Question about Thermador PCS484GGUS Gas Cooktop
Stainless Steel Cover for Grill
We accidently turned the grill on while the stainless steel cover was in place. The cover got hot and softened the plastic (?) handle material. While removing the handle it was dropped on top of the hot grille cover and has left marks made from the softened handle material. I am unable to remove the marks with any solvent that I have tried. Do you have any suggestions as to how I might remove these marks. Is a replacement handle and stainless steel cover available?
  • 868 Answers
Yes the parts are available .As for the removing the material left on the cover,I would use a very light 400 sandpaper first to see if that makes progress.Without seeing the cover it's not advised to give any advice, only because without the right pressure and tool used it will vary on how this will be removed.
Posted on Jun 24, 2008
How do i turn off child lock
I expect you have found the solution by now since this post is so old - but for any other that are searching, just push the child lock knob down and turn the knob and it should pop back up, turning the gas back on.
Mar 26, 2015 | Bosch 36" Induction Cooktop with Touch...
I Have A Jenn-Aie Model 720-0164 Natural Gas Grill. When I Grill, The Control Knobs Get So Hot Theyh Will Burn You. What Could Csuse This?
Can this grill be also used on propane? If so you might be running it too hot on natural gas, check to see if the control knobs have two different set of markings.
Sep 16, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
Installation in a hole bigger than the unit, is there a flange kit or something that will help get it to fit?
yes there is a kit you can use. most diy shops that sell cooker fixings etc will have them. they usually stainless steel and you have to cut them to size you need. and make a square with it. backing with bits of wood to the size of the hole need to put the top on and the stainless steel to cover the wood that has been put in. you can make your own. by filling the hole with wood strips get from a timber yard or store have them cut the size you need. then fix them to the open part you need to fill. leave a lip ( this is to put the stainless steel to. check it all fits. then get the strips of metal to fill the hole making sure they the right size glue them down to the strips of wood you have put in then put the top on. jobs a good one. don't nail the wood in place put 4 good long screws in each piece of wood gives it strength then.
Oct 30, 2013 | GE 30 in. JP340 Electric Cooktop
Scratches because of steel wool
Is there directional grain..? I have removed small imperfection in stainless look by gengtly rubbing only in the same direction as the existing grain.. and be careful sometimes the repair is worse than the issue..
Oct 12, 2013 | KitchenAid Cooktops
Burner shuts itself off after 10 0r s minutes of working normally
this unit has a gas coil controling the valve . and wen it gets hot it is failing and cannot keep the gas on . replace the valve coil // mm
Jul 12, 2010 | Thermador PC366BS Stainless Steel Gas...
How to remove brown scorch mark on stainless steel cooktop cover
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Mar 26, 2010 | Jenn-Air JGC8536 Gas Cooktop
Grill will not ignite-glow pug is bright red
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter
http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Feb 14, 2010 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
I have a dynasty grill which is approximately 8 years old and needs repair. Do you know of any repair persons in the ventura county area?
DeBruce Polish is a Non-Toxic, Non-Abrasive Multi- Surface cleaner that will restore the STAINLESS STEEL portion of your unit.
find at: debrucepolish.com
on \\\You Tube search: DEBRUCE METHOD
May 12, 2009 | Dynasty DSCT 36-6 Gas Cooktop
How to clean the stainless steel stove top
try a non abrasive cleaner like bartenders helper. it wont scratch and should help to tone down some scratch marks.
Aug 04, 2007 | Thermador 37 in. SGSX365 Gas Cooktop
Thermador PCS484GGUS Gas Cooktop Logo
146 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
jasbo
jasbo
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
