Question about Creative Labs ZEN Vision:M Digital Media Player
Vreative zen will not charge - Creative Labs ZEN Vision:M Digital Media Player
  • 1 more comment
  • seventiesgal Aug 05, 2008
    I have tried to charge my zen
  • Anonymous Aug 06, 2008
    Same problem here - works fine from conencted mailsn charger - but powers off as soon as disconnected
    D
  • Anonymous Oct 06, 2008
    Same here,
    Works when connected to mains. I used to work in a department where the desinged MP3 player processors (also for creative) and think I know what is wrong:
    The Charging circuit that is implemented for the lithium ion charging, needs a small voltage from the battery to detect it and start loading. (this is intended as safety, but will render your device unusable if the battery goes completely flat. So i have also have a dead device now.
    Solutions:
    1 Get and install new replacement battery (instructions can be found online (is simple)
    2 Open your device (use same instruction). Connect yout battery to a 3 up to 3.5 volt power supply. Leave this for a short while (charging lithium ion battery's is difficult) This might give the battery enough charge to be detected by the player again.. reassample and recharge as usual.
    I will first try the second option, if that won't work, I will hav to buy a new battery.
    GL with your dead visions!
Thank you all for your comments and solutions.
I bought a dedicated battery charger and hey presto - all is well, I have got my music back.
Thanks again everyone
Posted on Oct 07, 2008
I used to work in a IC design department where we disigned IC's for creative. It is a problemn of the lition ion charging circuit. When voltage drops under 0.9 volt (if I remember clearly) It will not detect
the battery anymore and wil not charge..
So, solution:
1 try to charge the battery manually for a short time, disassemble the vision and connect the battery to up to 3.7 volts. For a while, later your device can charge it further, by itself
Posted on Oct 06, 2008
Hi, my ZEN vision m: does not start anymore; when charging the blue light just "flickers", but even after 1 night charging, no possibility to get to the menu
The rapid-blinking blue light means that the Zen's battery is too drained to allow the player to turn on.
It can take 24 hours or more to completely recharge the Zen using USB. If you see the blue light blinking slowly when you plug it in, then the player is charging, and you will have to wait for it to finish charging.
If, after leaving the Zen to charge for more than a day, it still does not turn on, then the battery may be defective and not able to be charged anymore. The battery will have to be replaced.
May 16, 2010 | Creative Labs ZEN Vision:M Digital Media...
My zen wont turn on or charge up and I don't know how to reset it, is there a button??Its a creative zen v plus 1GB
Support site for the Zen V Plus, see:
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=15306&prodName=ZEN+V+Plus&bTopTwenty=1&VARSET=prodfaq:PRODFAQ_15306,VARSET=CategoryID:213
In the knowledge base solutions Creative gives next answer, when the player does not power on or charge:
To resolve this problem, establish that the player is charging correctly as follows:
  1. Connect the player to a USB port on the back of a desktop PC, to a powered hub, or to a power adapter ( You can purchase the power adapter here as a separate accessory).
  2. Press the reset button and observe the player.
  3. Check the display for the charging icon battery_ac_charge_1.jpg.
    • As the display times out after a few seconds, press any button on the player to reactivate the display.
    • If the battery is fully depleted, the charging icon may not be displayed. Cup the player in your hands to check that the blue power LED behind the Play/Pause and Options buttons is glowing on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed.
  4. Allow the player to charge for at least 6 hours. During this time, if charging from a USB port, please ensure your PC does not enter a power conservation mode (Standby, Sleep, or Hibernate) as this will interrupt charging.
Creative recommends updating your ZEN V or ZEN V Plus firmware to take advantage of new features and functionality. To learn more, visit SID 29048 in our "Further Suggestions".
Note: If the player does not indicate a charge, or will not power on after at least 6 hours of charging, please contact Customer Support.
Reset pin on the left side with the player facing up.
Manual (Multilingual, 17,2 MB) for the Zen V Plus :
http://files2.europe.creative.com/manualdn/Manuals/TSD/9851/0xE85A7F46/Zen%20V%20Plus%20Quick%20Start%20Multilingual.pdf
Nov 24, 2009 | Creative Labs ZEN V Plus MP3 Player
I can t put music on my creative zen it charges
Support for Zen Stone
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=16424&prodName=ZEN+Stone
From this page you can download the application software:
ZENStone_PCApp_CLE_L6_1_11_08.exe
With this software you should be able to get access to the Zen Stone.
Aug 04, 2009 | Creative Labs ZEN Stone MP3 Player
CREATIVE ZEN - NOT CHARGING
Go into your lab top and click on remove hardware safety.Find your zen the click remove..Next do not unplug it,shut off your zen then you should see instantly on the zen its charging...
Mar 31, 2009 | Creative Labs Zen V MP3 Player
Creative zen m series no charge
i was trying to charge my zen on a cpu at work that did NOT have the zen installation disc installed on it. the lightning bolt over my battery sign indicated my zen should have been charging, however it did not. later that night i plugged my zen into my own laptop at home, the one that i installed my zen to in the first place, and it worked fine.
Jan 13, 2009 | Creative Labs ZEN Vision:M Digital Media...
Trouble with my creative zen
this happened to my vreative zen also......... what i did is that i waited till all of the battery is gone then i just plugged it in my computer to charge and after that it was all good.....
Oct 15, 2008 | Creative Labs Zen Digital Media Player
How to charge my creative zen mp3 player
Just connect your Zen onto your PC (NOT LAP TOP) on a USB.
If does not start charging (you´ll see arrow and pause/ play buttons flashing slowly) then you need to RESET your ZEN.
How to reset: You´ll find a tiny little hole by on/off button on the side. With ZEN connected to the PC USB or onto wall charger try turning ZEN on, it doesen´t matter if it turns on or not. Then insert a sowing pin or office paper clip end in this reset hole for a few seconds and release. Give it a couple of seconds and see the lights go off onto charging mode. LEAVE IT CHARGING for 24 hours. Make sure your PC will NOT turn itself on safe mode or hibernates in this period, it has to be ON for charging, at all times.
This is it.
Louise Passalacqua.
Jul 08, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen stone 1GB low battery even after charging
go and delete some songs by this your zen memory is free.
and go to adjust power property and select the right power management for ur eqipment.
Jun 22, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen 8g
I have a zen V 1g, and it doesn't have to be fully charged.
Mar 20, 2008 | Creative Labs Zen V MP3 Player
Zen show charging but its not charging
are you using ac charger to charge? if so i would think the port has a bad connection or bad battery.
Dec 08, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
119 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
