I have a 65 inch toshiba projection tv about 5 years old that has a problem with the picture. the red blue and green lines are not aligning, giving it a 3d looking image. i was just wondering what it might be. the motherboard was replaced about 2 years ago also so i dint think that is it. thanks for any help you can give.
    Novelist:
    Champion:
  • 216 Answers
Greetings fireftr2001,
You may need to perform convergence on the unit. This is something that needs to be done periodically and especially if you have recently moved the unit. You can normally find the convergence option in your menu system.
Thanks,
Dorothy
Go Ahead. Use Us.
Posted on Jun 24, 2008
Re: Toshiba 65 in Cinema Series - 12 years old. Color Separation. Green bow at top center of screen, red and blue double images tilting upwards toward sides. Sometimes clears unassisted after set has...
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 20, 2011 | Toshiba 65H82 65" Rear Projection...
Convergence adjustment aligns red and blue picture tubes to align with fixed green tube. Green image appears to skewed (possibly out of focus) in one direction making it impossible to get red and blue...
Ur tv convergence are dead.U know how to solders?Must replaced the 2 STK convergence ICS,some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 04, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Hitachi 65F59 65-Inch CRT Projection HDTV picture skewed.
The convergence output IC's have failed and need to be replaced. Sometimes when they go biasing resistors burn open also. These are large amplifiers mounted to heat sinks and have as many as 18 pins soldered into the circuit board. Better be handy at desoldering even if it's only the IC's that are bad.
Jul 10, 2009 | Hitachi Televison & Video
Big screen TV corners of tv blue and red
I HAVE A 57" TOSHIBA REAR PROJECTION TV. HALF THE SCREEN HAS A BLUE TINT AND THE OTHER HALF IS CLEAR.
Jan 19, 2009 | Televison & Video
Mitsubishi Rear Projection 65" tv picture becomes blurred bouncing right to left and color is red & green. TV is 8 years old approx. Any suggestions. Have not had any problems prevoiusly. First it woudl...
Sounds like possible solder connections on the convergence ICs. If so, you will see the red, green, and blue not lining up on ever input and even the mits menu. If you can bump it to correct, its just a solder connection, but if its out all the time then the ICs need replaced. This is a difficult repair only recommended for skilled technicians (40 solder connections + possible re-alignment needed)
Dec 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Sony 65 inch screen tv
The lines you saw, i;m sure they are the ones called retrace lines but know the failure could be located on the red CRT board. Most likely the video amplifier is defective and not necessarily the CRT.
What is the model number of your TV?
Jun 17, 2008 | Televison & Video
Double image/ out of focus with green and blue seperation
Your tv is crt-based and is out of convergence. In other words, the settings for keeping the Red, Green and Blue images aligned have drifted and must be reset. This is common with CRT projectors and CRT rear projection tvs.
Refer to your owners manual for instructions on re-aligning it.
Apr 18, 2008 | Hitachi 51UWX20B 51" Rear Projection...
65 Toshiba picture sides are bowing in.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 21, 2008 | Toshiba 65HDX82 65" Rear Projection...
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
Jvc tv picture quality
sounds like your crt tubes...meaning Red, Green and Blue are out of alignment...or possibly 1 of the crt's is burned out.
Jan 29, 2007 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
