Question about Mad Dog Multimedia Computers & Internet
DVD burner replaced old unit in e drive position and now f drive doesn't appear in my computer
  • 31 Answers
Make sure both aren't set as Master, check that you didn't accidently unplug either the power cable or ide cable. If that doesnt do it load into the BIOS and see if its showing up there if not try changing out the cable. But short of a drive failure or port failure it should be one of those.
Posted on Jun 30, 2008
Bad hard drive
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Mar 20, 2012 | Dell Vostro 1500 1700 / Inspiron 1520 1521...
Computer BIOS recognizes the SATA DVD Rewriter but Windows XP does not. The drive opens the loading door but it does not appear in the Windows XP explorer (My Computer).
Windows XP doesn't nativey support SATA. Check in BIOS to see if your motherboard supports sata to IDE emulation.
Comment back if you need further assistance.
Aug 17, 2011 | LG GH24LS50 Super Multi DVD±RW (±R DL) ...
I need to work properly with my acer 1610a cdrw in win xp sp3 i have a disquette with the drivers but after installing them the device continues been unrecognized .. when i open the windows explorer the...
Hello mirelycas Hi, check your power plug at the back of the drive and see if its loose, If you have done this, most likely you have a bad drive. Does the drive appear on the BIOS screen? Does the Drive appear on other computers? The common caused of undetected drives would be
  • bad logic board
  • improper bios setup, not enable
  • loose power cord
  • loose solder on the power cord
  • faulty data cable
  • Virus infection
Make sure that all above list are good, if not, you may need to replace the drive.
Feb 26, 2011 | Acer CRW 1610A CD-RW Burner
It says system boot up fail
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 26, 2011 | SySTOR Systems (410S16) Burner
Sony DVD unit not reading DVDs
try to clean the drive's lens with a lens cleaner CD ...
Oct 16, 2009 | Sony DRX-S70U-R DVD±RW Dual Layer Burner
Drive will not read cd rom, reads dvd and audio
CD rom drive is dead!
Time to go out and buy a new one. Rough cost is anywhere for a DVD BURNER is $25 - $40.
DVD burner are now the mainstream drives replacing CD roms.
But if you can still get a replacement CD rom from a computer in town should be cheaper than a DVD burner.
DVD burner can read and write DVD's and CD's.
Aug 14, 2008 | Pioneer Computers & Internet
Samsung DVD±RW Dual Layer
With the price of those units, it's usually cheaper to replace them. You could check with Samsung and find out if it's still covered under their warranty.
Theres
Jul 16, 2008 | Samsung (TS-H552B) DVD±RW Dual Layer...
My LH20A1p186c Lite on dvd writer will not do anything. A simple swap into my comp with 3 cables and the comp. does not recognize the new hardware. In fact both dvd and old cd player appear tp be one...
Check the Master Slave jumper on the back of the drives. If using 2 drives on 1 cable, make sure one is set to master and the other is set to slave. The jumper positions usually are labeled on the top of the drive as "M" and "S"
If you have them set to the same, both drives won't work.
If the drive is sharing cable with a hard drive, try changing the M/S setting.
Mar 31, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
Drive Mechanism Replacement
To figure this out you must look and see if Samsung offers mac osx compatible drivers for this unit. Ther in lies your answer.
Aug 17, 2007 | Pioneer DVR-S706 External USB/FireWire...
DVD BURNER DISAPPERS FROM "MY COMPUTER"
You can try using the ide cable connector that the other drive is on and swap them round just to illiminate the cable connector, but at the end of the day i think your DVD burner is faulty and requires replacing, as they are very innexpensive to replace as you wili probably know,so don't waste too much time trying to solve it. The drives dont last as long as they used to because, keeping the price of burners down, like anything else means cutting corners and costs and in burners cases as was the case with PS2's the lasers are cheap and soon fail.
May 06, 2007 | Sony DRU-810A DVD RW Dual Layer Burner
Computers & Internet Logo
43 people viewed this question
Top Mad Dog Multimedia Computers & Internet Experts
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
Are you a Mad Dog Multimedia Computer and Internet Expert? Answer questions, earn points and help others
