Question about Canon BJC 80 InkJet Printer
Acer Laptop Windows Xp and BJC 80 WILL NOT PRINT TEST PAGE ?
It is seen as default printer ok will print out maintenance pages but not the test page email address g.robinson@ntlworld.com
Use bjc 85 driver for printing w/xp on your 80.
Posted on Jul 20, 2008
Canon BJC printer keeps printing test pages
Printers with USB are so inexpensive and think you have an incompatibility issue with your BJC-80 and the usb to serial convertor is not helping.
http://www.ebay.co.uk/sch/Printers-Scanners-Supplies-/171961/i.html?_from=R40&_nkw=printer&_sop=15
Hope that helps.
Mar 19, 2014 | Canon Office Equipment & Supplies
80 maintenance infoprint 1125
You need to replace your Maintenance kit and reset the fuser count.
This counter is reset by the servicer after a “80 Scheduled
Maintenance” message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the Diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
Select Reset Maintenance Count. Pressing Select resets the
maintenance page counter to zero. Reset Maintenance Count
Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count
screen.
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
The tests display on the operator panel in the order shown:
• Print Registration
• Print Tests
• Hardware Tests
• Duplex Tests (If installed)
• Input Tray Tests
• Output Bin Tests
• Base Sensor Test
• Printer Setup
• Error Log
• EP Factory Defaults
Sorry English only.... hope you can read English or google translate it...
Feb 24, 2010 | IBM Infoprint 1125 Laser Printer
My kodak printer is not printing my word documents
HAVe you tried to print on other application?
try to do some print test page using you computer. If your using windows XP you can print a test page under control panel and printer and faxes, Just click the icon of your printer then properties. If the test page printed the test page it means computer is fined
Just check the settings of word document. make sure your printer is selected as default printer
Nov 12, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
What does disabling bidirectional support mean
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Jun 12, 2008 | Canon BJC 80 InkJet Printer
Canon BJC 2000 question-1284 to usb
TIPS:
Jun 05, 2008 | Canon BJC 80 InkJet Printer
BJC 80 Won't Print
Try disable bidirectional support
Jun 02, 2008 | Canon BJC 80 InkJet Printer
Canon BJC 4300 InkJet Printer
i assume the cleaning method that you perform is offline (taking the cartridge our and clean them). I suggest you clean the head during the printer on.. try to perform below steps per the manual Cleaning the printer Printing the test pages Cleaning the print head I assume you do not have the manual anymore (no DVD) i list down the step below Its a bit long manual I suggest you download them from the canon website.. if you still have problem I can send to you the BJC 4300 manual Cleanning printer Make sure the printer is turned off before cleaning it. It is a good idea to unplug the AC adapter also. Do not clean the exterior of the printer with volatile liquids such as thinners, benzine, or any spray-type or chemical cleaners; doing so will damage the surface of the printer. When cleaning the printer, avoid the area near the print head on the BJ cartridge. Do not touch the print head. Ink may leak out and cause stains. Clean the printer regularly to avoid printing problems. Remove any ink mist or paper debris from the interior of the printer using a soft cloth moistened with water. Clean especially well around the platen area. If the rollers become dirty, you can clean them using a small soft brush. Clean the exterior of the printer with a soft cloth moistened with water. Clean away smudges and dust. Do not use paper products (such as paper towels or tissues) to clean the inside of the printer. Printing the Test Pages You can print these test pages to check the operation of your printer and your print quality. Test A This test prints a repeating pattern of characters. Demonstration This test prints a sample page describing the printer's features. Printing the Test Page From Windows You use the Test option on the Control tab in your BJC-4300 Printer Driver for Windows to print a self test, demonstration page, or a nozzle test pattern. Before selecting a Test option, make sure paper is properly loaded in the sheet feeder (see Automatically Feeding Paper starting on page 3-7). Click on the Test option and then click on the Print button. Printing the Test Pages Using the Operators Panel To print a test page, make sure the printer is turned off and paper is loaded. Press and hold the POWER button until you hear the number of beeps that correspond to the test page you want to print. Test Page Number of Beeps Pages Printed Demonstration 1 Continuous Printing Status Information 2 1 Page Test A 3 Continuous Printing Nozzle Test 4 1 Page When you release the POWER button, the test page starts to print. *All self-test prints require Letter or A4 size paper. Using a smallersize paper for a self-test print will result in parts of the printoutbeing printed directly on the platen. All self-test prints are printed in accordance with the current printing settings (font, printing mode, etc.) *Red- Information for technician not included in the user manual Cleaning the Print Head Your printer is equipped with a print head cleaning function to ensure constant high quality printing. Cleaning the Print Head From Windows If you are using Windows, you can execute print head cleaning from the Control sheet in the printer driver. Simply click on Clean Ink Head. 4300 Chapter 4 Page 6 Cleaning the Print Head Using the Operators Panel If you want to clean the print head from the operator panel, follow these steps: 1 Make sure the printer is turned on. Make sure the green POWER light is on. 2 Press and hold the RESUME button for at least two seconds until the printer beeps twice. The POWER light will blink for several seconds while the print head is being cleaned. Perform the print head cleaning only when you encounter a print quality problem. Unnecessary and repetitious cleaning will waste ink. If you execute the print head cleaning while paper is manually loaded, the printer will eject the paper and then perform the cleaning. 4300 Chapter 4 Page 7
Aug 24, 2007 | Canon BJC 4300 InkJet Printer
Time consuming
Try installing the latest driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=230&modelid=7998
Aug 23, 2007 | Canon BJC 80 InkJet Printer
Printer won't print
I have had a similar problem to this: I have had a BJC 80 for nearly 5 years and carried it around with my laptop using Win 98 and a par - par cable. It worked beautifully and successfully - so much so that when i saw a number of ink tanks going at very cheap volume prices in PC World i picked up a lot of them. Changing to an XP meant that i had to keep on using the par to par cable via a docking station but prevented my use of it with my new laptop - so when i brought it out of retirement it gave the blank printing problems yoiu described. By checking some error messages that it expected a black cartridge (which is what was installed) i found that inthe setup the software indicated it defaulted to colour cartridges. By changing this on the computer, it still printed blank pages but by changing the cartridge to colour it sprang into life when the set up asked for colour. I tried 2 other print heads which i had (3-4 years old) but still blank paper when printing to a black cartridge. I am now awaiting a new black print head carrier to see if it makes a difference. When trying with my laptop using XP and a par - usb cable it does not work at all. I have removed the sware driver for the Canon 80 and manually installed the one for the Canon 85 but no luck in printing to par - usb at this time
S Ranson
Nov 13, 2006 | Canon BJC 80 InkJet Printer
Canon bjc-80 - no print appears but cartridge & paper move normally
I had this problem too. It turned out there was old dry ink in there clogging up the printerhead and it was fixed after I ran the cleaning programme several times. However I can't for the lifeof me remember how to do that now. I know I found it online but it has since vanished. Maybe check your manual?
Nov 12, 2006 | Canon BJC 80 InkJet Printer
Canon BJC 80 InkJet Printer Logo
127 people viewed this question
old marine
old marine
