Question about Acer Aspire 5000 Notebook
Shuts off at boot up screen?
So everytime i try to turn on my laptop, it will get to the Windows XP loading screen...and after a minute or so just shut down...and restart itself, and will keep doing this until it runs out of battery.
The fan has been replaced and that made no difference, and i tried disabling the automatic restart on system failure and it just blue screens....hellllp?
  • bethanyliz Jun 27, 2008
    is there a way to tell what exactly it is?...so i could replace it?
  • 20 Answers
Start the computer in safe mode (tap F8 immediately after turning it on until you see the option of how to boot)
If it successfully boots into windows, you have an issue with either driver conflicts and/or viruses. If it still restarts itself, you most likely have a hardware issue (bad hard drive, motherboard, etc)
Posted on Jun 25, 2008
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
Looking for assistance. My father is having some
unfortunatly without a windows xp cd to do a repair reinstall or use the advanced recovery, there is nothing that can be done for this. This is a problem that requires that as part of the solution.
Feb 12, 2010 | Toshiba Computers & Internet
Everytime i switch my toshiba l300 laptop on just goes to windows is loading files then i get bluey grey screen with system recovery box saying installed program cannot start turn off im running windows...
Download "Hiren's Boot cd".Burn the ISO images in a disc.Set your BIOS to boot using that disc.Select Mini windows XP.There you can have all the repairs tools pre-loaded.If none of the tools able to fix then you can always backup your important files and doa new re-installed.
Here is the link of lastest Hiren's Boot cd
http://d2.hirensbootcd.net/Hirens.BootCD.10.1.zip
You try to remove all the program during startup using that disk with "msconfig" command.
Let me know if it work out for you.
Dec 27, 2009 | Toshiba Satellite Pro L300 Notebook
Media drive not found my laptop is toshiba sat a45 s150. after turning it off unsuccessfully, a blue screen error was displayed. if long pressed the power button to shut it down. after opening it again,...
Most likely the boot sector is corrupt.Try to boot by starting the Computer and hitting F8, or F12 you need to get to your start windows splash screen.Then try Start Windows from Last Known Good Configuration.If that don't work try Safe Mode.If none work you will need to recreate your .boot file, or try recovery fron CD.It gets complicated explaining how to rebuild your boot sector,If you have access to internet search "how to rebuild boot sector Windows XP".There are programs you can download and then load/run to rebuild boot.This has happened to me or someone I know and it is a pain to fix.You need some knowledge of how boot loads and how to repair.Try to get someone you know to help you.The problem was caused by the shut down.I think you ment XP can't Boot.Good Luck
Sep 11, 2009 | Toshiba Satellite A45-S150 Notebook
Shutting down at setup blue screen
even thoough it isn't the original cd that came with the the lapop it should still install.
make sure you clean the lens of the dvd drive with a damp q-tip of water and then gently clean it with a dry q-tip. This will ensure that the laser of the drive is nice and clean and free of dust or lint.
Then make sure there is no smudges of dirt or dust of on either sides of the cd so that way there can't be no write errors due to this.
Now see if you can install windows xp. If you still can't install windows xp then its because the hard drive is bad and needs to be replaced.
Aug 21, 2009 | Acer Aspire One AOA110-1588 Notebook
Cannot start up the laptop
Hi there.
That really quick flash of a blue screen is the blue screen of death and there is a possibility that the error could be memory related.
What you have to do is remove and clean the system memory and the slots the memory goes into.
Take out the battery and the AC power (if attached)
The memory will be located behind a panel underneath the laptop, unscrew the panel unclip the memory, clean the brass contacts and the slots with a clean, dry, soft paintbrush, then reseat the memory making sure it clips into place, replace the memory cover and reboot the laptop, see if it lets you into windows.
Please post back with the results and more help if needed, good luck and thanks for using FixYa!!
May 20, 2009 | Toshiba Satellite A105-S171 Notebook
Randomly lost display on my pc.. and its not a faulty card.
Try to set your PCI-E card as a first one in BIOS. There also should be an option to turn off onboard video.
Mar 07, 2009 | Gateway GT4022 PC Desktop
Boot up menu restart; will not power
Boot up to the safe mode screen & select last known good configuration.
Jan 15, 2009 | Gateway 4026GZ Notebook
Acer Aspire 5050 Won't Boot.
Your problem could be windows vista isnot installed properly
i assume in the beginning, your laptop come with windows xp.
if you want to go back to windows xp, you can still use alt+f10, as long as you don't delete the recover partition.
Just boot and press Alt+F10, it'll give you recover screen.
Mar 20, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire 5000 Notebook Logo
193 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
