Question about Neff 24 in. S5453X1 Built-in Dishwasher
Low salt light
The low salt light keeps coming on just after 1 wash,even if it's filled with salt.
    President:
  • 1,462 Answers
Try stirring the water in the salt container. however, as long as you renew the salt now and again, it doesn't matter
Posted on Jun 24, 2008
My low salt light on my Hurlcon vx7t salt chlorinator keeps comming on.How do i adjust it?
A low salt level warning is indicated on your VX Chlorinator if the salt level drops. If Low Salt is indicated, check again in 24 hours and then if it is still indicated, add two 25kg bags of salt to the shallow end of your pool. Run the filtration system for approx. 6 hours to help mix the salt in the pool. It can take up to a day for the salt to fully dissolve.
If the low salt light is still on, then you should get your pool water tested. If the Salinity is above 4000ppm then you may need to have your Chlorinator checked.
Warning: Some people recommend that you put salt directly in the skimmer box. This is a very bad practice as it allows very high concentrations of salt to be passed through your filtration and other pool equipment.
Hope this helps.
Jul 06, 2011 | Grilling
My pump keeps reading low salt it will run fine for about 2 to 3 hrs then the low salt alarm goes off. I have put in approx 240 lbs of salt I have at 16' x 48" pool. Please help
Your unit is malfunctioning...your pool @ ~5200 gallons, even from a no-salt in the water start-up should only need ~140 lbs. Are you certain it is reading low salt and not high salt or simply salt error? You can try diluting the water to get the salt levels below 3600, otherwise you need the unit serviced or replaced...generally with an intex, if that is what you have, it will mean replaced.
John
Jun 13, 2011 | Intex Pool & Spa
Hi i have a 18 x 48 above ground intex frame pool with a salt water pump /chlorinator system. i have put the required amount of salt in 75 kg and it has fully desolved. the alarm keep coming up on the pump...
the amount of salt that they reccomend in the book is just a starting point
You need to get a salt test kit that reads in #'s not colors
Get your pool to as close to 3000ppm as possible
lower than 2800ppm and you will not produce enough chlorine
any higher than 3500ppm and you can trigger high salt alarm, have bad tasting water, or even get cloudy water
Like you have done, when adding salt , filter only for 6 hours or so to fully disolve
Jul 18, 2010 | Intex Automatic Salt Water System for ...
Low flow
If your pool has a skimmer system there is a hose from the bottom of the skimmer going to the suction port that goes through the pool wall. Disconnect the hose off of the blue adapter and unscrew the blue adapter there is a screen / strainer right there whatever gets pass the skimmer basket gets plugged up in that screen.
Jul 07, 2010 | Intex Automatic Salt Water System for ...
Dishes not coming clean
Five common causes:-
1. The dishwasher hasn't got any salt in, or the salt dispenser control is set too low. Even if your tablets/powder have a salt function, it's often not enough in hard water areas and supplementary salt must be added to the salt dispenser.
2. There is no rinse aid in the machine or the dispenser control is set too low. Supplementary rinse aid may be needed even with tablets/powder which claim to include it.
3. The dishwasher is not reaching the correct operating temperature. This can be due to a faulty machine, or by using low temperature washes inappropriately. Low temperature washes are only suited to very lightly soiled loads which have not baked/dried on. There ARE special low temperature tablets/powders, but they're designed only for specialised domestic machines with low temperature overnight wash cycles or for commercial dishwashers.
4. The filters/debris traps at the bottom of the machine are not clean.
5. You're using the "wrong" brand tablets/powder. In this instance "wrong" simply means that your machine just doesn't get on with the brand you're currently using. price has little to do with it; I find with my current machine that the market leading expensive brand works poorly but the ultra-cheap supermarket basic value brand works perfectly. Also it can be down to using a genuinely wrong tablet/powder choice as per suggestion #3.
May 15, 2010 | GE 24 in. Profile PDW9280JSS Built-in...
I have a Simpson 22S750M 7.5kg eco washing machine problem is that it doesn't drain the water on the last cycle as it thinks that the lid is not closed even though it is, the beeping is driving me nuts...
we have had the same machine for a few weeks and have the SAME exact problem. They are replacing the whole electronics board but the part has to come from SA and will take a week at least. I have an incont child and this is very hard! why dont they recall?
Sep 18, 2009 | Washing Machines
Water softener
Hi vayvego,
I'm Harvey the Master Plumber.
You want to know why: Salt residue remains on the dishes. The water softener is going throught salt like crazy. You fill the salt and make sure that the light is off before you start the cylce. Within the first 20-45 mins the salt light comes on again and the dishes will not wash properly. You have come to the conclusion that the salt is being distributed to quicky but cannot figure out why the light keeps coming on. The switch inside the cap for the salt is set a the min.
I hope I understand you. This is how it's suposed to work. The salt in a water softener is only used for backwashig the filter. It should be set to backwash once or twice a week when nobody is useing the water, useually 2am or 3am. The only time you can get salt at the fixture is if you're backwashing when you use the water. If you're backwashing all the time either the controls aren't set right or the unit is defective, in which case it is unlikely you can fix it. In that case you might consider utilizing our Repair Directory to find a repairman. If it's still under warranty, it's time to make a phone call.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Danby 17 in. DDW1802W Designer Series...
Neff 24 in. S5453X1 Built-in Dishwasher Logo
785 people viewed this question
Top Neff Dishwashers Experts
shaun taylor
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
