Question about Indesit W 123 Front Load Washer
Indesit w123 shaking
When machine gos into spin it shakes like mad any ideas rest of cycle is fine?
  • 66 Answers
Hi your machine is either out of balance , or a support leg may have gone weak.or a spring or worse case your bearings and spider need replacing
Posted on Jul 14, 2008
I had the same problem the drum when in spin cycle with the machine almost walked out the door shaking violently as if it was possessed. Check the drum on the inside of machine as most times it has some kind of screw to hold it in place for transporting etc. I did find on the other cycles it worked fine except for the spin cycle, and l have this machine in my caravan near my bed so you can imagine the ferocious noise and how scary it was, and it was a simple error on our behalf. I hope this resolves your problem. Kind Regards Karen.
Posted on Jun 29, 2008
Kenmore 3.5 cu ft front load quiet tumble action washer. Will not stop cycling, leaks, and shakes violently when spinning.
The shaking could be due to a defective drum support bearing. The shaking also could have caused the door seal to fail, resulting in the leak.
Jan 22, 2014 | Kenmore 3.5 cu. ft. Front Load Electric...
GE WBHV5200J3WW shakes during spin cycle with load in the machine
you might need a new Motor Asm Kit part number WH20X10028
the pic below is Motor Asm Kit that you might need okay
Jan 29, 2013 | Washing Machines
Indesit washing machine wie167 the word door came flashing up, the cycle has stuck and the door wont open
Ok the machine needs to be drained. Then switch the machine on again. The door should open.
Oct 06, 2012 | Indesit Door Handle Kit for W123, W133,...
Spin cycle shakes whole washing machine
have you tightened the jamb nuts on the legs after leveling the machine so they can't move from where you set them initially when you leveled the unit?
Mar 21, 2010 | Kenmore HE2 Plus Front Load Washer
Excessive shaking
your suspension dampers is damaged on washing machine causing bad balance on spin cycle..
Mar 03, 2009 | LG WM2277HSW XL Front Load Stackable...
Severe drum? shaking and display lights flicker during spin cycle
Loose mounting points or broken pins. If not that then possibly drum shaft could be cracked.
Nov 10, 2008 | Indesit W 123 Front Load Washer
Indesit W123 5 flashes error!!
The F05 fault means the pump is blocked, check the filter at the front bottom right of the machine behind the plinth and if its connected under a sink check the hose & connection
Nov 03, 2008 | Indesit W 123 Front Load Washer
Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
211 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
neilmoto
Chris Hall
Chris Hall
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
