I pod to tv
Is there a jack wire to put my i pods content through my big screen tv?
    Novelist:
    Scholar:
  • 100 Answers
Salutations DDAWG123,
Depending on how you wish to connect your Ipod there are several cables that you could purchase.
This is a standard cable that you should be able to connect to your audio jack which will allow you to view movies and listen to music on the television:
http://www.bestbuy.com/site/olspage.jsp?skuId=7673038&type=product&id=1134703394661
Or
This cable should connect through the imput jack and would connect to your telvision and allow you to charge the unit:
http://www.bestbuy.com/site/olspage.jsp?skuId=8769914&type=product&id=1203815922545
Happy Shopping.
Jon
Go Ahead. Use Us.
Posted on Jun 24, 2008
Screen display "no content" error when plugging i pod into usb port
some receivers have a special usb port for i pod to work properly
does not read i pod otherwise
Jan 10, 2014 | Yamaha Audio Players & Recorders
When I plug my headphones into my iPod, there is no sound, unless I jiggle the cord around and do not plug them all the way in. They worked fine at the beginning, but do not work now.
I'm not certain it's not the I-Pod socket or the headphone jack that is playing up? If you can get another pair of headphones (a friends etc) and put them in the socket of the I-Pod, to test it that should clear it up. For if they don't work you know it's the I-Pod socket that's faulty.
If it's the Bose jack that's gone, you better see my tip on dodgy cable/plugs on headphones. You should be able to replace it with the 3.5mm type shown, but I think you can get the thinner type jacks.
Jul 09, 2010 | Bose in-ear headphones - Black with...
My Line 6 Spider Amp sound goes out when I plug in my FBV express pedal. Any advice?
Read this cut and paste and verify compatibility as a first step:
*FBV is not compatible with Spider II 15 or Spider III 15.
**FBV is only compatible with POD 2.0 units with pedal jacks labelled "FBV Pedal." It is not compatible with older units which have pedal jacks labelled simply "Pedal."
(NOTE: FBV is NOT compatible with Ax212, Flextone I, II or HD, POD® Pro, Bass POD®, Bass POD® Pro and Spider.)
Note there are apparently several versions. Check compatibility at this site:
http://line6.com/footcontrollers/fbv.html
May 07, 2010 | Line 6 Spider Iii 120 Stereo Guitar Combo...
Pocket Pod wont turn on
MOST pedal devices ENABLE the battery when the INPUT audio cable is inserted (there is a switch on the jack it plugs into). This automatically connects the battery when you go to use it... ALSO if you leave the cable plugged in will DRAIN the battery.
May 02, 2010 | Line 6 Pod 20 Fx Box
Ipod nano connector for Bose 321 GS Series III
OK! The cheapeast and most simple way would for you is to get a 1/8th inch conector jack that adapts into red/white RCA jacks (it will have a couple feet of wire in between the jacks) plug the 1/8 inch adapter into the jack on I-POD and the RED/WHITE ends into the back of your systems aux inputs RED/WHITE! OR tape input ect! make sure I-POD is turned up! and you may have to adjust I pod eq to get the best sound out of system! (OH you can get this adatper at any radio shack or wall-mart!)
Please take a second and rate this response
THANK YOU!
Jan 19, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
Senseo machine has started producing very weak coffee
I don't know if you've tried this, but it works like gangbusters for me. I use non-senseo pods with the 2-pod holder, and they're too big for the 1-pod holder but not quite big enough for the 2-pod one.
I would frequently end up with a lousy, weak cup of coffee, and after a little investigation I deduced that water was flowing into the pod holder and AROUND the pod, without going THROUGH the pod directly. The name-brand senseo pods fit perfectly, and always produce a strong cup, even if I don't like their coffee, and it's because there's such a tight seal between where water flows in and where it flows out.
Simple solution: Put your pod in with the flat part facing up, and the bulgy part facing down. Press it down hard into the 2-cup holder. Run a little HOT tap water, and lightly wet the surface of the pod--not so much water that the pod starts floating in the holder, but enough to get it soggy. Then make your cup of coffee. The water will flow through the pod first, and kind of like siphoning gas through a hose, once it's started going through the pod it won't stop. Instant awesome cup.
Oct 24, 2008 | Philips Senseo HD-7810 Coffee Maker
Bose Control Pod won't work
Try changing the plug on the control pod, those plugs are fairly weak and prone to breakage. Does there appear to be any strain at all on the plug itself? if so then that is where I would start. If you have a series 2 then I can help you, or if you can find out if the 2 control pods are the same, that would be fine too, but I have a series 2 system companion 3 and if needed I will cut my cable to trace the wiring and then replace your plug for you. my cost for this would be $40, that includes return shipping with priority mail.
Oct 03, 2008 | Bose Companion 3 Computer Speakers
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
