Question about Vestax CDX-05 Turntable
Vestax cdx-05s The scratch function and the brake on one of my cdx-05s does not work when playing a cd but works when the cd is not playing
  • snafubar Aug 14, 2008
    Have the same problem for the scratching; haven't noticed a problem with brake though.
    It seems that the mechanism that detects pressure on the platter is not working anymore. It is probably a switch problem: either the switch is broken, or its solder broke on the board.
The problem is with the tiny grey switch that tells the CDX that the platter is engaged. Take the face of the unit off by unscrewing the screws of on the circumference of the bottom of the unit, then locate the copper T shaped piece touching the spindle of the platter. Unscrew the little circuit board (this houses the on/off soft switch for the scratch mechanism) covering the bottom of the T and the T itself. Try powering the unit up and play a CD with the scratch mode activated. Push the grey soft switch to see if the music stops and move the platter back in forth to see if it scratches. If so, all you have to do is bend the copper T trigger to a position where it hits the soft switch just right; off when you don't have the platter pushed down, and on when you do. If the scratching doesn't work when you push the grey switch down, you have a problem I don't know how to fix. Hope this helps!
Posted on Jun 18, 2010
  • 515 Answers
One of the motor's on the unit might be bad. This is not an easy fix, and I would suggest taking it to a service center for diagnosis and repair.
- Davis
DJ Pro Audio
www.DJPROLAB.com
Posted on Jul 15, 2008
Vestax CDX-05 stutters and clicks when ejecting cd. Not all the arms on the transport assembly move when trying to eject a cd.
well to be honoust, it would be the best, but not price wise. I can't help you, only let a pro look at it with you by your side. It turnds and grabs the side and yesterdat i reard that loose components can be installed......
Dec 18, 2012 | Vestax CDX-05 Turntable
Vestax cdx-12 , left hand cddrive doesn't recognise discs imediately , sonetime not at all
In that case, the lens is weak. You need to change the lens entirely.
I wish you the best of luck.
Nov 05, 2009 | Vestax Cdx05 Table Top CD Player CD Player
Laser
The laser is probably dirty... Lasers last forever, or 100,000 hours of play, whichever comes first.
Use a CD laser Cleaner ... Radio Shack ($14)
It is a Audio CD with small imbedded brushes. No chemicals involved.
read the instructions carefully and turn on the volume when cleaning. The CD is an AUDIO CD and it will also give audio instructions.
Hope this helps! ... Don't take the unit apart...
Sep 08, 2009 | Vestax CDX-05 Turntable
Scratch works only on pause
The problem is with the tiny button that tells the CDX that the platter is engaged. Take the face of the unit off by unscrewing the screws of on the circumference of the bottom of the unit, then locate the copper T shaped piece touching the spindle of the platter. Unscrew the little circuit board (this houses the on/off soft switch for the scratch mechanism) covering the bottom of the T and the T itself. Try powering the unit up and play a CD with the scratch mode activated. Push the grey soft switch to see if the music stops and move the platter back in forth to see if it scratches. If so, all you have to do is bend the copper T trigger to a position where it hits the soft switch just right; off when you don't have the platter pushed down, and on when you do. If the scratching doesn't work when you push the grey switch down, you have a problem I don't know how to fix. Hope this helps!
Sep 01, 2008 | Vestax CDX-05 Turntable
Sony cdx-4000x
if you are playing original cds with no scratches try a cd lens cleaning disc if that fails it sounds like the laser
May 21, 2008 | Car Audio & Video
Pitch control center now 3.2% off center
maybe you should try a firmware update .follow the links on the vestax website about product support .
Dec 08, 2007 | Vestax Cdx05 Table Top CD Player CD Player
Pitch control center moved
Hello, Mr. Dixon.
I had the same problem and i decided it whit this procedure:
1. Restoring Factory Default Settings
2. Set the PITCH Slider to the center ( 0 ) position.
3. With the CDX-05 in the start mode displaying “no Disk” hold down EJECT and TIME/ENTER and press FILTER. The TEMP display in the LCD reads 0.0 and the procedure is complete.
Peter Petrov
Dec 08, 2007 | Vestax CDX-05 Turntable
Sony cdx m8800 error message
if it gives you a cd error message check the cd for scratches.try playing different cd`s
Jul 05, 2007 | Sony CDX-M8800 CD Player
Vestax CDX-05 Turntable Logo
251 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Electric Dime
Electric Dime
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
