Question about Maytag MAH6700AWW Neptune Front-Load Washer
Grinding noise I love my new washer. It works awesome and I make sure to only use the HE soap in it. I don't know what it is, but there is a really bad grinding noise every now and then...I have noticed it at times when the machine is barely getting started as well when it is going at full speed. Everything else seems to be ok, other than this morning, it did not ring the clothes out all the way, so I had to set it to a spin only. Which it did not like. It made the same tired, grinding noise. I have only had this washer for about 6 months. It does get daily use of at least 1, but no more than two loads. ???? HELP! I do not have money for a repair man.
It is a new machine, please check your warranty. This kind noise, it will cover.
Posted on Jun 25, 2008
Washer makes loud grinding noise when turned on. We believe it is a problem with a belt, but we don't know how to remove the back panel to check.
The grinding noise you get is from the worn out ball bearings. Replace them. You can open the back cover by removing the screws. To fix new bearings remove the pulley & then the bearings.
Jun 15, 2011 | Washing Machines
Whats a really good smelling perfume for teenage girls to buy?
Victoria's Secret PINK "fresh & clean"smells awesome and is cheap. They also make lotions and soaps in the scent.
Nov 23, 2010 | Dana Perfumes Loves Baby Soft by Dana Eau...
Whirlpool washing machine makes grinding noise
Hello Friend, Your solution is a real quick fix. The problem you are having is very common, your motor coupling has broken and that is what's making the grinding sound, also in this condition it will always pump out the water. Go to your local appliance parts store and purchase a new motor coupler, your cost should be under $25. It's very simple to remove old and install new coupler. First remove two screws from control panel and tilt control panel backwords exposing area under panel. You will see a metal clip on each side of cabinet under panel. Remove these clips, and unplug wires from plug in on cabinet. Remove cabinet by lifting up in back and tilting forward. Once removed you will see the innerworkings of your washer. Lay washer on it's back and remove the two spring clips that hold water pump in place and remove water pump. Leave water pump hooked up just move to side out of your way. Then you will remove the two screws that hold the motor clips in place and just snap the motor clips off. Be sure to unplug the wire harness plug from the motor. Just simply lift the motor straight up and off of the transmission. There you will see the motor coupler broken and to replace, just pry old one off transmission and motor with large flat head screwdriver. You will notice that one half of coupler is attached to the motor and the other to transmission. In the coupler kit you will receive both pieces and the rubber center connector. Just replace all the old with all the new and your problem will be solved. Happy to help, Tim.
Jun 20, 2009 | Whirlpool Washing Machines
Washer loud grinding noise spin stop
if its brand new it shouldnt be making a loud grinding noise id get it checked make sure they removed all shipping bolts
May 17, 2009 | Maytag Washing Machines
Nextra7 condenser dryer making squeaky noises
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Feb 14, 2009 | Hoover Nextra 160 HNWF 3137 Front Load...
Roper washer not draining
okay you say coupler was broken, make sure coupler is on properly, and make sure your pump is clear of debri, sounds like you washed something heavy, make sure your pump is also clear
Apr 03, 2008 | Roper RAX7244KQ Top Load Washer
Washer making noise in spin cycle
Is this unit new? I had a frigidaire that would really get to going on the spin cycle. Got the clothes really dry and sounded like a jet engine if no clothes were in it. Is it a whisling sound or screeching sound...The sound could be coming from the water pump. It may have something in it that is dragging. Some you can take the bottom off of and clean them out..
Feb 10, 2008 | Washing Machines
Washer LAT9206BAE
the agitator shaft has come loose from the transmission. when you pushed it back down it probably didn't seat properly, thats why the grinding sound. you need a new transmission
Nov 14, 2007 | Washing Machines
Maytag MAH6700AWW Neptune Front-Load Washer Logo
121 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
