Question about Denon DN-C635 CD Player
Denon C630 CD Player
My Denon 630 does not recognise some Cds while they play perfectly well in other players, Sometimes when it does cue a track it plays with a lot of crackling noise, Does this model have a problem with power supply?
3 Suggested Answers
cdj repairs
  • 68 Answers
SOURCE: Denon cd player skipping on some track/cds
This could be a possible worn laser pick-up problem.
Regards.
http://www.audiovisualservices.info/
Posted on Dec 13, 2008
  • 135 Answers
SOURCE: cdj 1000-mk-2
Could be either the Track skip switch has collapsed and is thus over sensative or the button bank is broken and the track skip switch is being pressed when the cue button is used.
Could also have liquid spillage on the circuit board which cause all sorts of random problems
Posted on Sep 06, 2010
How can I fix a slot-loading cd player that skips without taking it apart?
Look inside at the laser carriage. You should see a grooved track. Check that none of the teeth are damaged. They should be in perfect condition. If they are not the lens unit will jump during playback. It could also be caused by too much grease or dirt, or too little grease. Clean the track if you can see too much grease or dirt. If it looks dry, you can apply Silicone Grease, which you can get on-line or in electrical parts shops, such as Maplin if you are in the UK.
Dec 01, 2017 | Denon Audio Players & Recorders
To Determine CD recording problem: Track1 records and plays back O.K. Upon completing track2, display window flashes continously "Now PMA" (Updating disc contents) NO playback or sound on track 2.
It is possible that until you finalize the disc, the only track that will play is the first one. Unfortunately, once you finalize the disc, you cannot record additional tracks to it. You can verify this by finalizing after recording the second track and seeing if they then both play. If that works, you can safely burn additional discs with confidence that they are burning correctly even if you cannot play each back after burning and must wait until finalization to test full burn.
Sep 26, 2016 | Denon CDR-W1500 2-Disc CD Recorder
I have a Denon DCD820 from the late 80's. This week I wanted to reuse it after remodeling my house and putting it aside for one year. When inserting a cd, sometimes it starts spinning and the shows the...
Couldn't find much for that specific Denon model but there is lots of info on basic CD player trobleshooting. If this video isn't helpful, do a youtube search or google "cd player troubleshoot"
Jan 08, 2015 | Denon Audio Players & Recorders
UCD 110 - Doesn't recognise every CD and will only play some CDs. I've tried cleaning the player with a CD Cleaning disc but to no effect.
I've had the same problem with a denon ucd 70,had the laser replaced and still the problem remained.Finally it appeared that a little wheel which moves the laser over the disk was broken and therefore the entire system finally couldn't read any cd anymore It started with some cd's however.
Still looking for a replacement wheel and fear that I have to buy a full new laser unit
Sep 24, 2009 | Denon Audio Players & Recorders
Regards.
Nov 28, 2008 | Denon Dns1000 Table Top CD Player CD...
Cd player not playing some cds: denon cd player ucd-77
try cleaning your not working cd with soap and water, and dry it with paper towel. tnx
Jan 30, 2008 | Audio Players & Recorders
How do I copy a CD on my denon CDR-W1500
Operating instructios can be downloade here:
http://www.retrevo.com/s/Denon-CDR-W1500-CD-Players-review-manual/id/363ci860/t/1-2/
10 COPYING PROCEDURE
About copying
 Copying can be performed easily from the set’s CD unit onto the CD-R unit.
 There are two copying speeds (normal and high) and four copying modes.
• The mode switches as described below each time the normal speed copying button (NORMAL) or the high speed copying
button (HIGH) is pressed.
• The recording level is automatically set to the default value (0.0 dB).
• The repeat and random play modes are canceled when the copy mode is set.
• During normal speed copying you can listen to the sound as you copy.
• During high speed copying no sound is produced.
• No signals are output from the digital outputs during high speed copying.
• During copying, buttons other than the CD or CD-R stop buttons do not function.
• When CD TEXT compatible CDs are copied, the disc names and track names are also copied.
 When copying, switch the relay mode to the normal or dual mode. Copying is not possible in the relay or mix mode.
 For optimum recording, make sure there are no fingerprints, scratches or dust on the signal surface of the source side CD or
the CD-R/RW.
 The auto track function is always activated in the copying mode. It is not possible to assign track numbers manually.
Disc dubbing: In this mode, entire CDs can be copied onto CD-R/RW.
(“All Tr Dubb” is displayed.)
Make CD: In this mode, entire CDs can be copied onto CD-R/RW then finalized automatically.
(“Make CD Dubb” is displayed.)
1TR dubbing: In this mode, single tracks on CDs can be copied.
(“1Tr Dubbing” is displayed.)
Scan REC dubbing: In this mode, the desired tracks can be selected from CDs and copied.
(“Scan Rec Dub” is displayed.)
Jan 14, 2008 | Audio Players & Recorders
Cdj-500ll cue button repair
the faulty button will not stop it from playing well... replacing them is not hard so long as you have some experience with a soldering iron.
Clean the laser lens with a cotton bud wet with windex... then use a dry one to be sure no residue is left. If it still mistracks... new optics required!. You willl need a pioneer service agent to do this for you. A little complex for the first timer :)
Jan 08, 2008 | Pioneer CDJ-500II CD Player
Denon DN-951FA
Push your "track selector knob" IN towards the unit and hold it in while pressing and releasing your STDBY/CUE button. This resets the microprocessor (kinda like rebooting) the unit. If you want to speak to me further about your 951fa, email me at chris at cueblip dot com Thanks!
May 04, 2007 | Denon DN-951FA CD Player
Denon DN-C635 CD Player Logo
246 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
