Question about PC Chips M955G Motherboard
Pcchips my board when down and doesnt want to turn back on when i press the power button it turns on load up the post and then turns off
NESCESITO DRIVER DE AUDIO
Posted on Jun 30, 2008
My tablet wont turn on it continues to blink but wont turn on
Try using a paperclip to reset it on the back, hold it in for 5 seconds, if that doesnt work:
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
Apr 20, 2013 | Coby kyros Tablets & eReaders
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Doesnt turn on correctly
Soft Reset
To force the device to restart without wiping any data, simply press and hold the Power button for about 10 to 20 seconds until the device turns off. You should then be allowed to turn the device back on as normal.
Hard Reset Using Buttons
Note: A hard reset deletes data. Before performing these steps, be sure to backup your data if you wish. Some data can be backed up under Settings > Privacy > Back up my data and data that syncs with Google should re-sync once you have performed the reset as long as you use the same account.
1. With the Galaxy Note powered off, press and hold the Volume Up, Volume Down and Power buttons.
2. When you see the Samsung logo appear, release the Power button, but continue to hold Volume Up and Volume Down.
3. Release all buttons when the System Recovery screen appears.
3. Toggle the selection to highlight wipe data / factory reset using the Volume Down button.
4. Press the Power button to choose the selection.
Jan 24, 2013 | Samsung Galaxy Note 10.1 Wifi 10.1-inch...
Crosley CAWC529PQ1 won't turn on.
First, you'll need to make sure you have the proper voltage at the outlet, and the power cord terminals fit tightly into the outlet slots. Based on your post, you most likely have a faulty electronic control board.
Here is the board to order.
Nov 25, 2012 | Crosley CCW5294W Top Load Washer
My LG pdp42x3 plasma doesnt turn on.
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Oct 02, 2012 | Cell Phones
My LG washer powers off completely after running through a cycle. The only way to get it to turn back on is to either unplug it from the wall or flip the breaker. It doesnt seem to be throwing the...
I had the same problem with my LG washer today. I found another post that said to hold down the start pause button 5 seconds, plug back in so you have power, run on drain/spin at highest spin speed. I did it and so far after each load it has not shut down.
Jan 26, 2011 | LG WM-2277HW Front Load Washer
LCD TV samsung LN40A450 doesnt turn on
hi,
your lcd ip board (power board) capacitor had already exhusted.
got to replace the ip board.
Jan 18, 2010 | Samsung LN40A450 LCD TV
Conputer won't power on
Hi there.
Remove the power adapter and the battery, plug in AC power and hit the on/off button, if it powers up wait for the OS to load up and the shut it down again, put the laptop battery back in and power it up.
post back with the results please
Good luck and thanks for using Fixya!!
Feb 23, 2009 | Dell Inspiron 8600 Notebook
Laptop is nmot working
hi,
welcome to fixya,
as u said that ur laptop is not working and it is not booting,i mean is it a dark screen or do u see the lights on the computer,can u clarify me pls...u can try and safe mode and if it doesnt load in safe mode then what u can do is that disconnect the ac adaptor and take out the battery and then without ac adaptor and the battery press and hold down the power button for one minute and then release the power button and then connect the power cord and put the battery back in and then turn on the computer,and if still it doesnt turn on then try and connect with the different wall outlet and if still doesnt turn on then try with the different ac adaptor and still if it doesnt work then replace the motherboard and the ac adaptor.
Feb 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
OVERCLOCKING
Hi, On other motherboard models of Asus, similar problem was corrected by: 1. Updating the BIOS; 2. Actually overclocking the FSB to slightly higher than default (say 170 or 175 from 166, 140 to 150 from 133); 3. Slightly increasing the default processor voltage supply by increments of 0.05; 4. Replacing the 3.0 volts Lithium battery; 5. Replacing the memory to next higher speed; Never had problems like this with MSI, ECS or Intel boards. Hope this be of some idea/help. Post back how things turned up or should you need additional information. Good luck and kind regards.
Oct 05, 2007 | ASUS P4S800D-X Motherboard
PC Chips M955G Motherboard Logo
112 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
