Ricoh Ft 3713 Toner light still on
OK - I was using your instructions as you said, but when I enter in the 96 on the keypad it blinks. You say to press print and cut the copier off then on. Call me stupid, but I do not have a print button. The start button, I would consider is the print button??? But when I push this, nothing happens. Any further instructions for me to try to get the toner light to go off??
I really appreciate your help so far. Thanks
    Problem Solver:
Try to enter 65 or 66 and let it free run for bout 20 copies...after that switch it off then on again...u can make it a try.
Posted on Jul 30, 2008
2 Suggested Answers
  • 1326 Answers
SOURCE: toner light will not go off
Did you remove the tape from the toner bottle when you installed it? It may just be looking to add toner back to the developer, to bring it back to the set level of toner? See if it stops
Posted on Apr 30, 2008
How do i add developer toa ricoh ft 3713?
Vac and clean the developing unit then replace the developer
but if the case is developer spilling we need to replace the 4 bushings and seal then replace the developer
Aug 22, 2011 | Ricoh FT3713 Copier
Error code E-22 in RICOH FT3713
· Scanner home position sensor failure
· Defective scanner motor
· Defective main motor
· Defective dc power supply board
· Incorrect scanner drive wire position
· Defective dc harness
· CN103 or CN105 on the main board is not correctly connected.
· FU202 on the dc power supply board open (blown fuse).
Jan 08, 2010 | Ricoh FT3713 Copier
Ricoh ft 3713 error 54
Clean the thermistor and clear the code by turning on both dip switches on the main board, turn off the main switch, turn off the dip switches, turn on the main switch.
Mar 26, 2009 | Ricoh FT3713 Copier
Ricoh Toner for FT3313 and FT3713
When the developer is the same the toner is the same.The toner drops in to the developer,thus the toner must be the same.They just package it different to be a pain!
Nov 20, 2008 | Ricoh FT3713 Copier
Your copier may need developer if the cycle count is over 150,000 copies. Once that is added to the toner the Toner/Developer sensor should be calibrated and should work fine.
Sometimes the drum can create light copies if it was exposed to light from being out of the machine or leaving the door open too long on the side of the machine letting light in.
Aug 24, 2008 | Ricoh Office Equipment & Supplies
Emptied toner waste and now I'm supposed to do an Sp 83 or Sm 83 to clear the counter?
ok, you need to enter service program as follows Press 7 key.Press 1 key.Hold down the stop/clear key until you see "." in the upper left corner of the display. Release the clear/stop key. press the clear/stop key again. Press the lighter key. The number "5" will now flash in the display.Enter "96" using the number keys.When you have enter the code,Press Print, cut copier off then on.
May 12, 2008 | Office Equipment & Supplies
Added new toner but light won't go off. Ricoh FT 3713
The TD sensor got disconnected or is broken, the copier needs service because it's not detecting that it actually has enough toner inside to copy.
Apr 30, 2008 | Office Equipment & Supplies
Toner light will not go off
Apr 28, 2008 | Office Equipment & Supplies
Assembly of Ricoh color laser printer - error message
On the Ricoh 3713 you can do a hard reset by going on the main board toggling dip switch 101-1 on and then off, entering 97, pressing the "aps" key, and then power cycling the printer. Might work similarly on the CL3500N.
Apr 04, 2008 | Ricoh Aficio CL3500N Laser Printer
56 people viewed this question
