Question about Kenmore Washing Machines
How do you get inside kenmore calypso 110.22062100. I am having a problem with bleach dispenser not working.
  • 246 Answers
Before you go in, have you removed the top portion of the dispenser? You can do that while the lid is still in place. If so, here's how to get in. Take a small flat head screw driver or putty knife. Put a thin peice of cloth over it so as to not mar the finnish on your machine. Using a flash light look between where the top panel and the front panel meet. There will be two flat green peices of metal. Using your putty knife or screw driver, push on these clips towards the rear of the machine while lifting up on the top portion. Once you get the two clips off, you'll be in. For a bleach dispensing problem, I would remove the hose coming off the bleach dispenser side, the white plastic "T" it goes into and the other black hose that goes out to the tub. You could have build up or debris in one or all of them preventing your bleach dispenser. While you have them off, also check the nozzle off the bleach dispenser itself. it too may have a restriction.
Posted on Jun 25, 2008
Kenmore calypso washer bleach
I would take the bleach hose off and verify it is not obstructed, if that doesn't look bad then the system that calls for bleach my be faulty, but I would check for obstructions first in the hose first.
Jan 15, 2014 | Whirlpool Washing Machines
Water dumps on clothes when opening the lid.
It sounds like the seal is loose (worn out) or damaged in any case....not sealing. Calypso's splash a lot and when bleach is used regularly they corrode quickly. To replace the seal you have to get a whole inner lid assy. I also advise not using bleach or at least not regularly.
Jul 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Dingy whites
smaller loads - so articles arent drawn to the hole.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Sears / Kenmore top-loading washer does not dispense bleach
Remove the tray and check the proper operation of the solenoid for the door.
May 31, 2009 | Kenmore 23822 Top Load Washer
Maytag top loader slight leak from bottom left corner
Thank you for responding. Yes we fixed the problem. After taking off the front cover noticed the hose from the liquid bleach dispenser (which I never use) was not connected. Evidently when using the extra large load a little water would splash into the bleach dispenser, hence the small amount at bottom front left corner where dispenser is located. So simple! Glad I didn't pay for someone to attach the hose. Thanks again for your timely response. Lynn
Mar 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore/Sears 417.43142200 bleach dispenser not dispensing
Before you do anything, make sure that the plastic part in the bleach dispenser container is pushed in. Fill with bleach to the "max" line, written on the plastic part. Start the wash cycle and make sure that water goes into the bleach dispenser. Once water flows into the dispenser, the bleach/water mixture rises and should automatically dispense into the washer. We had this same problem. We removed the dispenser unit and took it to the sink. We then filled it with water and it started coming out from the bottom automatically. So sort of suction is caused from the amount of water and it starts to flow. Basically, you aren't adding enough bleach into the dispenser if the water flows into it as the wash cycle runs.
Mar 22, 2009 | Kenmore 43142 Front Load Washer
Kenmore Oasis washer - water accumulates in bleach dispenser
somethinf clooging dispenser, remove water from dispenser and get small straw and un clogg,,,,,,,, thats it
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore front load washer will not dispense fabric softner
I've had this same problem and solved it by removing the detergent/bleach/softener dispenser drawer from the machine and seriously cleaning out all of the "gunk" from the drawer and from inside the drawer area on washer. Sometimes I have had to repeat the cleaning and then the fabric softener begins dispensing again. I have model # 417.43042200 but it may work on all the Kenmore front loading washers.
Oct 28, 2008 | Washing Machines
Too much water on clothers
this is common with this model
may need a new lid
Oct 20, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Open Questions:
Washing Machines Logo
100 people viewed this question
Sal De
 Brian Main
Brian Main
