First off... be warned overclocking is not for the faint of heart... now let us begin...
MAKE SURE YOU HAVE ADEQUATE COOLING!!!!
I can't stress this out enough if you plan on overcloking it's worth spending some money on some fan's specifically a CPU fan to make sure it stays cool. A side effect of overclocking is increased heat.
Restart the computer and go into your BIOS. Look for the setting to change the bus speed. Depending on your specific CPU it should be 200 MHz (if it's not don't worry, most computers now are 200 MHz). There should also be an option called the multiplier. This one is usually unavailable. If it is available you have a high-end CPU model that is "unlocked".
THEORY:
The system bus is multiplied by the multiplier and gives you the resulting speed.
200 x 16 = 3200 => 3.2 GHz
IF your multiplier is unlocked you can increase it... it's not then we have to use the system bus.
When you change the system bus it increases the speed of everything in your system... that is the link in between individual components. But it's a double edge sword... it will cause you system to become unstable more quickly and reduce the maximum overclocking potential.
PRACTICE:
Increase the bus speed 3~5 MHz at a time. Restart the computer boot into the Operating System and run applications you normally would. If nothing crashes, hangs, freezes, locks up... you can reboot the computer and increase the bus speed again. Repeat theses steps until:
a) reach a point where the system becomes unstable
b) you feel like pushing your system more is getting to risky
This is a very basic answer on how to overclock. For more information, guides and other goodies
http://www.extremeoverclocking.com/ is a good website for more information and guides.
WARNING: If you push the system to far to fast without doing it gradually you can surpass the computer components limits and cause damage to the computer parts. I am not responsible for any damage that occurs. This is just a guide.
