Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Washer makes a thumping sound
When washing towels on the "quick wash" cycle, when agitating the machine makes a thumping sound on the side. I had the repairman out and he ran it through diagnostics and couldn't find anything. Something is not right though. Any ideas
    Genius:
  • 1,028 Answers
You indicate problem happens on quick wash how about cycle designed for towels ? the control bd on cabrio is programed for loads based on each setting the speed and torgue for motor is controled by the bd and trying to use on settings other than those programed towels may indeed cause problems ..try different cycle and let me know thanks
Posted on Jun 25, 2008
My machine is a few years old, I don't use it very often now, how do I make sure it's clean and not harboring bacteria?
I would keep the washer lid open and the agitator and drum dry. However, you will have to, from time to time clean the machine.
Run a full cycle (tub empty of garments) with hot water and Clorox or other liquid disinfectant. Then air or towel dry the inside components. Read the manufacturer's cleaning instructions that came with your owner's / user's manual.
Feb 24, 2017 | Washing Machines
Washer squeaks during agitation, both wash and rinse. also makes thumping sound for few seconds after spin cycle stops.
Hello Chris, thank you for your post!
I see that the washer on your Frigidaire laundry center is squealing during agitation. This noise could be coming from the motor or transmission and you may need to have the washer disassembled to locate which component may be causing the issue. For proper disassembly you may need to seek assistance from a professional technician. A technician will have the appropriate tools needed for complete disassembly of the washer without causing personal injury or harm to the laundry center. Hopefully this information is helpful towards your repair. -Matt
Apr 20, 2016 | Frigidaire fex831cs stacked washer&dryer...
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
My washing fills and drains properly, but will not agitate or run the spin cycle. I sounds like it is going through the cycle properly, but will not turn the drum (spin cycle) or agitator.
Try picking a different wash cycle, instead of your annual quick wash cycle opt for the longer wash cycle and then you may find that the spin cycle may kick-in, hope this works for you, good luck!
Apr 17, 2011 | GE WBSR3140DW Top Load Washer
Washer makes a steady thumping sound
Could be coin in pump hitting blades...Try pump only no spin this will discount the drum ....Check filter if you have one.
Apr 08, 2010 | Washing Machines
Spin cycle tub becomes unbalance
When the drum gets unbalanced more often then not, there's a few things to check:
1. Check to make sure your machine is level. Check level from side to side and also front to back. The machine has leveling feet to adjust. Make sure they are all in firm contact with the floor when leveled.
2. Wash items that are alike in material. In other words, wash towels with towels, shirts with shirts, etc. If you wash a load of shirts with a towel, it will have a tendency to get unbalanced quickly.
3. Avoid over-stuffing the machine and washing under sized loads. Both of these scenarios will cause a tendency to go out of balance on the spin.
This will solve 75-80% of unbalance issues. Let me know how it goes..
Dec 07, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Long cycles on my whirlpool duet washer
it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Thumping/knocking/rattles during wash agitation cycle
Mine is doing the same thing. I opened it up to see what was happening and it was the drive belt tension arm bumping around. Soon, the belt started slipping during the spin cycle. Now it won't spin and the belt starts to smolder from the friction of the drive motor. If you haven't checked your belt, that's a good place to start.
Jun 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
184 people viewed this question
Dan Webster
Dan Webster
Sal De
