Question about Oreck XL Ultra Bagged Upright Vacuum
Oreck XL Classic
The belt is on properly, however the brush will spin, then stop.
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=703827
Oreck XL Classic
posted by balis on Jun 24, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Classic. It sounds like the belt may be stretched out and my needs replacing. The average belt change is every 4 to 6 months and to store the extra belts in a Ziploc bag in the refrigerator. Also check the brushroll, the gray bearing ends with say on either side the words NEW or OLD and both ends need to be identical – new/new and old/old NOT new/old, if the belt and the brushroll are OK then it may be the motor but I don’t think so. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 25, 2008
The roller brush on my Oreck XL Classic has only center bristles. Both sides have been worn down to nothing. It is hard to push.Why are the bristles wearing down?
Sounds as if the wheels are collapsed on one side and the brush is harder in contact on one side. In correct alignment the brush should just kiss the top of the carpet causing the bristles to flex a little.
Oreck will fix it for you under warranty;
http://www.oreck.com/oreck-xl-classic-limited-edition-bagged-vacuum/UK2200.html
The XL® Classic Limited Edition is confidently by Oreck®'s warranty and 9-point free service tune-up inspection plan to ensure optimal performance for years to come.
Returns information is here
Returns
Oct 30, 2016 | Oreck Vacuums
The brushes are not spinning
It sounds to me that the drive belt to the brush is broken. To verify, or replace, you must take off the bottom cover.
Jan 14, 2013 | Oreck XL® Classic Bagged Upright Vacuum
Oreck roller brush problem
The belt is just stretched. Replace it with one from a vacuum store not a discount store they ARE different. It can happen easily. That's the only thing it could be.
Good Luck!
The Vac Dr.
The Belt:
http://www.vacuummedic.com/product.php?id=257
More info on belts:
http://www.vacuummedic.com/blog/2012/10/09/my-brand-new-vacuum-doesnt-work/
Oct 16, 2012 | Oreck XL Ultra Bagged Upright Vacuum
Hi, I have a 1 year old XL Pro Plus Upright. Motor works fine, brushes are turning but it will not create any vacuum. we made sure thenew bag is connected properly and still no suction. Any advise? Thanks,...
The belt that turns the brush bar is probably stretched and worn. Once this happens, you will lose suction. When they get worn they stretch, thus causing it to spin on the bar itself.Just simply replace the belt with a new one that fits your machine.
Good Luck!
Jim
Jul 28, 2011 | Oreck XL Pro 18T Upright Vacuum
Oreck xl commercial spits out dust on bare floor but work on carpet. It is about 15 years old. Bag has been changed. Brushes are spinning so belt is working. Started about 2 weeks ago. HELP!
It might be that the beater brush is spinning when you tip it up to look at it but slight pressure of it contacting the floor is enough to stop it. If it were my machine I would remove the beater brush and clean it as best I could, paying particular attention to the end pieces on the brush that hold it in place. A little WD40 between the end pieces and some twisting to be sure it worked in well. I would then reassemble with a new belt being sure it is on correctly so it turns the brush in the proper direction.
That is about the least expensive thing(s) you can do at this point before going further. I have one more potential cause, but it is best to check these first.
Please let me know how you make out.
Oct 06, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Roller on upright vacuum is not spinning so vacuum is not picking up dirt
Any time that a vacuum's roller brush stops spinning, this means that your belt has either stretched so much that it's fallen off of the motor, or that your belt has broken.
Here's a very helpful video on how you can replace the belt on your Oreck. This will give you step by step instructions on the belt change.
If you need to purchase a new belt, here's a direct link to a 3 pk. of belts that are used on your Oreck XL upright on our website:
http://www.govacuum.com/oreck117.html
I hope that this video repair was helpful to you! Please be sure to rate my repair helpful by clicking the thumbs up icons in the top of this repair page.
Thank you,
Chris J.
GoVacuum
Apr 05, 2010 | Oreck XL2200 Bagged Upright Vacuum
My oreck vacuum has stopped sucking up things.
It won't turn the brush because the belt is stretched or broke from the heat of sucking something too big up. If you have your service manual it should show you the location of the belt covers to replace it.
Dec 03, 2009 | Montgomery Ward Oreck XL Celoc...
While vacuuming it's unusually hard to push.
I see your post is from May. I just joined Fixya this month so, id you're still looking for a solution, I would saythe belt broken or is so stretched the roller isn't spinning. Here is an link to an online guide with illustrations for changing belt. Also check the roller brushes for wear and change if necessary. Hope this helps.
http://www.info-vacuum-cleaner.com/oreck-vac-belt.php
May 02, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL Ultra Bagged Upright Vacuum Logo
290 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
