SOURCE: maytag ensignia electric dryer makes alot if
I had a squirrel(?) stuck in mine! I removed the lint pipe and it was really nasty. Something had chewed through the screen and climbed down the pipe to stay warm?? We live in Minnesota and it was cold as heck. Anyway, Have a shop vac ready, I hope this helps. Remove pipe at the dryer, push start a couple of times and see if anything blows out. K.J.
SOURCE: How do I diagnose a problem with a dryer that
Since the dryer runs, the thermal fuses are fine making a possible open circuit condition in any of the heating element, the cycling thermostat, and the high-limit thermostat. Remove the front panel to access the cycling thermostat on the blower housing, the high-limit thermostat on the heating element enclosure, and the heating element itself. Once accessed, check the continuity of the high-limit thermostat and the large terminals of the cycling thermostat. There should be continuity on both parts. Use a volt-ohmmeter and set it to the R X 1 scale. Continuity means zero resistance. Replace the part found with no continuity, i.e., open.
Check the resistance of the heating element using the same volt-ohmmeter set to the R X 1 scale. Replace the heating element should its resistance reads infinite (open).
The front panel can be removed by removing the four screws located vertically along the
inside lip of the door opening. These screws hold the front panel to
the front shroud assembly.
Once the four screws are removed,
grasp and press in on the upper edges of the front panel posts then
twist it inward to release the clips holding it to the cabinet. Tilt
the top of the front panel and move it away from the dryer. Reinstall it in reverse of the removal steps.
SOURCE: how do I get the top off a maytag dryer model
http://www.partselect.com/dryer+open-cabinet+repair.htm
