Question about Dell 3000cn Laser Printer
Back cover won't shut on 3000cn
Had a paper jam, removed the paper (gently) from the back of the printer and tried to shut the cover - won't shut. Something is keeping it from closing, but what???
  • Anonymous Mar 31, 2014
    The computer says the printer is out of paper, but it isn't. I have reloaded the paper. Shut everything done and restarted.
There is a guide just at the pick up roller that can fall out of position.
Pop off the back cover (the hinges are spring loaded). There are 4/6 screws holding the paper conveying section, remove these and teh conveying section should just slide out. Disconnect the cables on the lower RHS. There should now be a whitish plastic guide with sponges on it visible. Stand it upright placing the guide behind the frame of the machine, use a prop to keep them in place, something placed into the paper traay section. then re-fit everything.
Hope this helps.
Posted on Jul 07, 2008
How to clear paper jam trouble epson L210
most printers have a cover at the back. Switch off the printer and see the back and gently pull out the cover and you should be able to see the jammed paper. So you can gently pull the paper out. If that doesn't work put the cover back and lift the front cover and see if you could see the jammed paper or even small pieces from a torn page. If you do, gently pull all the pieces out. Once you cleared all the jammed papers it should work.
Unplug all your cables and leave for few minutes and reconnect the cables and switch on, it should work. Good luck.
Nov 16, 2015 | Epson L210 - multifunction printer /...
Dell 3000cn Laser Printer Problem--Paper Jam
Have you been able to get the toner out yet?
There is a little handle on the right side that you need to lift to unlock the cartridge:
See if there is anything hiding in that part of the paper path. Maybe even just re-seating the cartridge will be enough for the sensors to stop tripping.
Feb 13, 2008 | Dell 3000cn Laser Printer
Tip
How to repair paper jams
<span>Instructions</span> <ol> <li> Turn off the printer. As the printer shuts down, it will automatically attempt to remove any paper that is jammed.<br /> </li> <li> Pull any paper that is visibly sticking out of the printer. This can help to remove it if the paper is loose enough.<br /> </li> <li> Open the printer as you would to change the ink cartridges. Check inside to see if you can find the jammed paper and gently pull it out. You may need to remove the ink cartridges. Alternately, some desktop printers have a separate panel at the back of the printer that you can take off in order to remove jammed paper from the roller.<br /> </li> <li> Turn the printer back on and repeat the steps if necessary.<br /> </li></ol> jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); <span>Tips & Warnings</span> <ul> <li> Gently pull any jammed paper using both hands and avoid ripping. Tearing the paper may worsen the jam.</li> <li> Avoid filling paper trays to maximum capacity in order to prevent printer jams and never use damp paper.</li></ul>
on Dec 23, 2010 | Office Equipment & Supplies
Paper jam. Sheet printed but didn't pass through the rollers
  • Remove the paper tray completely by pulling it out towards you.
  • Now pull the jammed/stuck paper out gently.
  • If you cannot remove the paper by the above procedures,open the printers front cover to access the cartridges assembly.
  • Pull the cartridges assembly gently and slowly.This will come out together with the jammed paper.
  • If jam not cleared,open the back cover and pull the tab outwards to access the fuser unit.Remove the stuck papers here.
  • Hope this helps.Thanks!
Oct 31, 2011 | Brother HL-2040 Laser Printer
I have a Dell 3000cn and it won't print due to the problem "Paper Jam Open Reg Cover." I have tried looking for a lodged paper inside the printer, and trying to let the roller read the paper. Any...
I've got the same problem.
The problem is probably due to a lose or defective sensor.
Open the back cover. In the middle you can see now a sensor (2 small glass "eyes". It is possible that this sensor has lost connection (white plastic holder). The way to access this is to open the imaging drum cover, remove the drum and reach all the way down inside.
So far my theory. I can not reach it and have little hope. Never again a Dell :-( .
Jan 06, 2011 | Dell 3000cn Laser Printer
I have the Dell laser printer 3000cn. The printer powers on and everything but I can not do anything because it keeps asking me to close the reg cover. ther reg cover and all the other covers on the...
Dell 3000cn Color Laser has a duplex. If you face the printer on the top right of the duplex there is a button to release the duplex and it folds back. The reg cover is a door on the back of the printer that is covered by the duplex, try opening again, I know you have done this, maybe even wiggle it a little see if it registers as closed.
Also check to see if any dust or paper pieces maybe be jammed in there.
Nov 02, 2010 | Dell 3000cn Laser Printer
Dell 3000cn paper jam open reg cover
Don't take risk about your equipments. consult a enjineer.
Aug 06, 2009 | Dell 3000cn Laser Printer
Paper jam
Some of the Ink Jets have a cover in the back of the printer that you have to turn a lock to remove and you could have some paper stuck back there.
Mar 03, 2009 | HP DeskJet 3940 InkJet Photo Printer
Dell 3000CN Laser Priner
Removed the fuser unit and also removed the left hand side panel to access the gearing mechanism.
Manually rotated the gearing a number of times thru 360 degress. This appears to have cleared whatever was causing the printer to detect a paper jam although there was no obvious sign of bits of paper or even dust build up.
Dec 28, 2008 | Dell 3000cn Laser Printer
Paper transport does not work; terrible grinding noise
I took mine apart from the back and put it back together and it worked. It is probably due to moving it and the bottom paper tray alignment gets out of whack. I inspected all of the gear train and didn't find any worn or missing teeth. I suspect a paper jam started it and the user turned the printer around to open the back door. Since the handles are on the printer the tray doesn't move with it which allows it to separate and possibly jam a pickup drive gear.
Nov 08, 2007 | Dell 3000cn Color Laser Printer
Dell 3000cn Laser Printer Logo
100 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
