Question about Dishwashers
My dishwasher does not seem to be spraying water like it should during normal cleaning cycle, the door still has food on it how can we fix this
  • 487 Answers
Take the arms out of the machine and clean them. Normally they get clogged up
Posted on Jun 24, 2008
Kudpo1flbl2
Check if you have at least 120 degree water temperature coming into the dishwasher. Check if the upper rack spray arm is turning during cycle. Does dishwasher sound normal, like you can hear strong water spray inside it?
Nov 13, 2011 | KitchenAid Dishwashers
Hi I have a Blanco dishwasher BFDw8 which is having poor wash results in the top tray I have tried all the trouble shooting things in manual. Investigated further by opening door during wash cycle several...
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Scrape away large pieces of food, bones, pits, toothpicks, etc. Burned on food should be loosened before loading. Empty liquids from glasses and cups. Foods such as mustard, mayonnaise, vinegar, lemon juice and tomato products may cause discoloration of stainless steel and plastics if allowed to sit for a long period of time. Unless the dishwasher is to be operated at once, it is best to rinse off these food soils. Load racks so that large items do not prevent the detergent dispenser from opening. If the dishwasher drains into a food disposer, be sure disposer is completely empty before starting the dishwasher.
just click on the above questions for more help the answer will come to the screen
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
  25. Stainless Steel Cleaning
  26. Strange grinding noises and not washing properly
  27. The dishwasher doors falls down
  28. White filming on the glasses
Oct 05, 2008 | Dishwashers
White residue on dishes when the dishwasher cycle has completed, not sure why, salt is fine. Is this limescale?
Hi
Make sure that the water is being heated up by your dishwasher. Also need to make sure that the wash motor is spraying water around at full force.
Best way to check this is to start a normal cycle about 10 minutes into the cycle open the dishwasher door during the cycle. 1st observe if the water was being sprayed around as you opened the door. 2nd feel the water and see if it has heated up.
Reset or cancel the cycle and wait for the water to empty. make sure it is draining properly and also check to see if filter is clean.
I'm inclined to think your machine is not heating the water.
Ash
Sep 09, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Won't clean-looks to run properly
check the sump area below the pump and clean out any waste food debris,etc. and also the drain check valve,it may be plugged and not draining waste water completely or not closing completely and letting waste water back into the sump and this could be getting back through the pump and sprayed back onto your dishes
Jul 28, 2010 | Kenmore Dishwashers
Food particles remaining on dishes after cycle is complete.
Hi
While putting dishes in the washer and obstructing the spray ams which causes food particles to stay on dishes. After loading dishwasher and pushing in baskets ,be sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
However the other causes for this problem are…
Not enough water entering dishwasher (check level after fill... Should be slightly below bottom wash arm)
Water filling but draining during wash cycle. Check toward end of wash cycle but before drain. See if water level is diminished from start of wash cycle.
New 'water saver' dishwashers are notorious for having smaller water jets, and thus easier to stop-up jets. Check the jets on all wash arms to be sure they are cleared of food particles.
Another way to check the wash arms is to manually position them at specific locations, momentarily run the dishwasher for a few seconds, then open the door to inspect the location of the wash arms. Do this three or four times to eliminate the possibility of coincidence.
If the wash arms do not move from the location that you put them, the most likely cause is food particles stopping up the water jets. These jets not only clean the dishes but also the water pressure they generate turn the arms inside the dishwasher to properly distribute water pressure on the dishes.
Sometimes you can dislodge and remove food particles stuck in one of the jets with a toothpick or other small probe. Others require that you remove the arm(s) and get a little more creative. I use compressed air to clear mine, but not everyone has access to compressed air, so use whatever you can to remove the food particles.
Simply dislodging them from the water ports is usually not effective... As soon as water pressure is applied, the particles return to the jets and stop them up again. The real fix in this instance is to completely remove the food particles from the arm if you can.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
Apr 14, 2010 | Maytag 24 in. MDB8600AW Jetclean II...
Hi, my Frigidaire dishwasher doesn't seem to clean
Factory Defect, where I was given full refund plus re-installation costs from Lowes...
Oct 04, 2009 | Frigidaire Dishwashers
Motor makes noise shortly after starting, makes normal sound level during main body of wash, then makes noise again during what I'm guessing is the rinse cycle. Not sure if it is a pump or motor problem....
Make sure the sprayer arm is turning freely, check for something stuck in the base of the sprayer arm (food or utinsel) preventing it from turning.
Sep 22, 2009 | Dishwashers
No clean dishes
Internal filtersEvery dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve
Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms
There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Detergent cups
Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Sep 12, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
I have a whirpool Quiet Partner III, and the top layer of glasses is not getting clean. I had a technichian out some time ago, and the problrem was caused by food debris trppaed in the filter in the wash...
CHECK THE SPRAY ARM HOLES,ARE THEY CLOGGED ??IF THERE NOT YOU MAY NEED THE PUMP REPLACED (NO PRESSURE).........BY THE WAY THE POWER DRIVE UNIT IS NOW REFERED TO AS A > MOTOR/PUMP WHICH IS NOT INCLUDING THE PUMP.IT'S THERE WAY OF ADDING CONFUSION WHEN WE ORDER PARTS. 1ST LOOK FOR CLOGGED SPRAY ARMS. LEAVE A RATING !!
Jun 08, 2008 | Whirlpool Dishwashers
Dishwashers Logo
47 people viewed this question
Top Dishwashers Experts
