Rca dvd home theatre system rtd258rv
I have a new system that is installed in my new motor home which has a HDMI interface to a Viewsonic LCD TV.It has a 5 disc changer.When I try to to load a dvd in the disc slot,it says BAD disc.I have tried 3 of the 5 slots with the same results.The dvd is good as I have played it at my home equiment.
Any idea what is wrong???
  • rmcarlson64 Aug 28, 2008
    I have the same problem in my fifth wheel. The unit has already been replaced once through warranty, and now I am having it replaced again through my extended warranty. I have no idea what is wrong, but I do know it is a POS.
SOURCE: 5 DVD disc changer doesn't open
are you using discs with labels that you out on your self? I had a similar problem before and my label peeled off in the player causing it to get stuck., you might just have to take it apart, and get the label out.
Posted on Nov 06, 2007
  • 7 Answers
SOURCE: Hooking Up The Theatre System to the TV and Cable.
this means you likeley have your cable box connected correctly, if you have it connected to a standard definition input (AV in or coaxial) make sure the that the dvd player is not in progressive mode.
Posted on Jan 27, 2008
  • 4234 Answers
SOURCE: RCA RTD206 HOME THEATRE
This is an indication that the optics are either dirty or failing. Carefully open up the unit and clean the lens using a cotton swab and alcohol. That should resolve the problem. If not, try playing a music CD. If the CD plays but a DVD does not, the optics are failing and need to be replaced.
Dan
Posted on May 22, 2008
  • 84 Answers
SOURCE: LG home 5 disc dvd changer
try to clean the dvd player it could be the lens that is having a hardtime reading the disk and it causing the noise
Posted on Jul 21, 2008
CaliBoy380
  • 11 Answers
SOURCE: We have a RTD259 RCA 5 disc home theatre system
Fist off, do you have Satelite TV or cable box? if so you need to run you audio wires from the audio out on those devices. If not from your TV should be audio out L&R to you audio input on your RTD259, now you may have a specific input for your TV, or you may not. If there is no specific inout for TV, there should be at least one AUX audio and video input open on your unit. Hope this helps, Cali
Posted on Jul 25, 2009
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
Connecting a panasonic surround sound to a sanyo tv
if you have this option, use a hdmi cord from the dvd output to the input of the tv.most new tvs have several hdmi connectors. Then use a fiber optic cable from sound system to the audio input of the tv. between the both it should sound like a movie theatre. thats how i hooked mine up. good luck
Feb 27, 2012 | Panasonic Audio Players & Recorders
RCA LCD Flat Panel HDTV and RCA Home Theater System--No sound
Video comes from external device to TV - OUT on device and IN on TV.
Sound connects by the red/white cable set (or HDMI). Place set in Audio OUT ports on TV and Audio IN ports on DVD. Then select AUX IN on DVD.
Jan 05, 2010 | RCA RT2380 Home Theatre System System
Installing a pioneer home theatre dvd/speaker system.
On page 36 of the Pioneer users manual, it describes how to set your audio for HDMI interconnect. Follow the directions, and hopefully it will work. You can down load the manual from the Pioneer web site. Google "speaker system HTZ171 DVD". Click on the Pioneer site for your system and look for the download on the right side of page.
I hope this was helpful...
Jul 25, 2009 | Pioneer 45X4 DFS BLUE LED CAR CD
How to set up 6.1 divinci home theatre system to 42inch HHD LCD T
davinci DA-6.1 home theatre tokk it out of box their is only speaker wires that connect on to another no power source or wires to tv I need help
Jun 27, 2009 | Audio Players & Recorders
I have bouight a samsung home theatre system that comes complete wiht a DVd player - i also have a samsung blu ray player - naturally ithought they would be compatible!! how wrong i was!! the connections...
You have several ways to do this. You can hdmi cables from the two units and plug them into your tv if it supports hdmi and run the audio out portion on the back of the tv and hook that into one of the audion inputs on the surround unit. Or you run audio directly out of the bluray using rca, digital coax, or digital optical cable. Turn the surround reciever to the corresponding input that you choose to use.
Jun 19, 2009 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
1ST TIME SETUP OF NEW TV...HAVE AUDIO, NO VIDEO
Are you getting sound through the TV from the DVD, or is the sound from the DVD coming out of your home theater/surround sound system (if you have one)?
If it has more than one HDMI port (on the TV) try changing it. If not look around in your DVD settings as it might think it is only giving audio through the HDMI to a audio/home theatre system. And using the other video outputs to give the video instead.
It shouldn't be a problem with the cable, since it is digital, if it were not to work - nothing would, or the audio would atleast be coming out weird (it it wasn't working).
Feb 28, 2009 | Samsung LN46A750 45.9 in. HD-Ready LCD TV
No sound from plasma to home theatre
First off it's always best to start from scratch when it comes to home audio. LoL. Many times I've been in this situation.
So with everything disconnected. You should have your HDMI, COMPONENT, RCA(R,W,Y)
HDMI and COMPONENT are the exact same thing and in all preference COMPONENT is far better thand HDMI for the pure fact that each wire is in it's own casing and insualted to avoid feedback from the other wires.
Anyways, with everything disconnected we begin
From you Cable/satellite box- Run your HDMI cable from you cable box to your HDMI 1 input on your tv.(If your speakers were to work on your tv you would automaticaly get sound and picture)
That should be all that you should be running from you cable box. Now that we have one thing running we go to the next thing.
From your TV run your audio out (RCA Red/White) to your amp. Usually your preference but more than likely your TV IN on your amp.
With your amp now set on TV, you should automatically get sound from your tv. and if your running an HD cable box even though your only running RED/WHITE to your amp, you will still be receiving Digital sound.
Most new amps Should have a digital input and if your running and 1080iUp this one RCA plugin will give you dolby digital sound from your dvd player to your amp. Then running a video rca up to your tv, will give you the picture, while the digital out on your dvd player to your amp will give you dolby digital sound.
It's a basic simple step to get sound. Like a continuing current. So just as long as you have your cable to -- tv -- home theatre. Everything should work. Otherwise I would go and check your cables and make sure they are not faulty.
I hope this confusing walkthrough helps.
Jun 23, 2008 | Panasonic TH-42PX60U Television
312 people viewed this question
 Grubhead
Grubhead
