
Aug 18, 2011 | Televison & Video
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
I press the power button and hear the click but no picture appear
Unplug the TV Remove the cover wait until the TV cools then plug in, turn on and, it should come on... if it does; purchase a computer fan to cool the chassis of the TV wire it into the 12 volt side of the power supply and, install the cover
Aug 02, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV, i plug it in, turn it on, no image, "on timer" light comes on.
If you dont hear a click theres a problem in the standby power supply. if you do hear a click theres a problem in the Main power supply or sweep supply. Get a good tech to look at this for you if your not a tech. Good Luck
Aug 07, 2006 | JVC AV-27D302 27" TV
Onkyo TX-SR503 Receiver Logo
196 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
