Y9ou can gain access to the driver side blend door actuator by removing the glove box. The actuator will be in the left corner of the glove box opening. If you remove the actuator you will be able to turn the pin. If you can turn it 360 degrees the blend door is broke.
If your lucky its only the drivers side. If you get the repair kit from chrysler it will come with instructions with pictures on how to replace the blend door without pulling the HVAC unit/Dash. If the passenger side is broken the HVAC unit will need to be removed.
Heater treater (google them) also have a metal blend door replacement and instructions online on how to replace them without pulling the HVAC housing.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
