Question about Rainbow E series Canister Wet/Dry Vacuum
Rainbow Shampooer Where do the two tubes go at the bottom on the canister? Easy to hook up the hose but no place to hook up the tubes.
  • fimlay Aug 12, 2008
    the directions isn't clear, it show that the end of the tubes that are 2 together is suppose to be connected to the canister, but i can't find out where to put it
  • 2,794 Answers
It's been while since I used one. Hopefully things haven't changed.
One hose has to be be connected to the faucet of the sink using the adaptor. The other hose is supposed to go to the Rainbow iteslf.
one gets the rug wet and the other extracts.
Posted on Aug 04, 2008
Rainbow e2 aquamate
Hello ,
U r missing a wee screen that fits on the hole where the little hose plugs into the tank. Check inside the hose end or down inside your shampooer box.
May 26, 2008 | Rainbow E series Canister Wet/Dry Vacuum
How do i hook up the shampooer to my rainbow e series e2 canister have no instructions
Wow it's been a while. I think the shampoo attachment needs to be hook on the blowind part of the machine. If I didn't help take itto any vacuum store, they should be able to show you. Sorry thats the best I can give you. Chris
Feb 09, 2011 | Rainbow E series Canister Wet/Dry Vacuum
Don't know how to use carpet shampooer
You should have the new aquamate, it has a blue top to fill with the water and water/soap solution that pops down into place. You will need to use your power nozzle hose and tube, connect it to your shampooer (make sure to connect the power connection just like the power nozzle). Fill your water up, large compartment is for cold water only and the smaller compartment is for one cap full of soap then the rest filled with cold water. Start with just a splash of water or an empty basin in the rainbow. The trigger will control your water spray and the brush underneath. There are two levers on the back of the shampooer marked with a shower head and a bar of soap. Use the soap with the shower head and the soap on and the water only with just the shower head on. You will want to also go over the area shampooed with both off to **** up the remaining water. Make sure to clean your floor thoroughly before shampooing.
Aug 13, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Instuctions on how to use them together
youhook up the shampooer the same way you would hook up the vacuum head. you can put jut a little bit of water in the basin and it basically works like the vacuum except it dispenses cleaner and water when you posh the button in on the handle.
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Cant get rainbow shampooer to work
use the suction port for the vac hose
the water hose hooks to your kitchen faucet
Nov 11, 2008 | Rainbow E series Canister Wet/Dry Vacuum
How to hook-up shampooer to faucet
you may need an adaptor to snap it on
can get them at a vac shop
Oct 14, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister shampooer
i have never used my rainbow shampooer and have had it 2 or 3 years it is not working it will **** up water but will not spray water or shampoo what do i do?
Feb 18, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow aqua mate II instructions
You have the vacuum and the basin, you put them together just like when you vacuum but don't put water in the basin. There is a large white container that comes with the shampooer. you fill that up with water and then you place the vacuum cleaner and the basin on top of that. Now you will need the water hose (not the one that has the gas pump hadle). Hook that in the same spot that you do for vacuuming. Then you take the shampooing handle( it will have a trigger and a little white bottle and some tubes hooked to it) the one end of it hooks to the water hose and the other end hooks to the wands. There are 2 wands that come with your shampooer. At the end of those the shampooer head will be attached. There are two separate tubes there is a thick tube ( there two tubes fused together) and a thin tube, they hook to the large white container that you fill with water. Just look and you will see where they go. Then there is a tube that hooks to the shampooer head at the bottom. The you take the little bottle and fill it with your shampoo. You should have gotten some clips to hool onto your hose so that you can keep the tubes attached to it so they aren't in the way. You should be set. I hope I helped.
Jan 27, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Shampooer
aqua mates have an o-ringed valve assembly that go bad regularly reccoment having it replaced by local vac shop
Oct 07, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
280 people viewed this question
Top Rainbow Vacuums Experts
Chris Nomland
Chris Nomland
JoeVacs
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
