Question about Garmin zumo 550 GPS Receiver
Zumo 550 Shut Downs
When I try to enter an address into my Zumo 550, I get through the province and the city OK. Then it asks for the street number which I enter but as soon as I touch "Done" the unit shuts off. It seems to be doing this with all numerical addresses. The problem occurs either mounted on my motorcycle, mounted in the car or running on its own battery.
I noticed the problem yesterday and again today. I thought a software update might solve the problem so I that but the problem is still there.
The unit is still under warranty.
  • 1 more comment
  • kurre007 Jun 29, 2008
    i have just the same problem, everything goes well untill i put it the number, and "say" done , the unit shuts down
  • mhonn2002 Jul 01, 2008
    I have the same problem. Enter house number and when I press done the street screen comes on for a very short time and then the unit shuts down. I tried to reload the 2009 maps, I deleted the 2009 folser from my computer and the tried a reload. Still have the same problem.
  • fishman6002 Aug 02, 2008
    exact same issue, still trying to find fix
I am having the same problem, I can not figure out how to fix it. I checked the maps and I only have the Maps 2008 checked. If it is off then I can't get any directions. Help please as I really don't want to go through the hassle of sending back to Garmin.
Posted on Aug 02, 2008
I went to tools (the little wrench), pressed Map and then Map Info, as stated in the other solution. It should 2 maps as I have a card in. I simply removed the checkmark from the one I wasn't using and it resolved the problem. If you use a secondary map on a card, give this a shot.
The problem is with maps overlaying. If you go to the little spanner and then press Map and press Map Info you should only see one Map info. If you have more than one then you need to connect to a computer and go to the Garmin drive. Remove the additional map this will be called suppmap1. Just move it for the time being to you computer just in case you need to put it back.
Another way to check is to press and hold the Volume key on the left whilst powering up. This bring all the info for the unit. Press Next then More on the screen the map name is the 6th one down.
Whatever Garmin tells you to do will not work. I sent mine back and they replaced it within 5 days. Service on that score is excellent.
Posted on Jul 02, 2008
Postal codes in ottawa
Go to website:
http://www.canadapost.ca/cpo/mc/personal/postalcode/fpc.jsf
and enter full street address (complete with unit number if appropriate), city and province.
Dec 14, 2014 | Computers & Internet
How do I find a postal code in Vernon,BC.the address is 627-175 westside rd
Go to website:
The closest I can find for this address is at the Kelowna end of the road:
175 WESTSIDE RD N
KELOWNA BC V1Z 3S6
Dec 13, 2014 | Computers & Internet
What is the postal code for wetaskiwin ab
Need more information to answer this.
Go to website:
and enter full street address (including unit number if appropriate), city, and province
May 15, 2014 | Computers & Internet
Want Thunder Bay Ontario Postal Codes?
Go to website:
Trying to type in an address on my 1st gps.
The manual can be downloaded from Garmin.
www.garmin.com/manuals/3130_OwnersManual.pdf
1. Touch Where To? > Address.
2. Change the state, the country, or the province, if necessary.
3. Touch Search All. If you know the city, touch Spell City, enter the city/postal code, and touch Done. Select the city/postal code in the list. (Not all map data provides postal code searching.)
4. Enter the number of the address, and touch Done.
5. Enter the street name, and touch Done.
6. Select the correct street in the list, if necessary.
7. Touch the address, if necessary.
Dec 14, 2011 | Garmin Nuvi 1350LMT
When I press address it goes straight to Street. It doesn't ask what State. If I put in address....it says not found. Brenda Romero
need a lot more info .... what gps model do you have,
your saying you put address it goes straight to street? then say i put addrees it says not found
Most Nuvi units you have to press Where To...Address....and on the bottom of screen you will see Change State / Province
First select your State..... then go back and select the City... it should now let you put the number of house press done ..then the street name
Nov 06, 2010 | Garmin GPS
What am I doing wrong or amI.
just press done on the street selection screen without entering a number. alternatively if you know the crossing street you can enter the streets into the intersection option in the where to menu
Jun 03, 2010 | Garmin nuvi 255W GPS Receiver
Need help unlocking maps in City Navigator NT North America.
I turns out that the unlock code was discreatly printed at the bottom of a yellow piece of paper in the packing.
Mar 21, 2009 | Garmin zumo 550 GPS Receiver
Question about entering address
First enter the state and then the city.
There are several cities with the same name in different states and therefore the street names would be different. However if you are first entering the state and then the city and the street name dosent show , then you will need to update the map on the GPS. For this you will need to contact customer service.
Feb 26, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Zumo 550
You'll have to select the europe map and deselect the usa map. Also you might have to change the locales. to do the first thing
tap wrench/tap map/tap about there you should see both maps, select the one you need and return to the wrench menu, select locales slect change all and walk through the menus (especialy the country!!!)
Aug 18, 2007 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
227 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
