Question about Nikon Cameras
Have Nikon F3. Did not use for several months. Tried today - light meter and shutter do not work - checked & found good battery must be in camera - put in new batteries w/o success - Replacement batteries are Energizer 357/303 that I was told match chart for Varta V76PX that had been in camera. I'm "dead in the water" and don't know what to do next. Positive side of battery is up Towards lens)
    Genius:
  • 1,689 Answers
Well first off pheonix, is the motordrive still working, hopefully it is. if so then the only concern you may be encountering right now are the contacts for your Varta V76PX / 357's. few months of no operation may give enough moisture inside the camera and rust will start to form, it may not be visible on the outside of the battery contact but it could be inside. battery contact repair/replacement may not cause too much, so thats a good side.
if this is the problem (my boss had an D50 and stroed it without silica gel), the next time you store it, use a silica gel, or put one in the box/bag where it will be intalled. just a personal thought
good luck
Posted on Jun 24, 2008
    Master:
  • 848 Answers
Just clean the heads and remove the battery clean the metal surface properly ....and reinsert the battery
  • gopinath pasupathy Jun 24, 2008
    there might be some sensor problem if your lens are not coming out
    Genius:
  • 1,847 Answers
Try push the shutter with the finger, as it could be jammed not used for long time.
  • 13,433 Answers
You may have to take this to a professional you can try pressing the reset hole in the bottom or near the connectors.
Nikon f3 shutter release and light meter
there are a number of things that could be causing this and none of them are good. The impact could have torn the main circuit. If it hit on the rewind side there is an expensive glass disk (glass is used for temperature stability) called a FRE that has contacts on it for the ASA and aperture information to be sent to the main circuit. This is easily broken. You may also have damaged the shutter speed unit or its flex.
Jun 01, 2012 | Nikon F3 35mm Film Camera
I have a Nikon F601 and I put a 400 iso film recently and I sort of didnt know how to load it on properly so I pressed the shutter release button as I loaded it twice when youre only suppose to press it...
Remove the lense, or the film if you're willing to waste it, and check to be sure the shutter blades aren't damaged. It'll be fairly evident if they are. If they are, the camera is pretty much now a paperweight. I hate to tell you that - but shutter replacements are VERY expensive and parts for most of these models no longer available from Nikon.
If that is not the issue, set the mode dial to M and try to take a shot. If that also doesn't work, either the batteries are exhausted or there is an internal issue in the camera. At this point, try new batteries. If that also gets you nowhere, you'll need to seek a reputable service tech, either through Nikon directly, locally if you can find one, or online/mail-order. If you have to go mail-order/online I'd recommend KEH Camera out of Atlanta, GA. They are very reasonable, have decent turn around, and do good work - but expect at least 1 month without your camera.
In M(anual) mode, be sure the lense is also set to M, via the switch on the front of the camera near the lense mount. You're not worrying about the quality of the image, only if the camera will take one. In manual mode, the light meter and other functions will have NO bearing on anything the camera does or doesn't do. At this point the meter reads out only for your information for you to set the settings yourself. The batteries do everything else - firing the shutter, driving the motor, etc.
Jul 21, 2011 | Nikon Photography
Hello, I recently purchased a nikon F2AS, it was in top condition, except there was no battery in the meter. Installed a new battery, and it occurred to me that the metering in the viewer was not clearly...
In Canada the cost of such repair would be about $100.00. I'd suggest not attempting the job yourself because the meter and shutter will need to be timed and a repair facility would have the necessary tool for doing this. An internet search will reveal several service places other then Nikon to have this done. I've even seen auctions on e-Bay selling service and had a Canon A 1 serviced. If the camera is in otherwise good condition and you enjoy the creative aspects of a manual film camera then you have a great classic to work with.
Oct 05, 2010 | Nikon F2AS Photomic 35mm SLR Camera
Nikon f3 hp light meter wont work
I'm interested in this as well. Just installed fresh batteries, light meter says 1/80 in all shutter settings faster than 1/60 (otherwise it shows the correct setting). Since 1/80 is the flash sync speed, it may be that the camera thinks there's a flash attached. But it is not...
Strange thing is that one time (I tried a couple of times today) the light meter worked correctly; it showed other timings and they changed as I turned the aperture ring...
Apr 16, 2010 | Nikon F3HP 35mm SLR Camera
Nikon F3's light meter always underexposed
needs repairing at a qualified shop
when was it last cleaned or serviced ?
if you think the camera is worthy, since its old how much is it worth to you vs a new one
Mar 06, 2010 | Nikon F3/T 35mm SLR Camera
I am borrowing a Nikon F3 35mm film camera but I am having issues with the exposure meter. When I adjust the shutter and aperture to the appropriate dials the meter will say +- but when I double check it...
This is normal. The meter is extremely accurate and as long as you're very close to getting the "+ -" indication then you're good to go. Half stop positions are available on the lens aperture scale precisely to help you get the metering close enough.
Negative film has a wide exposure latitude and exposure errors of just half a stop will not be noticeable in any way on the final print. Even errors of one stop will often be insignificant as the printing stage gives the opportunity to compensate for errors at the exposure stage. It's a different matter with slide film though as there is no second stage but even then you need to be aware that the meter indication is a centre-weighted average of what's on view in the finder. So as long as you're paying attention to important highlight and shadow details you can use the meter as an indication and base the actual aperture and shutter speed on informed judgement.
You may also want to look at an online user manual for the F3: http://mir.com.my/rb/photography/hardwares/classics/nikonf3ver2/f3manual/index.htm
I hope that you've found my answer to be of some assistance and only ask that you return the favour by rating my answer.
Oct 19, 2009 | Nikon F3 35mm Film Camera
Light meter not working
Make sure the battery lid is securely screwed on, The meter wont work before the '1' frame. i just found out last week about this. make several clicks till the '1' mark appears, now check the meter if its working. [A] - aperture prio
Jun 09, 2009 | Nikon F3 35mm Film Camera
How do I put the neg and Pos 1.5 batteries in Nikon F3
If you undo the battery cap and pull it out , then hold it under a bright light you will see a picture of the batteries with their orientation depicted on the side of the plastic sleeves that will hold the batteries. Look for the shape of the batteries and make sure you load them in that same orientation.
Once loaded, remember that you need to pull the advance level back about 20 degrees to activate the power and the light meter.
Dec 12, 2008 | Nikon F3 35mm Film Camera
Nikon F3 w/MD4 motor drive...Not working!
Check to see if the manual shutter release (the one that is to the left of the lens when you look at the camera head on) is not cocked and ready. It should have its lever resting against the lens collar. Since this is the manual release of 1/80 second, this can sometimes be the cause of the problem. Also, make sure the shutter speed dial is set to something other than the 80 speed.
Since you can get a reading on the light meter, its likely not a power issue, plus the F3 is capabale of pulling power either from the drive or from the battery compartment.
Sometimes the electronic F3 shutter button can seize due to lack of exercise. The curtains won't need placing unless they are worn, but the switch may need replacing.
Dec 10, 2008 | Photography
Cameras Logo
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
