Question about Dell Inspiron 6400 Notebook
Problem with display on Screen
I have a dell inspiron 6400 laptop and the screen does not show brightly again but when connected to an external screen it is just okay. What is the problem and how can it be resolve?
    Genius:
  • 2,028 Answers
Try ajustiong the resolution and advanced settings.
Posted on Jun 24, 2008
My laptop monitor goes dark
Hi there! Try this trick...
You can adjust the screen brightness within BIOS set up...
It works with Dell!!!
^_^
May 13, 2010 | Dell Inspiron 6400 Notebook
Hi , my dell inspiron 6400 vista has no disply but external monitor it shows fine ?
If the external monitor is fine then there might be the issue with the display panel cable ( cable which connects mainboard with display) or the display itself. Ypou will have to replace.
Thanks
Mar 09, 2010 | Dell Inspiron 6000 Notebook
Laptop to TV Connection
Check if you are sending the signal to the external monitor. On my laptop with Windows 7, I can right click on an open section of the desktop and choose Graphics Properties. In this window, I can choose to send the display to the laptop's internal monitor, the external monitor or both.
Pressing Crtl-Alt-F1 will force the video onto the external monitor on the fly (Crtl-Alt-F3 goes back to the laptop's screen).
When I have added a second monitor to a desktop, I needed to reboot and allow new hardware to be found before the related Screen Resolution (right click on the desktop again) let me find the second monitor and choose if this was a duplicate or extended screen.
I hope this helps.
Mar 08, 2010 | Dell Inspiron 6400 Notebook
The screen is not coming on at all. i connected
With the external monitor connected, try holding down the FN key and pressing one of the F keys at the top of the keyboard that has a Monitor icon on it. This should turn off the external screen and show the laptop screen. If you press it a 2nd time, BOTH screens should show up. If still blank, Press again until the External Monitor comes back on. Then go to www.dell.com/support and go to Drivers for your Model. Then download and re install the VIDEO or DISPLAY Drivers. This should fix it if its a missing driver. If STILL no display on the laptop, call Dell.
Oct 21, 2009 | Dell Inspiron 9300 Notebook
Monitor does not work, computer starts up, dell prompts load, windows prompts load then screen goes black. i can hear everything loading but no display.
connect an external monitor on your machine and check if display is ok on the external monitor. if yes, try to re-install your video driver and check if display is ok on your laptop.
if both doesnt have display (external monitor and laptop's display) i suspected your lcd display is faulty.
Jun 30, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 display goes off < 1 min after switch on time
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
The buzzing sound is most likely the inverter problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 26, 2009 | Dell Inspiron 6400 Notebook
DELL inspiron 6400 laptop screen turned black
this sounds like a classic case of inverter problems, it could be just inverter coil thats gone which is an inexpensive repair, if it is the inverter then its a bit more.
try the Fn the F key that shows two tv screen icons, it may just have switched to external mode by accident
good luck
Nov 16, 2008 | Dell Inspiron 6400 Notebook
Laptop goes dark
You can refer to this document for display assembly. It looks like the display is going bad. By checking the seating of the display cable, you're isolating the fact that the cable is connected.
http://support.dell.com/support/edocs/systems/ins6400/en/sm/display.htm#wp1022270
Hope this helps :) Kindly leave a rating. Thanks..
Nov 27, 2007 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
118 people viewed this question
Alun Cox
