Question about Sony Playstation 3 (PS3) Console
No video power button lights tryed new cables no video display
  • Anonymous Apr 16, 2009
    power button lights up and discs load but there is no menu screen or ANYTHING! HELP!!!!
  • 282 Answers
You might check this out
http://www.us.playstation.com/Support/PS3/Troubleshooting/s_ps3_hs_dt.html
Posted on Jun 24, 2008
    Problem Solver:
  • 35 Answers
PS3 is The amazing device by sony but it has some common problems like sound , video problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Posted on Mar 12, 2009
My Playstation will not display anything when using a HD cable. It works with a regular AVI. It worked fine at the start. I have tried ressetting the display option but it has made no difference. I have...
Hi there, what you need to do is reset the video display. Try these following steps :-
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep once when you first press it, then again 5 seconds later. When you hear this second beep let go of the power button.
Step 3. Wait for your PS3 to start up
Hope this helps and thank you for using FixYa
Sep 08, 2010 | Sony Playstation 3 (PS3) Console
New generation ps3 system on but no video
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jul 01, 2010 | Sony Playstation 3 (PS3) Console
I have a playstation 3. there is power but no communication with tv. i have tried new rc cables as well no luck please help. tnx
Jun 28, 2010 | Sony Playstation 3 (PS3) Console
Turns on PS3 you can hear the loading music at start up but there is no video being displayed, tried replacing av cable with a new one same thing happens with new cables, my guess is its the console its...
follow these simple steps to solve your PS3 problem :
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Apr 22, 2010 | Sony Playstation 3 (PS3) Console
Replaced lcd display for dell 1525. need help!
Try re-connecting/re-seating the video cable/connector again.
Feb 13, 2010 | Dell Inspiron 1525 Notebook
While on vacation switched to 1080 now home and have regular tv now cant see to get back to regular. Im to the far right of menue. Need to know many to go right, down, button to hit to enter and then how...
Try resetting the video output. Follow the steps below:
  1. Before changing cables, make sure the PLAYSTATION 3 is turned off using the main power switch on the back of the PLAYSTATION 3 (the 0 side is pressed down).
  2. Unplug the power cord of the PLAYSTATION 3 and television (or display) from the wall socket.
  3. Make sure the AVI cable is connected to the [AVI OUT] port on the back of the PLAYSTATION 3 system.
  4. Connect the other end of the AVI cable into the [AVI Input] port of the TV or display monitor.
  5. Plug the PLAYSTATION 3 and television (or display) back in to the wall socket.
  6. Turn the main power switch on the back of the PLAYSTATION 3 back on (the line on the power button is now pressed).
  7. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  8. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Thank you for using fixya!
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
HP Pavilion dv2500 no display when power lights not blinking
Hello
To get the display on the TV . Please press Fn + F4 after connected TV to the Notebook using Svideo cable and the cable should be connected to the Svideo port of the Notebook.
If there is not display on the Notebook after the Svideo cable burns.
Then please perform the following steps.
= Power Drain =
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and Battery.
5. Turn on the Notebook power.
If the issue persists then check whether the display is same on the external monitor.
I hope this will work.
Thanks
Aug 24, 2008 | HP Pavilion dv2500t Notebook
No display on screen and solid amber light on pcs' power button
Well hate to say it but that sort of problem results from a faulty motherboard or processor so if you say that you have changed the motherboard then you problem lies with you processor chip.
Jun 06, 2008 | Intel D865GBF Motherboard
it seems to be an issue with the power supply as you already tried replacing the motherboard
power supply will be less expensive do try to get it replaced first
do check that monitor iss fine
unplug the blue VGA cable which connects your monitor to the tower
if a 4 colored box moves all over the screen the monitor is fine
and if it doesn't
get the monitor either repaired or get it replaced.
Jun 06, 2008 | Intel Motherboard
To el_cid_132: Did you mean to say a solid amber light on the MONITOR's power button? If, after all you've tried with the computer, you still have no display, it's a pretty good bet your monitor is bad. Try another monitor to verify the computer function. Take a close look at the pins in the monitor's input cable plug. They are pretty easy to bend, and you may have one not making contact.
To Jaffe: It's a simple job to remove the hard drive from your laptop and hook up to another computer to copy anythig off that you want to keep. I don't know what a shop in your area would charge, but it should be reasonable. As for replacing the system board, a quick Google search for "MX6448 motherboard" turned up several sources, price range $250-$300. Usually it's not worth putting a new system board into a laptop unless it's a very high-end model. You can buy basic laptops now for around $400, and you'd be getting brand-new with a warranty.
Jun 05, 2008 | Gateway (4000779) Motherboard
Sony Playstation 3 (PS3) Console Logo
171 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
