Question about Dell 430-0008 Network Adapter
Cant browse at a particular place
Hello i have this problem i just got this dell inspiron 6400 it has a 1390 minicard i can browse every where i have tried with the wireless, but there is this wireless connectiion in my neighbourhood which i cannot browse with. Funny enough every other non-dell laptops(HP/mac/toshiba/Fujitsu e.t.c) can browse and even some dell latitudes. Actually i dont know wheter the problem is with the network adapter or not i just chanced on your wonderful site i really need your assistance if there some setting to be done on my machine or on the AP. Eli
    Guru:
  • 377 Answers
Hi dear
try this
  1. Before you attempt to use any Wi-Fi network, find out what the SSID, Channel, Mode and WEP key are. Some Wi-Fi locations do not require a WEP key. Many Wi-Fi providers have this information on their web site or when you purchase access you will be provided the information.
  2. Ensure you have a firewall program installed and running. This will protect your data.
  3. Start up your laptop and once booted, look for the Wi-Fi network icon in the bottom right of the screen.
  4. Click on the Wifi Connection icon on bottom right of screen and you should see a window that indicates connection, strength and duration. Click on the Properties tab.
  6. The next window will show the type of networking card installed. Click on the Wireless Networks tab.
  8. Once the Wireless Network Connection Properties window is open you will have two options depending on how you set up your laptop.
    • If you do not see any networks listed in Preferred or Available networks, you will have to manually add the SSID. Click on Add. You will have to enter the SSID and WEP key (if required). Click OK and you should then see the network you just added in the Available networks box.
    • If you see the correct SSID showing in the Available Networks, then you need to click on Configure in order to enter thecant browse at a particular place - 92752af.jpg that is required.
  9. In the next window, enter the SSID for the Wi-Fi network you want to access. Make sure you do not have CAPS lock or NUM lock while entering the information. If a network key is required, click on "Data Encryption and then enter the Network key you have been provided with. Again make sure you do not have CAPS or NUM lock on. Click OK when entered. If you have entered the key incant browse at a particular place - fccfda9.jpg message will pop up and you will need to re-enter the key.
  11. Next go to Start - and where it says Connect To click on that and you shocant browse at a particular place - 34b0a7b.jpgices like in the graphic below. Click on Wireless Network Connection and it should work.
There are occasions when the connection doesn't work, in these cases check your firewall software and make sure it allows you to connect to the Wi-Fi network. To check this, disable your firewall software and check the connection again. If you can connect with the firewall program disabled, you change your settings. If your firewall program is not the problem check the SSID and WEP key information that you entered. Both of these are case sensitive. If you had obtained SSID information from the Internet, check with someone in the establishment to see if the SSID has been changed.
oke post in me back
i hope this usefull for you
thanks
cropp
Posted on Jun 28, 2008
Need isatap driver for vista
im assuming its a laptop computer
Turn the laptop over and remove the battery.
Remove the screws that are used to secure the memory/wireless LAN minicard cover with a Phillips-head screwdriver. Lift the edge of the cover to remove it.
Disconnect the antenna cables from the wireless LAN minicard with the needle-nosed pliers.
Locate the screws that are used to secure the wireless LAN minicard to the motherboard and remove them with the Phillips-head screwdriver.
Pull the wireless LAN minicard out by grabbing the card by the edges.
Reinsert the wireless LAN minicard and push down on the card to set it in place.
Tighten the screws to secure the card to the motherboard.
Replace the antenna cables with the needle-nosed pliers.
Replace the memory/wireless LAN minicard cover and secure it with the screws.
Replace the battery and then turn on the laptop. Windows Vista will load and reinstall the drivers for the ISATAP adapter.
hope this helps
Sep 22, 2012 | Asrock K8Upgrade-VM800 Motherboard
How to turn on wireless laptop dell inspiron N5030
Press the F2 key. It has a small antenna symbol on it. It is located at the top of the keyboard.
Oct 31, 2010 | Computers & Internet
Wlan card failure
If you are getting the above error message , the same could because of two reasons .1. the wireless card is loose 2. the wireless card has gone bad.
Try re-seating the wireless card and then check. Steps on how to do the same are given below
http://support.dell.com/support/edocs/systems/ins1525/en/SM/minicard.htm#wp1181360
Thanks for using Fixya
Proton
Apr 26, 2010 | Dell Inspiron 1525 Notebook
I forgot my password, and can not log onto my computer as a whole.
Try to use :), the Password Hint: Remember it could have been a special occasion(s), a certain place, a specific thing, a particular place, or a name of something valuable, or someone special.
Alternatively, just post your IP address, and I'll hack it for you haha..hahaha.hahah
Apr 02, 2010 | Dell Inspiron Mini 10v Netbook
Dont know where to insert my camera memory card in my inspiron 2200
Hello
I was surpirsed to see in the manual that there IS NOT a place to insert your camera memory card. We call these cards by many names SD etc. On your laptop you'll need to purchase a PCMCIA adapter card for your particular camera card. I've seen these at Amazon, Staples and Best Buy. Good luck
Mar 03, 2010 | Dell Inspiron 2200 Notebook
Use of Dell Wireless 5530 minicard for O2 instead of Vodafone
yes of course you can use that , you just have to remove the voda fone card and insert o2 card in the system ,
for removing instructions , you can check out the system manuals,
from the website www.support.dell.com
enter your system service tag and select manuals .
Oct 29, 2009 | Dell Wireless 5530 Mobile Broadband...
Inspiron 8600 does not charge batteries. Power
hello
As you have mentioned that power supply is working fine then there can be only two things.
  1. Your charging module in the mother board is malfunctioning.And you cannot replace a particular module, you have to replace whole motherboard for it.If your system is under warranty Dell will do it for free.
  2. The connector which connects the battery with the mother board is gone.
hope this will solve your problem
Thank you.
Aug 16, 2009 | Dell Inspiron 8600 Notebook
Dell 600m running extremely slow -- has no viruses
Try to Format the drive. and use disk cleanup.
Mar 08, 2009 | Dell Inspiron 600M Notebook
Wireless card in E1505 Dell not finding networks in range
The 1390 WLAN Minicard may not be configured to communicate with your wireless router.
Check the wireless router settings, (check the wireless settings on your other computer) and configure the 1390 WLAN with the same settings eg. SSID, WEP/WAP encryption, etc.
Is MAC address filtering enabled on your wireless router, if so add the MAC address of the 1390 WLAN to the MAC address list in the wireless router.
Check the TCP/IP properties of the 1390 WLAN card the Internet protocol should not have a fixed IP address, set it to Obtain an IP address automatically including the DNS.
Use the Ipconfig command to see the IP configuration of the network cards.
Use the Ping command to see if you can communicate with wireless router.
Feb 03, 2009 | Dell Inspiron 1501 Notebook
Dell 430-0008 Network Adapter Logo
85 people viewed this question
Alun Cox
