It appears U150 the following tank cannot recognized.. All ink are full
Has anybody a solution for these crappy ip6600d canon printers constantly getting the u150 error, i've got a brand new canon catridge but to no avail, it still complains.
Posted on Jul 14, 2008
mariolands
  • 2296 Answers
SOURCE: error code U150 The following ink
First, make sure you have the right ink cartridges. Here are the right codes: CLI-8BK and PGI-5BK for black, Yellow - CLI-8Y, Magenta - CLI-8M, Cyan - CLI-8C.
If the ink lamp is off then an ink tank error has occurred. Try to remove the ink tank and re-seat it. Make sure you removed the plastic cover on the ink tank. If nothing helped, you need to replace the faulty ink tank.
Posted on Dec 29, 2010
SOURCE: INK TANK
U150 is a 'faulty electronic chip on the tank' error. If you installed a new Canon OEM tank then probably the chip on the new tank is bad.. Take that tank back for a replacement.. If you installed a Clone(non-OEM) tank, then that one will only work if you retrieve a chip from a known good OEM tank and glue it on to it. Clone(non-OEM) tanks all come without chips.
Posted on Sep 26, 2007
SOURCE: error code: U150 The following ink tank cannon be recognized (Cyan)
The good news: Office Depot replaces "damaged" cartridges. This is my only solution to this problem. At least we'll get our money back. This is certainly an issue, Canon has to solve. Other than that I think this printer is much better than other products in this price range.
Posted on May 14, 2008
sadguy
  • 88 Answers
SOURCE: Error message U150 appears saying
try diffrent pixma mp970 may be that defcated
Posted on Aug 15, 2008
  • 421 Answers
SOURCE: error: U150 the following ink tank cannot be recognized
Only thing you can do with the U150 error is replace the tank.
Posted on Dec 05, 2008
Ink tank connot be recognized
I wish I could add a solution but I can only advise to stay away from these terrible printers. My Canon MG5320 is just barely a year old, barely used, maybe a dozen times and I'm getting an irreconcilable C000 error. "Consult the manual"? Manual advises that it needs to be seen by a tech. Same thing, can't get the cartridge tank to move to center to access the inks. It's called a built in "f-u" by Canon.
Jan 23, 2013 | Canon PIXMA MG5320 All-in-One Printer
Hi, I refilled cartridge CLI-526M fromCanon Prixma MG5250 and I have the error U130. How can I resolve the error to reprint? Thanks.
FAQ: An Error Message Is Displayed on the LCD
Issue
If an error message is displayed on the LCD, take the corresponding action described below.
Cause
The following ink may have run out. Replacing the ink tank is recommended. U041 Print head is not installed.Install the print head.U051 / The type of print head is incorrect.Install the correct print head.U052 Some ink tanks are not installed in place. U072 / More than one ink tank of the following color is installed. U071 The remaining level of the following ink cannot be correctly detected. Replace the ink tank. U130 The following ink tank cannot be recognized. U043 U140 U150 The following ink has run out. Replace the ink tank. U163 There are no photos in memory card Contact the support center or service center for ink absorber replacement. Press OK to continue printing Ink absorber full. Service required Timeout error has occurred The device may be incompatible. Remove the device and check the manual supplied with the connected device An unsupported USB hub is connected. Remove the hub. B200Printer error has occurred. See the manual **** Printer error has occurred. Turn off power then back on again. If problem persists, see the manual
Jul 06, 2011 | Canon MG5250 Printer
Error code U150 The following ink tank cannot be recognized
Dec 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
New black cartridge. won't print.
your housing may be not clean try to cllean it and clean the back of the tank carfully and erinstall the tank and reset the printe4r. if not try to use the old one again and see if you get the same error
Nov 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
U150, the following ink tank cannot be recognized
I had this same problem too and it's so frustrating because you cannot even scan and scanning is completely unrelated to ink. We called Canon and found out that it was a bad print head (ink tank). They ended up sending us one for free so I recommend calling them to report the problem. 1-800-828-4040.
Jan 10, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon IP6600D Error Message U150
you need to reset the chip on the ink cartridge.......................
Aug 22, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Error: U150 the following ink tank cannot be recognized
Jun 27, 2008 | Canon MP970 Photo All-In-One InkJet...
Error code: U150 The following ink tank cannon be recognized (Cyan)
U150 ink error fixed!
I too was getting the error for unrecognized ink cartridge. Then the little green circ board fell out of the end of the ink cartridge and it hit me that maybe if I put in the little green circ board from the old ink cartridge of the same color, then maybe the ink cartridge would be recognized. It worked! So don't throw out an ink cartridge that still has ink just because of that error and hold onto your empty cartridges in case you need the little green/gold circ boards.
This works!
Dec 26, 2007 | Canon PIXMA MP600 all-In-One InkJet...
INK TANK
Sep 11, 2007 | Canon PIXMA MP830 All-In-One InkJet...
748 people viewed this question
jasbo
jasbo
