Question about Lexmark C912 Led Printer
Lexmark c912 has 980 service switch error. Can you assist
    Genius:
  • 1,605 Answers
980 error code is internal printer error. This is beyond users capability.
turn off the printer and check all cable connections.
turn on the printer, you need to call lexmark service, if the error return.
Posted on Nov 11, 2008
2 Suggested Answers
  • 300 Answers
SOURCE: Lexmark C912 printer has a
980 - Face-Up/Down Switching Error, standing in front of the printer check the left hand side (the area between the fuser and where the paper exits the printer) you may find something stuck or some paper there
Posted on Jun 24, 2008
I have a Lexmark C522 printer and it has come up with an error : 140.01 Service Motor Error. What does this mean and is it repairable?
Please click on the link http://bit.ly/pABOH4 to see instructions on how to go about the procedure
For further assistance, please contact Lexmark Technical Support.
Jul 18, 2011 | Lexmark C522n Laser Printer
My Lexmark printer is showing 122.03 service fusher error what can i do
This error normally requires a service call. However, certain rare occurrences, such as a a power fluctuation or a stray static discharge in the vicinity of the printer, can cause a false 122.03 error message to appear. In these cases, the error is only temporary and can be easily resolved without service. Follow the steps in the table to test this.
Step Action 1
Power the printer off, wait ten seconds, and then power the printer back on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the page prints, the printer is functioning correctly. 2
If possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.
Yes: Continue to Contacting Lexmark below.
Contacting Lexmark
Please contact Lexmark Technical Support for additional assistance.
Jun 10, 2011 | Lexmark X543dn Laser Color All-In-One...
960 service memory error - a
The error indicates that the system board's on-board memory has failed. This usually requires a service call but you can try to turn off the printer, then turn on after 15 seconds. If the problem continues, I strongly suggest you contact Lexmark technical support or an authorized service provider for assistance. You may need to know your printer's model type and the serial number when calling for service. Thanks.
Sep 10, 2010 | Lexmark C530dn Laser Printer
Problems with the c760 900 service rip software error, can you help?
Perhaps this article on 900 Errors on a Lexmark C752, C760, or C762 will help. Just click on this link: http://bit.ly/c2xr1t. There are embedded links on the page for additional info. If you need further assistance, don't hesitate to contact Lexmark technical support or your authorized service provider.
Sep 02, 2010 | Lexmark C760 Laser Printer
I received an message 917.00 service transfer roll. How do I fix this ?
Here's an article on A 917 or 917.00 Service Error Is Appearing on a Lexmark T640, T642, T644, or an X64xe Series Printer. Just click on this link: http://bit.ly/aQD8jS. Follow the recommended actions. If error won't clear, printer may require service. Don't hesitate to contact Lexmark technical support for assistance. Thanks.
Aug 06, 2010 | Lexmark T640 Laser Printer
Code 936 - Service transport motor Lexmarx E350D
Here's an article on 936 and 937 Service Main Drive Motor Errors in the Lexmark website. Just click on this link: http://bit.ly/dtbJKt. If all else fails, the printer may require service. I suggest you contact Lexmark technical support or your local service provider for further assistance. thanks.
Jul 23, 2010 | Lexmark E350d Laser Printer
994 service density sensor
The 994 Density Error indicates that the printer's system card has encountered an unrecoverable error. The 994 Density Error can be caused by the density sensor becoming dislodged from the sensor board. This normally requires a service call. However, for basic troubleshooting, try powering the printer off, wait ten seconds, and then power the printer back on. If still no go, if possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages. If problem persists, I strongly recommend contacting your Authorized Service Provider or Lexmark Technical Support for assistance. I hope I can assist you more on this.
May 10, 2010 | Lexmark C912 Led Printer
Printer lexmark C510," 956 service TCSD system board"
With that " 956 service TCSD system board" error message, the only you can do is to replace the Rip/System Board. Hope I can assist you more on this.
Apr 06, 2010 | Lexmark C510 Laser Printer
Lexmark t644 error code 917.00
This error indicates that there is a charging problem with the transfer roller. You could start by cleaning the contacts for the transfer roller (power off printer first). The transfer roller is the black foam-like roller under the toner cartridge. Handle it with paper because the oils on your hand could damage it. To remove it, just pry under the far left side with a screwdriver. Lift and pull to the left to remove. If this does not fix it, then you have a more serious problem. It could be one of the arms or the HVPS.
May 07, 2009 | Lexmark T642 Laser Printer
"981 Service Switch Error" and "994 Servise Density Sensor"
these are internal error. beyond user capability or repair
turn off the printer and check all of the cable connections.
turn on the printer, you need to call lexmark service, if the error returns.
Feb 17, 2008 | Lexmark C912 Led Printer
Lexmark C912 Led Printer Logo
510 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
