Lexmark C912 printer has a 980 sensor error. Can you assist? Any help would be greatly appreciated... Ray Elms
  • 300 Answers
980 - Face-Up/Down Switching Error, standing in front of the printer check the left hand side (the area between the fuser and where the paper exits the printer) you may find something stuck or some paper there
Posted on Jun 24, 2008
    Genius:
  • 1,689 Answers
Ray, a pal posted this on another forum, it will involve a firmware but you have to contact lexmark to get a passcode for the firmware. there are passcodes posted on the thread but it may not give you the right access, but you can try them out too
http://www.fixyourownprinter.com/forums/laser/26401
good luck
"202.6 papaer jam open rear door" i have opened door removed paper jam, unplug printer turned it off and on, opened allthe doors removed the toner cartrege and it still has the same error code and we cant...
Great job. You pretty much did all the troubleshooting needed. If those troubleshooting steps did not help resolve the problem, the most likely cause of the error is that the sensor inside the fuser has gone bad. It's a fuser problem. I suggest you contact Lexmark technical support or your authorized service provider for further assistance.
Aug 05, 2010 | Lexmark T642 Laser Printer
994 service density sensor
The 994 Density Error indicates that the printer's system card has encountered an unrecoverable error. The 994 Density Error can be caused by the density sensor becoming dislodged from the sensor board. This normally requires a service call. However, for basic troubleshooting, try powering the printer off, wait ten seconds, and then power the printer back on. If still no go, if possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages. If problem persists, I strongly recommend contacting your Authorized Service Provider or Lexmark Technical Support for assistance. I hope I can assist you more on this.
May 10, 2010 | Lexmark C912 Led Printer
Lexmark C912 not reporting toner properly
print the status page make sure the revision level in the lower right corner is greater than 803.04 if its not go to lexmark to update the code if it is greater than. press the right arrow until reset toner Lvl appears in the display press select. use the right arrow to scroll through the colors to be reset. when you get tot the color you want to reset hit select it should give a brief message resseting toner then move to the next one. when finished you will need to power the machine down and back on again before the changes will take effect.
Nov 20, 2009 | Lexmark C912 Led Printer
994 Service Density Sensor Error Lexmark C912 Color Laserjet
What the error means:
What to do:
This error normally requires a service call. However, on certain rare occasions, such as a power fluctuation or a stray static discharge in the vicinity of the printer, can cause a false 994 Density Error message to appear. In such cases, the error is only temporary and can be easily resolved without service. Follow the steps in the table to check.
Step Action
1 Power the printer off, wait ten seconds, and then power the printer back on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the page prints, the printer is functioning correctly.
2 If possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.
Yes: Continue to 'Contacting Lexmark' below.
Contacting Lexmark
When calling for service you will need to know your printer model type and serial number. If you need help locating this nformation, click here.
Call them while you're near the printer in case the technician asks you to perform a task involving the printer.
Jun 15, 2009 | Lexmark C912 Led Printer
Replace toner
Please click here and the installation guide to install the toner cartridges ..
Good luck..
Nov 11, 2008 | Lexmark C912 Led Printer
Paper Type and weigth Fot Lexmark C912
Media paper weight: is 20lb or 75gsm.
Media type: card stock, envelopes, Glossy paper, Paper Labels, Plain Paper, Transparent.
Media size: A3, A4, A5, Banner up to 11.69"x36", Executive, JIS-B4, JIS-B5, Ledger, Letter, legal, Super Tabloid, B5, C4, C5 DL, 7 3/4 9, 10 Envelopes.
demension is in inches, you need to convert it to centermeter.
Oct 30, 2008 | Lexmark C912 Led Printer
Lexmark C912 LED Printer
replace the rip baord if the firmware download failed ie flashing firmware eprom has fialed
Sep 29, 2008 | Lexmark C912 Led Printer
Lexmark c912
980 error code is internal printer error. This is beyond users capability.
turn off the printer and check all cable connections.
turn on the printer, you need to call lexmark service, if the error return.
Jun 24, 2008 | Lexmark C912 Led Printer
Lexmark C912 dn LED laser
one of your print heads ahve failed ie printhead leds the but you uuslly find the printer lies so you may have to replace several of them
Jun 20, 2008 | Lexmark C912 Led Printer
"981 Service Switch Error" and "994 Servise Density Sensor"
these are internal error. beyond user capability or repair
turn off the printer and check all of the cable connections.
turn on the printer, you need to call lexmark service, if the error returns.
Feb 17, 2008 | Lexmark C912 Led Printer
152 people viewed this question
jasbo
jasbo
