Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Magnavox ptv835 I picked the tv up on the side of the road for free, hoping it could be an easy fix. The guy I got it from said the tv was given to him and at first it worked but the picture was dull and at some point went away all together. After I got it, I plugged it into the wall without being plugged into cable, satilite, ect. The set turns on but only will turn off with the remote from what i can figure out, and also there is no sound or picture which I would think that without being hooked up to a provider it should be static. I've tried to do as much research as I could before asking. The only problem I have found that it might be is a bad IC chip thingy. Im thinking about getting the magnavoxhelp.com repair kit, but I want to be sure it'll fix it before i buy it. Any help I can get would be appreciated. Thanks in advance
  • 4 more comments
  • Jeremy Bozarth
    Jeremy Bozarth Jun 25, 2008
    The model number is M - 9p6034 c103
  • Jeremy Bozarth
    Jeremy Bozarth Jun 27, 2008
    Ahhh thanks!
  • Jeremy Bozarth
    Thanks for the reply. Anyone else with any suggestions?
  • Jeremy Bozarth
    Jeremy Bozarth Jun 28, 2008
    Could anyone else confirm this for me?
  • johnnynamy Aug 23, 2008
    no picture, no sound, power light will turn green when turned on
    johnnynamy@hotmail.com
  • Mike Owens
    Mike Owens May 11, 2010
    First step would be to post a model number
  • Philips Master
  • 3,459 Answers
Easy fix. Its a bad IC chip as you suspected.
See www.magnavoxhelp.com for the solution
Posted on Jun 26, 2008
Phillips magnavox P960349102 model#PTV835
If its shrinking this is and easy fix...Goto the site www.TvRepairKits.com and get there shrinking video kit for your model.
As for the colors they are likely just washed out which is due to the CRT coolant. The same site has repalcement CRT fluid for your projection TV also.
Feb 09, 2013 | Philips Magnavox 9P6034C 60" Rear...
I have a Phillips magnavox P960349102 model#PTV835. I have power no picture or sound. How do I fix this?
Have power/deflection board rebuilt. Probably will not last long from my experience. In reality this model is too old for a good, reliable fix (like CTC167 in RCA is too old for a good fix, and Hitachi pincushion circuits).
Jan 18, 2011 | Philips Magnavox 9P6034C 60" Rear...
PTV835 PICTURE SHRINKS
Hello, I dont have a solution but I am experiencing the same problem. Did your tv get fixed ? Any solutions that you can offer ? Rudy
Jan 13, 2010 | Philips Magnavox 9P6034C 60" Rear...
Can You PLEASE help me
Common problem and fairly easy to fix.
Problem
Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Solution:
Check with the site www.TvRepairKits.com. They have built a kit to fix this problem.
Jan 22, 2009 | Philips Magnavox 9P6034C 60" Rear...
No pic. or sound but power light is on
Most likely the blue picture tube arched and shorted out the horzontal output transistor.Very common problem with this chassis.Now if you have an electronics background you can most likley fix it, if not you will be dealing with finding a high voltage leak consisting of 31,000 volts which can kill you.That pop you heard was the high voltage leaking to ground.
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
No sign of power on my Phillips Magnavox rear projection TV
try replacing the fuse. it should be behind the bottom panel near the power cord
Nov 17, 2008 | Televison & Video
NO PICTURE HAS SOUND
I had the same problem. Check www.magnavoxhelp.com for instructions on how to fix it.
Jun 23, 2008 | Philips Magnavox 51MP392H Rear Projection...
My 60" Philips Magnavox, model 9P6034C103, chassis PTV835
It could be the flyback losing resistace in its windings. What is the chassis number I should have the service manual for it. Phillips/magnavox is hard to cross reference without the actual chassis number.
Feb 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
TV turns off/on by itself
thats why you got this TV for free I'm afraid. Your problem will cost more then the set is worth to have it repaired. Unless you understand how the differant circuits work, and know how to read a schematic, follow the circuit flow, and use a multimeter, this will not be an easy fix for you to do. There are components in the power supply that need to be replaced. Good Luck
Jul 21, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
201 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
