Question about Brother IntelliFAX 4100 Laser Fax
Brother IntelliFax 4100 skips
We have bought several of these over the years and most recent one bought about 6 months ago started skipping horizonatal areas of the incoming fax. It makes part of the fax unreadable due to some sectioned being eliminated and running together.
  • 550 Answers
Check the paper size settings, that it is set to the same size as the actual paper
~50% chance of being a solution, cant do better
Posted on Jul 19, 2008
Brother IntelliFax 4100 will not send long distance
it must be a problem with yourphone line. Contact your phone company, this can be solved at their level.
Jun 02, 2009 | Brother IntelliFAX 4100 Laser Fax
6 disc cd changer skipping
Laser is loose or out of alignment return to factory for adjustment.RICHARDM69
Dec 14, 2008 | Pyle PLCDCHK6 6-Disc CD Changer
Rebuilding the brother fuser for the intellifax 4100
Although it fit the broken fuser, it does not mean it's ok.
1-they must have the same number of teeth ( diif. gears have diff. amounts of teeth)
2-it must be the same diameter ( so they can mesh together, otherwise it's touching the tip of hte teeth and may be skipping.
But I'm not sure the double image is coming from there, it would jam the paper because the timing is off.
Anyway you need to eliminate the obvious then see what happens, I think you said you had another tonertry putting that in, if it doesn't work then change the gear for the correct one.
try precisionroller.com
Sep 08, 2008 | Brother IntelliFAX 4100 Laser Fax
Send Fax Issue
I have a brother intellifax 770 and I bought it used so their for I do not have the owners manual and I am having trouble setting it up and getting it to work. I can fax out but I just can't recieve faxes I can fax my daughter but when she faxes me she gets an error of 388 but she is able to fax and recieve faxes so we know her end is not the problem.
Aug 20, 2008 | Brother IntelliFAX 4100 Laser Fax
Printer overlap
sounds like a defective cartridge, if it's a generic toner the seals may not have been replaced, buy a new one and return the other as defective.
Jun 04, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFax 4100 sending solid black pages
It sounds like the CIS (scanner) has failed in both machines. Its no generally not a common problem. I would change one every six months if I was lucky.
It may point to something in your environment. I have have seen rust build up on the contacts of the scanner cause this problem. So if you have high moisture or are close to the ocean this maybe a problem.
Feb 14, 2008 | Office Equipment & Supplies
Skipping
If you go out and buy a cleaning disc it may help. You should really clean a car cd player at least ounce or twice every 6 months to get the best sound and play out of the unit. You can pick these disc up at any walmart , kmart , or computer store. Hopefully this can help you out
Dec 18, 2007 | Kenwood KDC-MP228 CD Player
Brother IntelliFAX 4100 Laser Fax Logo
59 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
