Question about Dryers
Where can i see a schematic for the igniter and coils on my maytag gas dryer? I replaced the coils but have not connected the wires. Thank you.
  • 525 Answers
Http://www.google.com/search?sourceid=navclient&ie=UTF-8&rlz=1T4PCTA_enUS209US216&q=maytag+gas+dryer+wiring+diagram
You should also be able to find a wiring diagram in the control console,
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 24, 2008
I have a Maytag LDG 4000 gas dryer with electronic ignition. The igniter glows, but does not ignite the gas. I can not smell any gas, so I'm assuming a valve of some sort, internal to the dryer, is not...
Igniter glows - No gas ignition. If the igniter heats
up but the main burner flame is not ignited, remove
power and using an ohmmeter, check the following:
• Open secondary coil
• Open holding coil
• Open wire harness
• Stuck flame sensor (Stuck closed)
Most likely bad gas valve coils.
Sep 07, 2010 | Maytag MDG4000 Dryer
Not getting hot. vent line is free of lint. Maytag Atlantis/gas
Chances are the hot surface glow igniter is not working. Most likely it is burned out. Set the controls to dry in high heat and note if the glowing coil does in fact glow. If not, it needs to be replaced. Open the burner access door and then turn the dryer on. Watch inside the burner compartment for the glow coil to light up and glow. If all the controls are set correctly on the front control panel and the dryer is running, but the glow coil fails to glow, you've located the defective part. The glow coil will need to be replaced.
To remove the coil, turn off the gas first. Unplug the dryer from the electrical wall plug. Then remove the entire gas valve as an assembly. The nut on the gas valve to remove it from the gas supply pipe turns counter clockwise. There will be small sheet metal screws used to secure the plate to which the burner assembly parts are attached. The plate holds the entire assembly and is attached to the bottom of the dryer's cabinet.
Next, remove the glow coil from the burner assembly. Take the entire assembled part to the local appliance retail parts store for a replacement coil. Glow igniters are fragile and they break easily. Handle and install the new igniter carefully. Glow igniters are a non-returnable and non-refundable electric component.
Be advised that some new replacement igniters do not come with quick disconnect ends. In this case, it is OK to cut off the quick, disconnect from the old igniter and attach it to the new igniter. Simply clip off the wires several inches above, disconnect the old igniter, attach to the wires of the new igniter, and wire nut the two ends together. Repeat the process to attach the other set of wires and wire nut them together. There is no positive nor negative polarity to be concerned with.
Additional Suggestions: Read the manufacturer's online Web site for product information, problem possibilities, causes and solving methods, part locations, disassembly, reassembly methods, repair procedures, instructions, pictorials and schematics, which may be available online.
Oct 15, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Gas dryer ignites at start up then cycles off, won't re-ignite
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedures for your dryer.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
The link below shows an image of the gas valve coils, which is the most common failure component in the system.
1. Gas Valve Coils:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG3000AWW-%3d%3di3479&PartID=3479
Below are some tips to follow if the coils are not faulty.
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
You can also obtain more appliance information at my website, www.homemanagement.services.officelive.com
Aug 28, 2009 | Maytag Dryers
Maytag mdg6200aww dryer not drying clothes
my maytag dryer turns on the gas ignites and stays on for about 1 min then the gas shuts off the ignitor glows orange every 30 sec to a minute but the gas valve does not open also the dryer knob does not go past more dry im not sure if thats also the problem
Aug 24, 2009 | Maytag MDG7600AW Gas Dryer
Maytag neptune model mdg3000aww heats for 20 - 30 second then the burner stops.
The most common failure item is the gas valve coil(s)
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below are some links provided by, www.repairclinic.com. This can assist you with diagnosis, parts ordering and replacement.
Dryer parts breakdown link:
Coil illustration link:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg3000aww-%3d%3di686303&PartID=686303
Igniter
Gas valve coils
Aug 15, 2009 | Maytag Dryers
Dryer doesnt heat up
I have provided a checklist for both gas and electric dryers, courtesy of; www.repairclinic.com.
They also provide repair parts, disassembly diagrams, and instructions.
Firstly, ascertain that you have made a positive heat selection, then read on.
Electric Dryer Checklist:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to
Gas Dryer Checklist:
Igniter
Gas valve coils
Thermal fuse
Jul 14, 2009 | Maytag Dryers
Maytag performa dryer will not heat up
maytag performa dryer Model PDGT910AWW
"No Heat" complaint.
Firstly, make sure that you have selected/ascertained a "Heat" setting, then read the checklist below provided by; www.repairclinic.com
They also provide disassembly diagrams and repair parts..
Igniter
Gas valve coils
Thermal fuse
Jul 06, 2009 | Maytag Dryers
Maytag dryer Model # ldg9304aae , Dryer won't dry intermitantly, may not be lighting. Don't hear igniter
Firstly, ascertain that you have made an adequate heat selection, then read the checklist below, provided by; www.repairclinic.com. They also provide disassembly diagrams and repair parts.
Igniter
Gas valve coils
Thermal fuse
Maytag neptune (gas dryer) just stopped heating up...was working fine yesterday. The dryer is 8 years old...never a problem. Does the heating elements need replacement?
Gas dryers utilize a gas valve, ignitor assembly, and a series of coils mounted on the gas valve to provide heat and safety. The gas valve coils are the usual suspect when it comes to a "No Heat" complaint. I have provided a checklist from www.repairclinic.com, for your convenience. They also provide disassembnly diagrams and repair parts.
Firstly, ascertain that you have made an adequate "Heat" selection, then read on:
Igniter
Gas valve coils
Thermal fuse
Jul 06, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer does not stay hot.
Hello. I can help you. Here are all of the possible problems
Igniter
Gas valve coils
Thermal fuse
Jul 04, 2009 | Dryers
Dryers Logo
179 people viewed this question
Top Dryers Experts
