Question about Sony CDX-CA850X CD Player
CDX-CA850 REMOTE Hi, I have installed a second hand player to my vehicle and have found that the remote does not work. I have replaced the battery which has had no effect. Can you help
  • kwigz Feb 08, 2009
    ihave the same problemsthe remote control will not work what so ever....
SOURCE: Sony CDX-M630 will work only with remote.
possibaly the issue is the ribbon cable that connects the faceplate to the head deck i had the same issue
Posted on Jul 10, 2008
  • 55 Answers
SOURCE: sony cdx-m630
I have a few suggestions that may help. Have you checked the fuses?There is on on the stereo and one in the car's fuse box. Are all of theconnections from the wiring harness secure? Make sure these are tightand show no signs of damage, especially the ground connection. Also, ifthe face is detachable, check the connectors (on the face and thestereo) for damage or dirt or anything that would prevent a goodconnection. Pushing the reset button should not have prevented you fromoperation of the unit, so it has to be either an external fault (likewhat I described above) or an internal problem. How old is the CDplayer? If it is still under warranty, I would call Sony or go to theirwebsite and speak to one of their techs. You can go to the site byclicking on the blue link: Sony Support Hope this helps... Please take time to rate how helpful this was. Thanks and good luck!
Posted on Sep 10, 2008
SOURCE: Fixing CDX m770 - buttons dont respond
I HAVE THE SAME PROBLEM,ONLY THE LEFT SIDE IS OUT AND I DONT HAVE THE REMOTE.I DONT EVEN KNOW WHAT REMOTE MODELS GOES TO IT?IF ANYONE CAN HELP PLEASE EMAIL captainmorgan3@@yahoo.com
Posted on Oct 22, 2008
insanegtp
  • 112 Answers
SOURCE: radio audio working but no audio from CD. Shows cd playing but no
:) swap your blue with your blue/wht or vice versa.. (behind the radio) this WILL fix your problem..
Posted on Jan 27, 2009
SOURCE: sony cdx-ca850
There is a setting for this in menu. It defaults to "Auto" when the power is removed. It needs to be set to "Wide"
Posted on Jun 10, 2009
Sony CDX-5005 factory installed in a Bryant boat... no out put in any mode to speakers. What replacement unit will fit and hook up to existing harness?
Any DIN style radio will fit onto the existing cut out.
Stay with Sony CDX family. The connect and color code will be the same.
Do you still has the remote control for this Sony CDX-C5005?
This remote has an "ATT" (almost like mute) //// lower left hand button.
Aim the remote to the radio and press the ATT button and see is the volume restore to normal.
Click HERE (skip to page 6) for a sample picture of the remote.
Jul 28, 2011 | Sony CDX-C5005 CD Player
Remote starter doesn't function
if the battery was replaced or any terminals removed, you may have lost the tach programming for the remote starter. Goto http://www.bulldogsecurity.com/bdnew/installmanuals.asp and look for the remote start unit you have in the manuals and it will tell ya how to reprogram the tach memory.
Jun 29, 2010 | Bulldog Remote Starter & T-Harness Kit for...
My boyfriend hooked up my speakers in my car to my cdx-gt200, now my cd player wont even come on. He never touched any of the connection wires for the player. At first he could not find the remote turn on...
change the fuse behind the system.
"so he hooked it up to the left front speaker wire, then found the remote turn on wire and hooked it up to it." will have burned the sound system or not. remove the new installation, test it, reinstall, test again.
Jun 01, 2010 | Sony XPLOD CDX-GT200 CD Player
Unit asking for code
Here is a link to the Owners Manual for Sony CDX-M610. Look on page 8 to reset after replacing the battery.
http://www.docs.sony.com/release/CDXM610.PDF
Oct 13, 2009 | Sony CDX-M610 CD Player
Hi i need a remote for cdx-m630,where can i get one from?thanks i am from Toronto
You need remote under following part number for CDX-M630
47711014 RM-X117 REMOTE CONTROL for $33.95
It is available in Sony Accessories Store (copy link in browser search bar)
http://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=modelSearch&searchText=CDXM630
Thanks.
Jul 16, 2009 | Sony CDX-M630 CD Player
Key fob not working
Most of these key fobs have a number (FCC#) on the back, or inside the casing. You could go to the dealership and have them charge you a ton of money, or you can by them on ebay and set the switches on the circuit board to match your remote. Just make sure when you buy it the it matches your remote exactly.
Jul 07, 2009 | 2003 Hyundai Accent
Citroen xsara remote?
I haven't done it but apparently once you replace the battery in the remote you also have to do a 'resync' process (information from cxoc.net forums):
-switch ignition ON
-press and hold lock button for 10 seconds
-switch ignition off
-wait 3 seconds
-synchronisation procedure is complete
-confirm sync. with locking and unlocking the vehicle
Apr 05, 2009 | Rio Carbon MP3 Player
Radio audio working but no audio from CD. Shows cd playing but no
Jan 27, 2009 | Sony CDX-CA850X CD Player
Sony model #CDX-M630 car stereo reciever
you need to use the original remote to enter the code. Try these codes one of them should work...
You need to press reset after each attempt.
CODE 1: MODE SOUND OPEN ATT
CODE 2: ENTER OPEN MENU 6
CODE 3: OPEN DISC+ 1 LIST
CODE 4: SEEK- SEEK+ 3 OPEN
CODE 5: OFF 4 OPEN SOURCE
CODE 6: 2 OPEN DSPL SOUND
CODE 7: OPEN 5 ATT SEEK+
CODE 8: DISC- DSPL OFF OPEN
CODE 9: SEEK+ SOUND OPEN ENTER
CODE 10: DISC- LIST SEEK- OPEN
CODE 11: OPEN 4 LIST OFF
CODE 12: DSPL SOURCE OPEN 1
CODE 13: MENU 2 MODE OPEN
CODE 14: 5 DISC+ OPEN ATT
CODE 15: 3 MENU SEEK- OPEN
Sep 13, 2007 | Sony CDX-M630 CD Player
I think that you gays have a problem that calls flat cable that connects the main unit with the black rotary display
it costs about 10-20 usd and it is very flexible and thin.
the flat cable brakes at the place where it connects the external black display,you should try to look how the condition of the cable is
you can contact me at yupower1@hotmail.com
regards
May 23, 2007 | Sony CDX-M770 CD Player
Sony CDX-CA850X CD Player Logo
154 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
