Question about Medion Computers & Internet
Is it possible to replace the broken graphics card on my medion mim 2120 laptop and if yes do you have any idea of the cost of the part? thanks
  • 22 Answers
Yes it is possible. Graphics cards start out around $50
Posted on Jun 24, 2008
Medion erazer
Assuming you connected the auxiliary power connectors, do you get the boot screen at all?
Nov 09, 2013 | Computers & Internet
My power lights keep going from red and green then they go off altogether. i have to fiddle around for a bit before the power comes back on mim 2120 medion laptop
Could be three things causing this. First, the DC jack soldered on the motherboard could be loose. Over time the solder will crack loose. Most likely this is the problem. Second, the AC adapter could be going bad. Finally, the battery could be going bad. Each of these items should be checked.
Nov 17, 2009 | Computers & Internet
Medion MIM 2310 Monitor not working
it sounds like there is a short on your motherboard.your graphics card might be bad.or lcd screen.when you hook up a external monitor do you wait till everything is booted.wait 5 min then hook up the crt monitor.hold down fn then the button with the monitors.if none of this works then your graphics card is going bad.if it keeps restarting then there is a chipset problem or a short.best bet is to get a new laptop.save the harddrive and the ram,cd player,battery.you can sell these or buy the same type of laptop.and use these parts.
Jul 18, 2009 | Medion md40298 Notebook
Medion mim 2120 laptop
Hi
First i reccomend checking the power cable and seeing if there are no short circuits or breaks in the circuit. - to do this unscrew the end of the power cable - this part wares out often and costs about 50 cents to replace.
Hope i could help
CBZ
Comment if you need more assistance
Apr 27, 2009 | Medion md40298 Notebook
Wireless connection problem with Medion MIM 2120
hi..go and try to find the (Control Panel) then double click the icon of name is (Network Connections) then find the wireless LAN connection..if you have wireless connection u need configuration..if not no have wireless connection you need re-install the LAN card driver..Thanks and good luck..^_^
Feb 01, 2009 | Medion md40298 Notebook
Medion 2120 stuck on f2 screen
put the cmos battery back in and before you turn it on press and hold down the f2 key should send you to bios where you will have to reset all funcation becase you removed the battery
Dec 11, 2008 | Computers & Internet
I have a medion mim 2310 notebook laptop and the problem is that when i plug in the charger it short circuits and switches off,anyone got any idea what the possible cause may be as i dont fancy replacing...
dejay .
if you have a light for charging then have you checked if the ddr memory cards are ok just take one of some one to try you may get it solted if the memory is no good,wrong or damadge then replacing the memory card will solve your problem !
Nov 09, 2008 | Computers & Internet
Fitting new screen medion mim 2120 laptop
I could not find a breakdown for you laptop. But from a picture I saw on the web, I could tell you that it is probably the same as most laptop. First, there are screws under the round inserts. You need to pry those up and stick the aside ,in order to put them back when you finish.
Then remove the screws, usually 4 on each corner of the screen. Some laptops have 2 screws on top of the screen near the latch.
Then you need to pry the front bezel off the screen. You can use a small straight screw driver. Carefully (as not to scratch the case) insert the screw driver and pry the bezel away from the back casing of the LCD.
Once you have the bezel off you will see the screws that hold the actual LCD screen in, remove them and lift the LCD out. You will have to un-hook the cable from the System board to get the screen completely out. Then install the new screen.
Please remember to rate all users who assist you for free :)
Oct 01, 2008 | Computers & Internet
Medion mim2080
Usually this is caused by the Compact Fluorescent Tubes that run down the back of the screen, or the inverter that powers them.
If you are really confident, you might be able to but replacement CCFL's and inverters on ebay and install them or you could take the machine to a professional and them do it.
Alternatively if you use your laptop at a desk, you could simply plug it in to a monitor and use it like that.
I hope that helps, if you have any further problems, please add them ass comments to this question. If I have been able to answer your question (or not) please click on one of the ratings buttons to let everyone know how I did.
Thanks for your feedback, and good luck.
Jan 13, 2008 | Medion (40010998)
Computers & Internet Logo
127 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
